  1. Dec 10, 2024 at 7:32 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    If a shop is putting them in, they should know which ones to use that are compatible with the truck (if they're aftermarket sensors). And they then have to program the truck to accept the IDs of the new sensors. Or, you can do it yourself with an Autel scanning/programming tool. (I have an Autel TS508WS & use it regularly doing a 5-tire rotation - don't keep the spare on board bc it's big.)
    If they turned you away bc Tundras "won't register it after replacement," they're morons. Don't go back to them. They should know how to program them.
    Henry1jg, Tripleconpanna and MatD13 like this.
  2. Dec 10, 2024 at 7:36 AM
    The 2020 and newer doesn't like most aftermarket sensors but it sounds like that shop doesn't know what they are doing regardless.
    MatD13[QUOTED] likes this.
  3. Dec 10, 2024 at 7:38 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Truck is off for at least 15 minutes. Key in position II (no engine started yet), press TPMS reset button located by right knee 3 times within 3 seconds. It will say "TPMS recalibration". Drive for 10-30 minutes at moderate speed, making a few left and right turns.
  4. Dec 10, 2024 at 7:39 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Any sensor working at 315 MHz frequency will work. IIRC 315.
    1UP[QUOTED] likes this.
  5. Dec 10, 2024 at 7:40 AM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    Are you saying doing that picked up your new sensors?
    Tripleconpanna likes this.
  6. Dec 10, 2024 at 7:41 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yes. The key is to see that recalibration message. And park for at least 15 minutes before driving to relearn IDs. You may need to erase error codes in TPMS module first. Battery disconnect will clear them as well.
  7. Dec 10, 2024 at 7:44 AM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    That actually kinda pisses me off. I wasted a couple hundred on this Autel tool a few years ago and have been dicking around with it ever since to reprogram after every tire rotation.
    vtl[QUOTED] likes this.
  8. Dec 10, 2024 at 7:51 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I was one step away from buying it. Forcing the truck into ID learn mode was not straightforward at all. The official procedure is rather long and it mentions weird things, like driving at 37 km/h (eh?) and avoiding backing up (eh?).
    What I did precisely:
    - found which sensor is bad with OBD Fusion + paid Toyota block. The bad one read very incorrect pressure and temperature
    - replaced the sensor with Toyota OE
    - erased TPMS codes with OBD Fusion, just TPMS. Erasing all codes will throw OBD monitor readiness out of window, and I'm long due for MA yearly inspection
    - key in position 0 then II
    - pressed TPMS reset button 3 times within 3 seconds, the tire pressure light blinked 3 times, the display showed the recalibration message
    - turned off truck, waited for 15 minutes (overnight, actually)
    - drove for about 10 minutes, the light disappeared, tire pressures were still dashes, but they went away in another 2-3 minutes
    Done.
  9. Dec 10, 2024 at 7:53 AM
    Tundra family
    Tundra family New Member
    I needed this, gonna give it a shot right now. :thumbsup:
    Sleeper16plat likes this.
  10. Dec 10, 2024 at 7:53 AM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    Awesome - thanks for the info. Not sure it'll work for my '16 (diff tpms system - mine doesn't show individual tire pressures) - but I'll give it a shot.
  11. Dec 10, 2024 at 8:01 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    The basic principle is the same: TPMS module reads individual TPMS sensors in each wheel. It may not display the individual pressure, but interacting with the sensors is the same like in every other TPMS-equipped vehicle.
    Uhhhh....[QUOTED] likes this.
  12. Dec 10, 2024 at 8:06 AM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    Thanks man
  13. Dec 10, 2024 at 10:13 AM
    danb
    danb New Member
    Minnesota
    2018 Tundra DC Looooooong bed
    Getting my new to me 2018 SR longbed in midnight black to look less like grandpa's truck.
    Had ceramic tint installed on all 4 windows and the rear glass. Ordered GTR ultra reverse bulbs, stock reverse lights are ass, especially with the new tint. I back my truck down my 100 yard driveway and its difficult to stay on path at night unless I'm driving ace ventura style with my head out with the window. Hit everything under the truck with fluid film. Installed a fumoto valve. Installed the intermittent wiper stalk.
    Buddy hooked me up with 17inch Method 316s with 25mm offset black for a couple hundred less than the cheapest I could find online. Ordered the correct lugs from Method.
    Now I'm in analysis paralysis on which tires to throw on. Probably going to go with Defender LTX MS2s in 285/70 17, but keep looking at Open Country ATIIIs and Wildpeak AT4Ws. I don't do any hardcore off roading, but deal with a lot of snow and mud being in Minnesota. Use the truck to haul motorcycles, throwing logs and branches in bed from clearing property, and hauling my 2200 pound boat. I like the aggressive look of all terrains, but dont think I will be able to justify them since I have a lot of road trips planned this summer. Losing any mpgs on the stock 28 gallon tank would suck. My work truck has defenders and I drive a lot off road with them and haven't had any issues besides a couple punctures from nails.
    Future plans are to throw in a better headunit for carplay, throw on better running boards, install fog lights and low profile light bar, and throw on a larger fuel tank since I hate having a 280 mile range.
    Henry1jg and BR73 like this.
  14. Dec 10, 2024 at 10:21 AM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    The surrounding trim pops off easily with a trim removal tool. I used a leather boot that was referenced somewhere here on the forums. I can’t remember the details unfortunately. But it looks good, at least to me!
  15. Dec 10, 2024 at 10:23 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    10k more and it’ll finally be broken in.
  16. Dec 10, 2024 at 10:26 AM
    SAGE63
    San Diego County
    Same for me I run 2 spares both with tpms and do 6 tire rotations.
  17. Dec 10, 2024 at 10:29 AM
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    Damn, that’s the frequency replacement I had bought through Discount too… Had it refunded this morning
    I may just try and do it again and say I’ll re calibrate it myself either through your procedure or buying that scanner through Amazon. I hate going to the dealership
  18. Dec 10, 2024 at 10:32 AM
    Tundra family
    Guess I need a knob? Something stupid like this is right up my alley. :rofl:
    Asimov2025, Florida AF and BR73 like this.
  19. Dec 10, 2024 at 10:40 AM
    I'm still irritated that the 21 will show 5 on the display but the 20 won't.
  20. Dec 10, 2024 at 11:56 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Got some packages in the mail last couple days....
    Raceline wheels and some coachbuilder bumper shims so the lower offset wheels will fit!
  21. Dec 10, 2024 at 3:07 PM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    I'm working out of a 2 car garage. But only able to use 3/4 of 1 car side.
  22. Dec 10, 2024 at 8:13 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Had our Tundra club annual toy drive. Always a good deal.
  23. Dec 11, 2024 at 3:24 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    General Grabber A/TX has the largest side knobs in class that aid with navigating deep snow and some mud. They come in P-rating, too (to save fuel). But I would get LT for "set it and forget". On long trips tire weight does not matter much if you manage to keep torque converter locked. I'm on my second set now.
    But if you manage to do everything on Defenders then your snow is perhaps not that deep =) Stick with them for fuel efficiency.
    TacomaTRD4x402 likes this.
  24. Dec 11, 2024 at 3:36 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    PXL_20241204_214113937.jpgHere's my setup with a boot from Redline and new knob
  25. Dec 11, 2024 at 3:44 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Running the Grabbers A/TX on my Taco and love em. I'll probably run the same for my Tundra when I lift it.
    1UP, pvn.beluga, Florida AF and 4 others like this.
  26. Dec 11, 2024 at 3:49 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Good job Tundra Club!!!!:bowdown::muscleflexing:
  27. Dec 11, 2024 at 3:53 AM
    Tundra family
    I really like the carbon fiber look, wish I could find it with more of a matte finish.
    BR73[QUOTED] likes this.
  28. Dec 11, 2024 at 3:53 AM
    Tundra family
    Awesome!!
  29. Dec 11, 2024 at 4:22 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    I may try to dull it with some 0000 steel wool
    BlueRibbon4x4 likes this.
  30. Dec 11, 2024 at 4:26 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    PXL_20241118_131233056.jpgI run Toyo Open Country AT III'S 295/70R 18's
    1UP, Tundra-XP, Beckusmc and 7 others like this.
