Breather line location guide
Discussion in 'General Tundra Discussion' started by Sumo91, May 3, 2022.
  1. May 3, 2022 at 5:08 PM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Hey guys, I wanted to share some info I thought might be useful, everything I searched for this topic isn't as definitive this post will be. Hopefully this will help someone in the future.
    There are a total of 4 breather lines in the engine bay. 2 of them are located underneath the brake booster, these are the most common ones you'll see in threads and posts. The breather located towards the front of the truck is for the front differential, the one behind that is for the A.D.D - Automatic Differential Disconnect. Both of these breathers are expansion breathers. Meaning they allow air too escape as temperatures rise and air expands, but don't allow air or liquids to enter. This is accomplished with a spring and round rubber gasket located inside the cap. 20220503_155342.jpg 20220503_154331.jpg
    The other breathers are located behind the engine, they're kinda hard to see, but they do exist! The driver side breather is for the transfer case. It is also an expansion breather. The passenger side breather is for the transmission, it's a 2 way breather, and has no seals or springs. It's made of 2 plastic pieces, the body and the cap. The cap snaps onto the body and has a fair amount of play. There is absolutely nothing that can prevent dust and contaminates from entering this, so ill be posting my solution later. I'm still sourcing my parts. (The hole is so small it's probably not worth worrying about, don't freak out! I'm just going the extra mile)
    HeavyWasher, Humbug, ChiefG and 3 others like this.
  2. May 13, 2022 at 6:14 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    The driver and passenger transfer case and trans breather locations are where? Can you show a approximate location of which are would we find those?
    I know you say located behind engine but around where. Perhaps a generic engine pic with circled location would be great.
    Great info Btw.
    Sumo91[OP] likes this.
  3. May 13, 2022 at 6:25 AM
    Sumo91
    TN
    I used a Google generated engine bay pic for this and added an arrow. Look underneath the arrow. If you have large hands it's gonna be incredibly hard to get to. I had to lay down on my stomach across the engine bay to reach them. And it when removing them from the bracket It was all by feel, I wasn't able to see what I was doing. An inspection mirror would probably help you locate them pretty easily
    bulldog93 likes this.
  4. May 13, 2022 at 2:47 PM
    baraynavab
    Atlanta
    Ooh wait a min.. thats looks like the 4.7l Engine... I have the 5.7l.
  5. May 13, 2022 at 5:50 PM
    Sumo91
    TN
    It's just a general idea (I have the 5.7). Passenger side of the intake manifold. You'll have to look hard for it. It's not easy to spot. You gotta remove your engine cover.
    Grillojay likes this.
  6. May 30, 2023 at 1:18 PM
    Grillojay
    Grillojay New Member
    Sumo91
    Do you happen to have the part number for the transfer case breather? I found the plastic one, but cannot find the other one you replaced.
  7. Jun 20, 2023 at 2:09 PM
    Sunnier
    Sunny
    San Diego, CA
    @Sumo91
    I just noticed Grillojay tried tagging but forgot or didn't know to use the "@" symbol in front of your forum name.
  8. Dec 11, 2024 at 3:34 PM
    dlvonde
    dlvonde New Member
    Daniel
    07 Tundar SR5 Base Model - Non JBL Sound System
    I know this is an old thread but..does anyone have a more accurate depiction of where this automatic transmission breather is? I looked where the arrow is pointing in the picture above and I can't even get my head wedged between the hood and the back of the engine to even see this area...looking with a flashlight from the side on the passenger side I also don't see anything...I tried just blindly sticking my hand behind the engine bay (which seems to have a LOT less room between the back of the engine and the firewall than what the pictures above show) and I'm not feeling anything remotely like these 2 breathers :confused:.
    UPDATE: ahhh crap I just saw you have to remove the engine cover which looks like a whole bunch of crap to unbolt....
    I did an ATF drain and fill on an 07 Tundra 4.7L today and when I went to open the overfill air came blasting out along with the ATF so apparently I REALLY need to find this breather and clean or replace it before bad stuff happens...
