Outside Mirrors
Discussion in 'Sequoia 1st Gen (2001-2007)' started by mercury3298, Dec 6, 2024.
  1. Dec 6, 2024 at 6:58 AM
    mercury3298
    mercury3298 [OP] New Member
    Greg
    2005 Toyota Sequoia
    none
    My orginal outside mirrors took a nose dive and I replace them with a pair that are a 5 pin and the vehicle side is a 11 pin and I was wondering if anyone knows what wire goes to what wire. The vehicle is a limited edition Sequoia with folding, heated, and memory and remote adjustable capability. If anyone has a clue what wire goes to what color wire I would greatly appreciate it. I can provide pics if necessary.
    Thank you,
    Greg R.
  2. Dec 6, 2024 at 7:53 AM
    RobertD
    Robert
    DFW, Texas
  3. Dec 7, 2024 at 10:54 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Didn't see this thread until after I just replied to your PM. Going to copy that info here because it might help someone else in the future.
    My diagrams don't show the 2005 Sequoia to have an 11-pin connector for the side mirrors, but rather either a 16-pin connector (vehicles with driver position memory), 8-pin connector (no driver position memory, but power folding mirrors), or 6-pin connector (no driver position memory or power fold).
    Below are images for the RH (passenger) mirror connector - the driver side looks the same.
    Based on your description above, it sounds like you should have the left version of connector R18 on your vehicle (R17 is the driver's side and is the same connector). And I'm guessing you have mirrors that have the right version of the connector.
    The mirrors you bought will not power fold and will not correctly react to the memory position location.
  4. Dec 10, 2024 at 7:18 AM
    mercury3298
    Greg
    2005 Toyota Sequoia
    none
    It is a (R18-1) and the new mirror is a (R18-6) with only 5 wires I don't care about memory but I would like at least to adjust them to my liking, heat, and if possible fold. The connector on the new mirrors have 2 black wires one with a grey dot on it. Then we have a yellow, blue, and green wire. If you could tell me what wire goes to what I would greatly appreciate it. I can give you the color of the R18 wires if that will help.
  5. Dec 10, 2024 at 9:29 AM
    RainMan_PNW
    Casey
    Clark County, WA
    you will not have power fold in the new mirrors at all. They lack the physical motor inside of them to do so.
    As for colors of the wiring inside the mirror, nothing I can do about that - they don't show that information in the diagrams. But I can tell you which pin number is which function on the connectors shown. You will need to do the mental acrobatics to understand and apply that pin-out to the mating connector in the mirror. All of the pin information is looking at the open end of the connector (opposite of the end the wires are entering) with it oriented so the locking tab is positioned according to the image.
    Your original/factory mirrors (using the RH mirror for example - the COLORS may be different on the driver's side but the pin-outs are the same):
    Mirror wiring
    Mirror heater wiring (denoted by the (A) notes)
    Pin-out:
    The mirrors you bought (denoted by (B) in the notes):
    Mirror heater wiring (denoted by the (C) notes)
    Pinout:
    RobertD likes this.
  6. Aug 8, 2025 at 3:43 PM
    socialgosling
    socialgosling New Member
    Los Angeles, California
    2005 Sequioa LTD.
    Hello, I was wondering if you have the Pinout for connector R18-5? Cant seem to find it anywhere.
  7. Aug 8, 2025 at 7:38 PM
    RainMan_PNW
    Casey
    Clark County, WA
    fairly certain it's an empty spot in the connector - nothing in it.
