19-21 Tundra (No Transmission Cooler) Miles Survey [OFFICIAL THREAD]
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stan7174, Dec 8, 2024.
  1. Dec 11, 2024 at 2:55 PM
    Stan7174
    Stan7174 [OP] New Member
    2021 Tundra SR5 5.7 4x4 Double Cab
    Stock
    Great to hear! Do any of his 19-21’s have aftermarket transmission coolers installed or are they stock?
    Can you ask him and give some specifics for the mileages of the 19-21’s? I’ll then go ahead and add them to the leaderboard if exceeding any of the current ones.
  2. Dec 11, 2024 at 3:15 PM
    Clay00019
    Clay00019 New Member
    Winnipeg Manitoba Canada
    2011 Dbl Cab TRD Tundra
    They are all stock, no modifications. I will inquire about the mileage. Cheers
    Stan7174[OP] likes this.
  3. Dec 11, 2024 at 4:40 PM
    SportDek
    SportDek Boat hauler, Bus Driver
    Dale
    TEXAS from MN
    2021 1794 Tundra Crewmax Windchill Pearl
    TRD Swaybar, RCI Skid plates, DiamondBack HD cover, bed rug, Cooper AT3 4S
    Year: 2021
    Miles: 42,000
    Transmission fluid Interval: Not yet
    Towing: Yes
    Towing Frequency: 1 time/week during the boating season (22 ft Cobalt)
    Temp Monitoring: No
  4. Dec 11, 2024 at 5:20 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In northern Manitoba they glue an electric heater to oil pans, otherwise oil is not fluid in the morning ;)
  5. Dec 11, 2024 at 5:24 PM
    Clay00019
    Plus block heaters, battery blankets and cab heaters.
    vtl[QUOTED] and Stan7174[OP] like this.
  6. Dec 12, 2024 at 6:56 AM
    Newm
    Newm New Member
    KC
    Year: 2019
    Miles: 124,500
    Transmission fluid interval: Flushed at 80K (need to do a dump and fill here this spring probably)
    Towing (y/n): Yes
    Towing Frequency: 6 times a year....little 7X12 enclosed motorcycle trailer
    Temp Monitoring (y/n): No
    Been such a solid truck. I keep looking at new trucks but mine has never given me a hint of trouble in the 6 years I have owned it. On my 3rd set of tires, new front pads with rotors and a battery is all it has required outside of normal maintenance. Probably drive it until closer to 200K and see where I am at then.
    Henry1jg, Stan7174[OP] and SD Surfer like this.
  7. Dec 12, 2024 at 8:45 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Just for reference: a 2 years / 20k miles ATF with no cooler from 2022 Sequoia (V8). Tundra was worse. The color was the reason the cooler was installed in Sequoia as well. Otherwise the transmission was shifting fine. Occasional temperatures observation didn't reveal anything utterly bad, unlike in Tundra. But brown ATF with apparent inclusion of worn clutch materials speak for itself.
    We don't plan on getting rid of our V8s at 200k nor 2M miles, so I keep maintaining them good. My next car after Tundra is wheelchair.
  8. Dec 12, 2024 at 10:30 AM
    Stan7174
    Stock
    Added this to leaderboard, thanks!
    Newm[QUOTED] likes this.
  9. Dec 12, 2024 at 11:03 AM
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    It sounds like in Northern Manitoba, the transmission cools you?
  10. Dec 12, 2024 at 11:24 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    - '21
    - 32k
    - I haven't changed it yet.
    - I've only towed a couple things.
    - I do monitor temps with ODB Fushion and Veepeak.
    I have 315/70-18 (35.6) tires. I almost always drive with Tow/Haul on. I have seen temps get 240+* climbing the mountains in 2wd on the pavement. I will keep it in S4, too. When in 4wd I will use 4-low and tow/haul. Temps will still climb in the 230* range at times. Just driving on the freeway to work, I can see 230*. My drive to work is about 12 miles, no mountains. Slight grade, maybe .5-1%.
    Both my Tundra's (prior was a '20) ran nearly identical temps.
    I saw the same temps when I was running 295/70/18 tires.
    I have a cooler kit sitting in the garage waiting to be installed. I just need to get off my ass and do it.
  11. Dec 12, 2024 at 12:08 PM
    Clay00019
    I would rather be on the board walk in Savannah any day.
  12. Dec 12, 2024 at 1:02 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    2020. 50,000 miles. No transmission fluid change yet. Plan to change it at 60,000. I tow 2x a year.
    Henry1jg and Stan7174[OP] like this.
  13. Dec 12, 2024 at 1:44 PM
    Bowzer
    Bowzer New Member
    Year: 2019
    Miles: 70,500
    Transmission fluid interval: Drain and Fill coming end of month; Plan to send off some fluid for analysis just because.
    Towing (y/n): Y
    Towing Frequency: 1/Month (Light duty stuff...utility trailer)
    Temp Monitoring (y/n): N (But I lean down and smell underneath it a lot...)
  14. Dec 12, 2024 at 8:49 PM
    TundraBrew
    TundraBrew New Member
    Following. Only 40K on my 2019. I'll add my data in about 6 years.
  15. Dec 15, 2024 at 8:53 PM
    Stan7174
    Stock
    Any word on the mileage?
  16. Dec 15, 2024 at 9:43 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Year: 2021
    Miles: 50,500
    Trans replaced 30k miles with brand new Toyota and 48k miles with custom built.
    Transmission fluid interval: Not serviced outside of trans replacement
    Towing (y/n): Yes
    Towing Frequency: 1/Month ~4k lbs, occasionally 7k. Weekly haul 1500lbs in bed.
    Temp Monitoring (y/n): Yes (ODB2 bluetooth reader, was commonly 225 or more on the freeway).
    Supercharger installed at 16k miles. 34.4” Tires. Headers, exhaust, smaller pulley, larger throttle body and intake, estimated 650+ crank hp. Launched 0-60mph 100+ times before each transmission failed. Trans cooler and transmission custom built at 48k miles (no issues since then but will see in 10k miles lol).
    Stan7174[OP] and Terndrerrr like this.
  17. Dec 16, 2024 at 5:35 AM
    JohnWhicker
    JohnWhicker New Member
    Is that the Kenwood Excelon Reference DMX1057XR HU? And for the dashboard you have the Tundra iDatalink Maestro Module?
    Whats's the complete list of parts? HU, wiring harness and the Maestro module?
    How do you like the unit so far? Better sound?
    Was the install pretty intrusive? Does it leverage the existing truck microphone?
    Sorry for so many questions :)
    Thanks
  18. Dec 16, 2024 at 6:15 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    What are you doing with all of this data?
    Stan7174[QUOTED][OP] likes this.
  19. Dec 16, 2024 at 6:28 AM
    Bergy24
    Bergy24 New Member
    Why did it fail?
  20. Dec 16, 2024 at 6:40 AM
    #50
    Clay00019
    No, I doubt I am very high on the priority list this time of year.
  21. Dec 16, 2024 at 6:46 AM
    #51
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Apparently it was a missing transmission cooler problem. 650+ crank HP and many 0-60 launches had nothing to do with it!
  22. Dec 16, 2024 at 8:10 AM
    #52
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    I sent you a PM so as not to clutter this thread with my long-winded answers. :rofl:
  23. Dec 16, 2024 at 8:37 AM
    #53
    Jmunk
    Jmunk New Member
    2020 Tundra SR5 Crewmax
    I thought the same thing, new profile and comes on with a thread about mileage without a transmission cooler. Seems as if research is being done for some purpose. Any correlation to the company that was looking at a lawsuit?
  24. Dec 16, 2024 at 9:08 AM
    #54
    PermaFrostTRD
    Northern NY
    Good thread, OP.
    Year: 2019
    Miles: 63k
    Transmission fluid interval: First will be at 65k (I requested at 60, dealer suggested waiting to split up the bill from other 60k services - I stated I didn't mind the cost, but I think it was a time issue - they are always super busy with 2week + lead time for regular services; Plus I needed the truck back that afternoon for something I cant remember at the moment)
    Towing (y/n): y (small equip trailer for a ferris ISX 800 zero turn, various tillers, snow blowers etc; sometimes mulch, soil, yard debris in the trailer, sometimes in the bed)
    Towing Frequency: 2-3x/ month. most of my driving is short trips <5mi; 3-5x/ month is some longer 20-30 mi trips, 1-2x/ month 50+ miles; 1-3x/year 1000+ mi
    Temp Monitoring (y/n): nope
    I don't tend to drive it like I stole it until I'm in the deep woods/ with mud/snow/both in 4hi, but I bet my short trips unloaded and tow/hauling are probably pretty tough on my trans. Will try to get pics of the drain and fill to update/post here.
  25. Dec 16, 2024 at 10:08 AM
    #55
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Kind of thinking the same. Definitely some motive behind. Even if it's just for the personal decision making of adding a cooler or not. Outside of that, a bunch of people claiming their numbers on an internet forum doesn't hold much weight lol
  26. Dec 16, 2024 at 10:16 AM
    #56
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Unmodified coolerless truck will make it to 36k miles / 4 years of factory warranty, whichever comes first. The only fookup by Toyota was model year 2019 when they still mentioned the truck has a cooler.
  27. Dec 16, 2024 at 10:56 AM
    #57
    Jmunk
    Jmunk New Member
    The better question to ask would be - what does the oil analysis on the factory WS fluid at various intervals look like on numerous trucks. That would give more scientific data as to how well the WS fluid holds up without a cooler.
  28. Dec 16, 2024 at 5:45 PM
    #58
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    My 2020 said it had a transmission cooler on the window sticker as well
    bpilati and vtl[QUOTED] like this.
  29. Dec 17, 2024 at 6:06 AM
    #59
    bpilati
    bpilati New Member
    Virginia
    2020 Magnetic Gray Metallic DC 4x4 SR5 TRD
    If you have a tow package, you should have oil coolers, yes?
  30. Dec 17, 2024 at 6:08 AM
    #60
    bpilati
    bpilati New Member
    Virginia
    Truck with tow packages usually do. I think that almost universal among truck brands now. Some earlier trucks had it as an option.
