General Supercharger Thread
  1. Dec 9, 2024 at 10:27 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I do passenger side, clocked away from the stock upstream sensor. It's easy to reach and mark. You can then unbolt the exhaust from the header and catback and pull it out to weld it on. The O2 bung from Innovate is too long, I cut it down to about half length too.
  2. Dec 9, 2024 at 10:31 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Ohh dang, thought it would be able to be welded on while still on the truck (with one of those safety boxes connected to the battery)
    ARES35 likes this.
  3. Dec 9, 2024 at 10:32 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Passenger side before the cat by the trans cooler brick
    Mdl and NatesNightMare like this.
  4. Dec 9, 2024 at 10:35 AM
    snivilous
    SW UT
    No doubt possible somewhere. The drilling through is the issue more than the welding. Since the exhaust is so easy to pull i like to do that and get a nice finished product. Plenty of people who have had fucked up welds and it leaked air and gave bad readings.
    Mdl, NatesNightMare, ARES35 and 2 others like this.
  5. Dec 9, 2024 at 10:42 AM
    Danimal86
    Daniel
    Sacramento, CA
    manifolds are pretty easy to remove? I just figured that it would be a PITA.
  6. Dec 9, 2024 at 10:44 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    If you live in a rust free area, the hardest part will be unclipping the sensor connectors…
    HulkSmurf14, Mdl and Wynnded like this.
  7. Dec 9, 2024 at 11:10 AM
    Danimal86
    Daniel
    Sacramento, CA
    whats "rust" lol
    yeah, no rust here. In my head i'm imagining myself with being elbow deep from under the truck getting to the manifold bolts.
  8. Dec 9, 2024 at 11:11 AM
    ARES35
    ARES35 New member for life
    Mile high
    Well Toyota dealership is sending a tow to pick up the truck and see if the transmission fluid is proper. Also reached out to a couple transmission specialists in Denver. High country transmissions said they cannot rebuild. They would take out and install whichever transmission i get. Adam with Transmissions wizard out here said he could rebuild with better clutch packs, steel solenoid sleeves and etc. Both said they will install front and rear diff gears, mst kits and rear LSD.......so waiting game until I hear word for now.
  9. Dec 9, 2024 at 11:20 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Parts stock piling continues
    Ctaylor76, Jowett, Wynnded and 7 others like this.
  10. Dec 9, 2024 at 11:23 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    A long extension on the impact or ratchet and they come off quickly.
  11. Dec 9, 2024 at 11:25 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Dropping that downpipe is a 10 minute job if none of the bolts strip or break. One of mine did and it took alot longer :mad:
    Mdl, Silver17, ARES35 and 1 other person like this.
  12. Dec 9, 2024 at 11:32 AM
    ARES35
    Mile high
    I stripped two mani studs and had to die them one size down. It was a bitch.
  13. Dec 9, 2024 at 12:05 PM
    Danimal86
    Daniel
    Sacramento, CA
    You guys are making me nervous
    koditten likes this.
  14. Dec 9, 2024 at 12:06 PM
    helidave
    flagstaff
    2015 DC 4x4
    If you want to increase your odds of success, spray all the exhaust hardware with PB blaster a day or two before you do the work.
    Mdl, NatesNightMare and ARES35 like this.
  15. Dec 9, 2024 at 12:25 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    You should be able to drill and weld a bung on the mid-pipes without dropping them. Here is where I installed my wideband sensors without removing the exhaust, and there is room to weld...which I'll get around to doing one of these days.
    Wynnded, koditten, e30cabrio and 2 others like this.
  16. Dec 9, 2024 at 12:36 PM
    ARES35
    Mile high
    Naw. PB blast cold. Then drive, get engine to temp and crank the stud nuts hot. Use extensions and gloves so you don't burn your shit. Learned after stripping some.
    NatesNightMare likes this.
  17. Dec 9, 2024 at 12:37 PM
    snivilous
    SW UT
    Your trucks not that old, I wouldn't be worried.
    And if a shops doing it who cares :D
    nags, ZPhilip, Wynnded and 4 others like this.
  18. Dec 9, 2024 at 12:38 PM
    Danimal86
    Daniel
    Sacramento, CA
    This is kinda what i imagined doing beforehand. I'll need to figure out if its much of a difference between having it on one of the manifolds vs mid pipe.
  19. Dec 9, 2024 at 12:40 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Anywhere before the first cat will work, my setup is with long tube headers and the collector is further back, so it's probably not a good example for actual location compared to stock exhaust.
  20. Dec 9, 2024 at 12:41 PM
    Danimal86
    Daniel
    Sacramento, CA
    It was going to be: Bring to a shop and point "install it here"
    If installing it on one of the manifolds, i'd probably remove it and bring it to the shop, so i'm not paying stupid labor prices.
    Any reason why not to install it on the midpipe?
  21. Dec 9, 2024 at 12:42 PM
    snivilous
    SW UT
    Cats are meant to burn all the shit up, that's what you're trying to measure is the shit that's not burned up :D
  22. Dec 9, 2024 at 12:42 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    SPD performance sells a mid pipe with a bung lol if you’re already in there…
    nags, Mdl, e30cabrio and 1 other person like this.
  23. Dec 9, 2024 at 1:04 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I love those midpipes, even though I think all they did for me was make my exhaust sound like I always wanted it to, but I just could never get the catback right with having all 4 cats.
    reywcms[QUOTED] likes this.
  24. Dec 9, 2024 at 1:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The wideband should be at least 18-24 inches from the exhaust ports on manifold. Believe AEM is 18 and Innovate 24. Before the primary cat is optimal.
  25. Dec 9, 2024 at 1:16 PM
    Silver17
    Eastern PA
    Little higher miles, but nice SC truck in Oregon.
  26. Dec 9, 2024 at 2:13 PM
    koditten
    Kirk
    Midland of the Mitten
    Yeah, color me skeptical. Too many variables to go sideways.
  27. Dec 9, 2024 at 3:43 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    There’s one thing that keeps me up at night with these deep pans, even the PML that I run (which has some baffles), is that they don’t lower the sump pickup to the bottom of the pan. Just like an engine, all we need is a little air sucked into the pickup to create a momentary drop in pressure and hell could break loose. I mention this only to try and cover all potential points of failure.
    Since we’re talking about it, has anyone ever logged the pressure on the trans for an extended time to see if there are drops during various maneuvers?
    blenton, Wynnded, HulkSmurf14 and 2 others like this.
  28. Dec 9, 2024 at 3:57 PM
    snivilous
    SW UT
    A better question is has anyone figured out how to log anything for the transmission ever :D
    Wynnded, Mdl, koditten and 2 others like this.
  29. Dec 9, 2024 at 4:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    So you’re saying we need a longer sump pickup lol. Not sure what the stock pickup looks like but cut it in half tig weld an extension.
    Wynnded, helidave and snivilous[OP] like this.
  30. Dec 9, 2024 at 4:04 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    It's plastic, part of the filter...might be able to make a tube adapter that it slips into, then some longer bolts and spacers to keep the filter in place.
