General Supercharger Thread
  1. Dec 13, 2024 at 9:41 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Yeah, that's what I was thinking; even if it's only for a brief period. Soon as we got into the neighborhood and leveled out, temps dropped quickly, but still... :facepalm:
    I can't imagine that's doing anything good for the truck.
    ARES35 and Mdl like this.
  2. Dec 13, 2024 at 9:53 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The cold fault shifting program holds the shifts a little longer to get it up to temp.
  3. Dec 13, 2024 at 9:54 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Pinning the thermostat I thought was stupid until I did it. The trans takes the same amount of time as normal to warm up, and on my truck dropped the temps 20+ degrees the rest of the time. At least that would put your temps into manageable albeit still hot realm. If I see over 220 I start freaking out and planning what to do if it keeps climbing.
  4. Dec 13, 2024 at 10:11 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    @snivilous Still recommend it in places that hit single digit temps?
  5. Dec 13, 2024 at 10:45 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    There are places that hit those low temps, below 20 or so that need it unpinned. I only data logged my temps in the 20's.
    ARES35 likes this.
  6. Dec 13, 2024 at 11:16 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    You know you want the extreme :cool:
    Mdl likes this.
  7. Dec 14, 2024 at 2:22 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Please get the cooler.
    I ran 230's in Houston without it. unladen, hwy cruise
    installed mine at ~20k miles, right before I installed the S/C.
    now I run pinned and it tops out at ~170.
    as others have said - it warms up just as fast.
    Last summer - sitting in Houston traffic I touched a max of 185.
    FTR - cooler fluid does NOT affect mileage.
  8. Dec 14, 2024 at 3:53 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I saw that one too and was going to share! It basically confirms for me that “too cool” really isn’t a thing, and I plan to keep mine as cool as possible from here on out. Happy to have seen that as I was just thinking about unpinning it for winter, not anymore. Also notice what kills the rubber seals is not just heat but the temp difference of them getting hot and then cooling back down. The less often you let the fluid get to 200+ and then cool back down over and over again the better off they will be. With it pinned in winter it will likely stay under 170 not towing for me.
    As much as a don’t want the rough shifting, the extreme is basically explicitly made for high horsepower vehicles so I think the choice is clear. The price is the same at least. And the price is fair enough assuming no other duties/taxes that I may not even bother sending the core back to Australia if I did it.
  9. Dec 14, 2024 at 4:09 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I added the OEM cooler almost immediately and left the thermostat pinned. In the summer when it's 120+, I never see above 208. It's been in the 40s- 70s lately; it's at 145-170.
  10. Dec 14, 2024 at 6:34 AM
    Silver17
    Eastern PA
  11. Dec 14, 2024 at 7:03 AM
    snivilous
    SW UT
    I don't unpin it when I drive to my parents that live in a similar location to you. I would still try it and watch the temps and see what it does. It's surprising how fast they warm up with it always pinned so I wouldn't worry, but if the temps stay too cool it's 10 seconds to pull the pin.
  12. Dec 14, 2024 at 7:09 AM
    helidave
    flagstaff
    2015 DC 4x4
    Cool, I'll give it a shot. Taking forever to warm up was my main concern
  13. Dec 14, 2024 at 7:40 AM
    ARES35
    ARES35 New member for life
    Mile high
  14. Dec 14, 2024 at 7:48 AM
    ARES35
    Mile high
    It seems anyway to keep the trans cooler is the ticket. I missed the memo back in the day. 35s, stock gears, pulling campers over 12k passes.....not no mo. At minimum this round will be 5.29 gears, VB, pinned trans thermo and taking a bit easier in the hills. Live and you learn Lol
  15. Dec 14, 2024 at 8:28 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I wonder how often it gets that high? I guess that 500PSI sensor I ordered isn't going to cut it
    ARES35[QUOTED] and Mdl like this.
  16. Dec 14, 2024 at 8:42 AM
    pursuit2550
    pursuit2550 New Member
    To this day I still laugh at people who say engineers know best. No, the penny pinchers know best and squeeze every profit they can as long as the truck makes it to 5/60k warranty period. I run pinned, normal everyday driving its never about 160* round about. Thanksgiving weekend, I went up north, temp was around 36, trans never got over 130*. Went I would get on it, it would jump to around 140 and quickly come back down. I am on the side of, trans have soft parts, not everything is metal for the most part, so keeping it cool is best.
  17. Dec 14, 2024 at 8:47 AM
    blenton
    blenton New Member
    That’s the hydrostatic drive pressure (think how an enginedyno loads a motor to determine brake horse power) not the line pressure in the transmission. I think the 500psi unit should be safe.
  18. Dec 14, 2024 at 8:47 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    This was posted a while back in the transmission cooler threads.
    Edit for @helidave :p
    80c=176f, 90=194, 105=221, 115=239, 125=257, 145=293, 155=311
  19. Dec 14, 2024 at 8:50 AM
    helidave
    flagstaff
    2015 DC 4x4
    Can somebody convert that to freedom units?
  20. Dec 14, 2024 at 8:56 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Right on
    In that transmission thread
    the resident transmission engineer mafia jumped my shit when I told them I ran pinned
    some bullshit about it will run too cold
    GTFOH
  21. Dec 14, 2024 at 8:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    100C = 212F
    ARES35 likes this.
  22. Dec 14, 2024 at 8:59 AM
    koditten
    Kirk
    Midland of the Mitten
    Doing the math in my head.
    250 is 155c
    80 is 175f
    ARES35 likes this.
  23. Dec 14, 2024 at 9:10 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Toyota wants it to run hot for the proper viscosity...nope!
  24. Dec 14, 2024 at 9:19 AM
    Silver17
    Eastern PA
    Don’t forget the “sealed, lifetime fluid” transmissions. o_O
  25. Dec 14, 2024 at 9:21 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Fixed it :rolleyes:
  26. Dec 14, 2024 at 9:25 AM
    ARES35
    Mile high
    Never. Impressive that extreme build can handle that for any amount time they're doing something right.
    armyoffoo[QUOTED] likes this.
  27. Dec 14, 2024 at 9:26 AM
    helidave
    flagstaff
    2015 DC 4x4
    :oldglory:
    Tripleconpanna and ARES35 like this.
  28. Dec 14, 2024 at 9:30 AM
    ARES35
    Mile high
    Any of these guys forced induction? Do they also run larger tires? Do they tow up mountain passes? Stock form yeah unpinned makes sense. Forced fed it's a different story it seems.
  29. Dec 14, 2024 at 9:33 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That statement is too much from Toyota.
    I believe the WS fluid was designed for best longevity under 200 can withstand to 300deg. I've been shooting for anything under 190 deg.
  30. Dec 14, 2024 at 9:33 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I also bet like the 0w20 oil mileage and emissions crap is factor to why they want hotter
