General Supercharger Thread
  1. Dec 7, 2024 at 9:06 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I'm pretty sure my fittings will clear with room to spare, but I have the option to move it up another 1/2-1" if needed. Or I could get banjo fittings if it came down to it. I want to keep it between the bottom port on the heat exchanger and the fittings that go on the engine so I can easily drain as much oil as possible.
    e30cabrio and Mdl like this.
  2. Dec 7, 2024 at 10:46 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Flying down the road with 6000lbs drifting side to side can be a bit much. Now if I were flying high in the dunes or in some knarley stuff it'd be gone.
  3. Dec 7, 2024 at 10:53 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Even then ;)
    Mdl[QUOTED], reywcms, Wynnded and 3 others like this.
  4. Dec 7, 2024 at 10:57 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    1 1/4" - 1 5/16" between the the fittings and the sway bar, should be good. I used Earl's AT949010ERL that I was going to use in the heat exchanger, but I have more room there than I thought. Oil is draining now, and then I can swap out the stock oil filter assembly with the one from the models without the tow package.
    Mdl and e30cabrio like this.
  5. Dec 7, 2024 at 11:11 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    not tryin to drift a 6000lb truck lol but ive done some decent speeds off road with some whoops and it was pretty damn smooth other than that it would be crawling. i like full flex over limited. makes me wish i could afford a mid or long travel and still keep the lift height
    Mdl[QUOTED] likes this.
  6. Dec 7, 2024 at 11:11 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Any fool-proof way to clean a oil heat exchanger core out? I ran water through it for a while and blew it out with compressed air, but I just wanted to be sure before I trust it with my oil.
    Mdl likes this.
  7. Dec 7, 2024 at 11:21 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I would think it would be good to use a gentle solvent like mineral spirits or even gasoline and let it soak in there. Then rinse with hot water and dry with low pressure compressed air or something.
  8. Dec 7, 2024 at 3:06 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    @snivilous
    I spend a few minutes digesting this, at least the TRD tune portion as I've largely left my trans tune alone (except lockup) I overlaid the line pressure limits over your screenshot and wanted to talk out loud to see if I'm understanding what you guys are?
    1. PCS Line Pressure limit is increased ~21%, then from the base line pressures, it appears those tables for gear 1 and gear 2 modify those pressure limits and reduce the pressure over 34% throttle position?
    Assumption, increasing pressure thru lower throttle % should in theory keep heat down, but then it reduces pressure a bit near WOT to "back off" and take it a little easier on the trans. Thoughts?
    2. PCS Line Min and PCS TCC Min are both substantially increased. Unsure if this is again to keep heat down at the potential cost of loss of "rubber band" drivability?
    3. PCS SL2 Brake Max is reduced to almost nothing. Unsure exactly what the SL2 solenoid controls but appears to be engine braking lockup pressure, wouldn't this reduce potential for engine braking and go into a coast situation on decel?
    Any comments or thoughts from anyone?
    ARES35, Wynnded and e30cabrio like this.
  9. Dec 7, 2024 at 4:24 PM
    ARES35
    ARES35 New member for life
    Mile high
    Well gents looks Iike another tranny/torque converter bites the dust. Had some pretty good rpm flare ups today. Decided to go around the neighborhood where its less busy and test for it was happening in 2nd-3rd gear. Got on it and bam, lost all gears, no acceleration. Barely made it home and had to coast back. Hoping the converter is just toast:sadviolin:
    P.S
    Just had tranny fluid serviced on Monday. No codes.
  10. Dec 7, 2024 at 4:31 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sorry that sucks.
    ARES35 likes this.
  11. Dec 7, 2024 at 4:33 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    We need a "dislike" button in this thread for all the bricks and burnt up transmissions
    ZPhilip, e30cabrio, Silver17 and 4 others like this.
  12. Dec 7, 2024 at 4:46 PM
    NatesNightMare
    Pinetop Az
    it def make me not want to push it any further than what ive already got on lol
    ARES35 and Mdl like this.
  13. Dec 7, 2024 at 4:56 PM
    Silver17
    Eastern PA
    This is suspicious to me, but guess it could be coincidence. Show of hands, who has had transmission problems that has vs. has not modified transmission tuning parameters? I only have 23k on mine since boosting, 71k on the truck. Lots of towing, knock on wood no trans issues yet. Stock trans tune. These failures have me not wanting to get on the throttle too hard until I at least do a VB upgrade. This AB60 transmission we are stuck with really pees in the boost cheerios.
  14. Dec 7, 2024 at 4:56 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Sounds like mine lol no foward gears but slow crawl and only reverse
    ARES35[QUOTED] and Mdl like this.
  15. Dec 7, 2024 at 5:03 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    ARES35 likes this.
  16. Dec 7, 2024 at 5:03 PM
    ARES35
    Mile high
    Yes sir I have reverse! Lol. Put it in gear, feel the tranny engage and then nothing. Trying to get it in my garage may have to push her in haha
    reywcms[QUOTED] likes this.
  17. Dec 7, 2024 at 5:05 PM
    ARES35
    Mile high
    I'm running TRD tables. I'm one of the unlucky ones, only 3 tables to modify.
    reywcms and Silver17[QUOTED] like this.
  18. Dec 7, 2024 at 5:15 PM
    snivilous
    SW UT
    I'll have to look into it, but I think the values for the tune I showed arent displaying correctly (common on the 19-21). The values you overlaid look correct, and those values aren't modified, so if they're different something is wrong.
    On the 19-21 the solenoid curves are literal gibberish, that's why I think those values are also and I just didn't notice since I've never tried to change them anyway since the TRD tune doesn't change them.
    e30cabrio, reywcms and Wynnded like this.
  19. Dec 7, 2024 at 5:16 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sorry to hear, @ARES35.
    I was running a mostly TRD transmission tune, but I was experimenting with 3,4,5,6 L/U and giving it a really hard time. My symptoms were the same, forward gears were like trying to drag race on ice but reverse was fine.
    Mdl, Silver17 and ARES35 like this.
  20. Dec 7, 2024 at 5:22 PM
    snivilous
    SW UT
    When my trans went boom it was 5th and 6th that were hosed, 1-4 were kind of sorta functional (albeit still fucked). If it shifted into 5th it was stuck in 5th until the truck restarted, and 6th was extinct. That was somehow a result of using the lower gears really hard with continuous WOT on the beach.
    e30cabrio, reywcms, Silver17 and 2 others like this.
  21. Dec 7, 2024 at 5:30 PM
    ARES35
    Mile high
    On my little drive all was good until I slowed to 2nd gear. Gunned it, rpms slipped to 4k released throttle and lost all gears but reverse.
    snivilous[QUOTED][OP] likes this.
  22. Dec 7, 2024 at 5:32 PM
    Silver17
    Eastern PA
    @ARES35 which shit sandwich are you gonna choose now? IPT, Level 10, Australian Cruiser Brothers, new OEM, or junkyard used?
    nags, snivilous[OP] and ARES35 like this.
  23. Dec 7, 2024 at 5:35 PM
    ARES35
    Mile high
    Probably go built so issues never happen again, in theory. Sucks that all the performance tranny shops are extremely far from Colorado though:facepalm:
    Silver17[QUOTED] likes this.
  24. Dec 7, 2024 at 5:53 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    After much thinking I’m probably going to throw in a new oem unit. Then work on an 8speed or other trans solution. I don’t love the ipt/level10 options of reliability etc
  25. Dec 7, 2024 at 5:58 PM
    ARES35
    Mile high
    Do the L10 and IPT have reliability issues? Other trans solution would be idea.
  26. Dec 7, 2024 at 6:02 PM
    Silver17
    Eastern PA
    Probably smart, I might also spring for an IPT valve body if it were mine and I were in your shoes. If you’re going built engine you pretty much have to come up with some other more robust option like the others mentioned in the 6.0 stroker thread. I don’t think there is any AB60 build up to the task. It’s the biggest let down of boosting these trucks IMO.
    Mdl and reywcms[QUOTED] like this.
  27. Dec 7, 2024 at 6:13 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    The valve body isn’t a weak point from what I’ve heard and John only adds a sleeve to the shift solenoid slots. Nothing ground breaking there from my conversation with him. But I’ll give him another call to see what’s up
    nags, Mdl and ARES35 like this.
  28. Dec 7, 2024 at 6:22 PM
    ARES35
    Mile high
    Whats the consensus on these blown transmissions? Extremely worn clutch plates, valve body solenoids, TC, combo? Mine feels like the torque convertor completely failed but just a guess.
  29. Dec 7, 2024 at 6:23 PM
    snivilous
    SW UT
    To follow up, a normal tune (TRD file from my truck):
    The funky tune I posted:
    SL1 Clutch Pressure curve on my TRD tune:
    Same curve on the funky tune:
    On the 19-21 that are funky I just change the Base Line Pressure values (the ones highlighted in green before), everything below that should be ignored on those newer trucks since HP Tuners has issues reading/adjusting the data (as evidenced by the gibberish).
    Wynnded likes this.
  30. Dec 7, 2024 at 6:31 PM
    VWTim
    Corvallis, OR
    Interesting, pressure limits are identical to my stock '07 trans tune as is SL1 curve. Then the only differences so far are the gear 1 and 2, mine has them in 1 map, "Gear 1 or 2" And it looks like you have the compare from TRD vs OEM, so they reduce pressure at high throttle? Or are you comparing backwards?
