  1. Dec 14, 2024 at 11:44 AM
    #8041
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Something like that, you could also use a bit of JB weld on the backside so you can't see it.
  2. Dec 14, 2024 at 11:48 AM
    #8042
    bailey bulldog
    bailey bulldog New Member
    You could use a plastic welder on the backside.
    SoCal_Erik and cartage1 like this.
  3. Dec 14, 2024 at 12:29 PM
    #8043
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Got some door lights today, no big deal, but better than what was on there from factory.20241214_132150.jpg
  4. Dec 14, 2024 at 1:25 PM
    #8044
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    This truck wins. Well done
  5. Dec 14, 2024 at 2:53 PM
    #8045
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    NICE! :thumbsup:
    Great minds and all that.
    Also can see the additional blue footwell lighting I added.
  6. Dec 14, 2024 at 5:15 PM
    #8046
    lapoolboy
    lapoolboy New Member
    Which TRD Off-Road light is that exactly if you don't mind?
    cartage1 and SoCal_Erik like this.
  7. Dec 14, 2024 at 5:46 PM
    #8047
    BlackNBlu
    Rich
    MN
    https://www.mvpautosupplies.com/
    is the website for the manufacturer, but I got them from Etsy, where the seller name is MVPCUSTOMSshop.
    That's assuming my Etsy versions aren't knockoffs, which is possible.
  8. Dec 14, 2024 at 7:11 PM
    #8048
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4
    Yup, ans some of you mentioned, I’ll probably use JB Weld on the backside. It’s a fine hairline when pieced together, so shouldn’t be noticeable . I’d hate to exchange it at this point.
    BlackNBlu[QUOTED] likes this.
  9. Dec 14, 2024 at 7:20 PM
    #8049
    Hye_Tundra
    Hye_Tundra Fortune Favors The Bold
    LEV
    Los Angeles, CA
    25’ CSM Limited TRD OR
    All-Pro tailgate panel. Good quality for the price. No more destroyed knees.
    ChiefG, buzzkill42, Siopao and 5 others like this.
  10. Dec 14, 2024 at 8:11 PM
    #8050
    Eznk1
    Eznk1 New Member
    Tony
    2024 Tundra
    I added the OEM dashcam and seatjackers from Desert Does It. I opted to only go with the 3/4” lift on the seatjackers but it makes a world of difference in seat comfort.
    I also pulled out my Bedrug XLT and swapped it for the full Bedrug. It was a wash from a functionality standpoint but I prefer the more finished look.
  11. Dec 14, 2024 at 8:30 PM
    #8051
    Itsbui
    Itsbui New Member
    I installed Tufskin rear tailgate tundra overlay,
    Trd overlay for front grill and door sill overlay
  12. Dec 15, 2024 at 10:11 AM
    #8052
    Raven67
    Kentucky
    Installed 1/2" cornfed rear spacers today to give it just a tad bit of rake.
    The 1.75 front level made it perfectly level front & rear. (About 1/4" higher in rear). So I added the 1/2" spacer, now it's perfect.
    BlackNBlu and jachal like this.
  13. Dec 15, 2024 at 12:37 PM
    #8053
    egreen91
    egreen91 New Member
    Ethan
    2024 tundra sr5
    3 in Eibach lift on 35s
    Did you have the physical metal key inside? I bought my 24 with 5k miles and they don’t have the metal insert key for the second fob and said I should have got it when I bought the truck used
  14. Dec 15, 2024 at 1:35 PM
    #8054
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    So, are these used lots possibly keeping the second key to give to the bank. You know for those repo days !!!!
  15. Dec 15, 2024 at 1:53 PM
    #8055
    Cmaccullen
    Cmaccullen New Member
    2022 Tundra Limited
    I bought my 2022 tundra used from a dealer. No second key. I called my local Toyota to see if by chance my vin had a second key issued already. He never really answered me but did tell me it would be $400 for another fob and key.
  16. Dec 15, 2024 at 7:09 PM
    #8056
    lapoolboy
    Thanks! Just ordered.
  17. Dec 16, 2024 at 5:49 AM
    #8057
    BabyMoose
    BabyMoose New Member
    2023 Tundra Limited TRD Off-Road
    CBI bed rack, Decked storage, OVS Nomadic 2 RTT, Ironman DeltaWing 270
    Made a few more mods.
    4Runner "Raptor" lights modified for the TRD OR grill
    1.25 Wheel spacers until I get new wheels and tires
    NYTOP exhaust dump
    This one took the most time. I wanted to mount my fridge slide and tilt but didn't want to drill into the Deckd box. I fabricated the robust bracket from a 1/4" flat bar, angle iron, and 3/4" square tube. It's attached to a 3/4" plywood sheet coated in a rattle can bed liner. I can take it out in a few minutes to have the full bed when needed. I may need to reinforce the passenger side rear corner as the plywood wants to flex when fully tilted, but it is good for now while I put it through its paces.
    Mr Rick, BlackNBlu and MAC25Tundra like this.
  18. Dec 16, 2024 at 5:57 AM
    #8058
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    How was the NYTOP dump tip install? Mine arrived this weekend and it’s on my growing list of things to do on my new Tundra. Any change in exhaust sound? TIA
  19. Dec 16, 2024 at 6:06 AM
    #8059
    BabyMoose
    It was pretty easy. Prepare to cut the factory part in half where it goes over the axle if you are lazy and don't want to jack the back end up :) A little louder and more aggressive on cold start. A little "rumble" or drone in cab but not in an annoying way. Sounds better to me but not a huge change, which I am glad for.
    MAC25Tundra[QUOTED] likes this.
  20. Dec 16, 2024 at 9:11 AM
    #8060
    SoCal_Erik
    2023 SR5 Sport 4x4
    Received store credit towards the purchase of a new one and get to keep this one. If anyone is interested let me know.
    thomez and cartage1 like this.
  21. Dec 16, 2024 at 9:59 AM
    #8061
    euroshowoff
    euroshowoff New Member
    Ronnie
    2024 Limited
    i've got the nytop axle dump waiting to go on when the weather clears, how was removing the oem axle back? did you have to jack up the drivers side, or just lower the spare? thanks.
  22. Dec 16, 2024 at 11:04 AM
    #8062
    lapoolboy
    So, are you selling or giving away the damaged one they gave you full credit for?
  23. Dec 16, 2024 at 11:50 AM
    #8063
    Alpha Six Sigma
    Alpha Six Sigma New Member
    2023 Tundra TRD Pro
    2023 Tundra TRD Pro Hybrid Ext: black int: Red Still has TRD Pro Fox suspension Current Truck Height to the Fin: 85 Inches (7’1”) Additions: Leveling kit Tri-flip tonneau cover Go-Rhino RB20 Slim Side Step Rails 37” Mickey Thompson Baja Boss M/T Tires RRW 17” RR7-H Matte Bronze Wheels Dark Ceramic Window Tint Wallet Friendly Add-Ons: K&N Air Filter ProLong Engine Treatment Lusso Gear Pet Seat Cover Reese Trailer hitch Haimont Waterproof gear bag Rhino Ratchet Straps AJT Keyfob Upgrade Additions Coming Soon: Die hard Platinum AGM battery Bronze Front logo decals Matte infotainment screen protector Cup holder dividers DeYoung Gun Magnets Matte Black Steering wheel emblem JDMCAR Center console organizer JDMCAR Non-slip Cup holder door liners Possible; OD Green Full Wrap
    Just threw on the Go-Rhino RB20 Slim side step rails. I really did not want rails to take away from the overall truck, but be super functional. So far, I am super happy with them and the look.
  24. Dec 16, 2024 at 11:52 AM
    #8064
    BabyMoose
    I'f I had lowered the spare I wouldn't have had to cut. but I didn't wanna mess with a jack or the spare so once it was loose, I cut it near the big bend with an angle grinder.
  25. Dec 16, 2024 at 11:55 AM
    #8065
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    I think you succeeded in your mission - looks great on your truck. Those tires look mean, what are they?
  26. Dec 16, 2024 at 11:58 AM
    #8066
    Alpha Six Sigma
    2023 Tundra TRD Pro
    Thanks! Tires are 37" Mikey Thompson Baja Boss M/T with RRW 17" wheels.
  27. Dec 16, 2024 at 12:33 PM
    #8067
    SoCal_Erik
    2023 SR5 Sport 4x4
    probably sell it for a bill plus shipping. Will post when the next one comes in. This way we all save.
  28. Dec 16, 2024 at 12:55 PM
    #8068
    lapoolboy
    Uh oh. We've seen this before with a guy trying to sell some MESO lights (I think?) that were defective and replaced by the company and it wasn't pretty. Most guys don't think it is very ethical to sell parts you didn't pay for.
    Raven67, GoHuskers and JollyTeraPro like this.
  29. Dec 16, 2024 at 12:56 PM
    #8069
    SoCal_Erik
    2023 SR5 Sport 4x4
    I appreciate your opinion. And you seem to have many of those around here.
    but when a company says keep it and do what you want with it, I will.
    Im not going to start a back and forth with you. You asked me a question and I responded. Good day!
  30. Dec 16, 2024 at 1:03 PM
    #8070
    lapoolboy
    You are correct, everyone here, myself included, has opinions. There's no back-and-forth needed. *IMO* (there it is again!), it's a douchebag move to sell a damaged item you received for free in order to offset the cost you originally and willingly paid for it. The company did right by you....why not pay if forward and GIVE the thing to someone?
    Siopao and SoCal_Erik[QUOTED] like this.
