General Supercharger Thread
  1. Dec 6, 2024 at 11:41 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    those air tubes were a major PIA working around when installing the Doug Thorley LT's on my tacoma.
  2. Dec 6, 2024 at 11:55 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    They just called to confirm if EGR is wanted. The question is will it pass with out the egr
  3. Dec 6, 2024 at 11:56 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    How did you the block the egr etc?
    e30cabrio likes this.
  4. Dec 6, 2024 at 11:57 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Mine passes, I have the full kit from Hewitt with the sensors that replace the valves, so I deleted everything and my ARH headers don't have the provisions.
  5. Dec 6, 2024 at 12:00 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    HulkSmurf14 likes this.
  6. Dec 6, 2024 at 12:02 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    e30cabrio and HulkSmurf14 like this.
  7. Dec 6, 2024 at 12:02 PM
    M3Tundra-JK
    Scott
    2005 GX470
    e30cabrio, HulkSmurf14 and Mdl like this.
  8. Dec 6, 2024 at 12:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I did the Hewitt block off plates and the cheap DIY AIP bypass. Worked pretty good for past few years.
  9. Dec 6, 2024 at 12:04 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  10. Dec 6, 2024 at 12:06 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm trying to rember what @ViktorG said that the ecu 5v reference that the pumps use can cause issues. I wanted to pull the whole system but settled on turning of mil codes and fooling the temp test.
  11. Dec 6, 2024 at 12:07 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    If you do the DIY bypass, what does the status say for the SAIS? I bought the Hewitt kit because it shows as Ready
    The sensors replace the valves under the blower, if you do the kit you can remove the pumps in the fender as well as the hoses. I just taped off the power plugs for the pumps and zip-tied them behind the mess of wires on the valve cover
    e30cabrio, reywcms[QUOTED] and Mdl like this.
  12. Dec 6, 2024 at 12:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  13. Dec 6, 2024 at 12:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'll have to look. It should be ready as it just tells the ecu for sais that the temp is good.
    If I can take all that stuff off then that would be golden.
    e30cabrio and armyoffoo[QUOTED] like this.
  14. Dec 6, 2024 at 12:12 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yep, I've had mine sitting in storage since I took it off when I installed the supercharger. Picture below is before with the valves, second picture is with the sensors in place of the valves ( breathers zip-tied to the sensor nipples that are open to atmosphere).
  15. Dec 6, 2024 at 12:13 PM
    M3Tundra-JK
    Scott
    2005 GX470
    e30cabrio, reywcms and Mdl like this.
  16. Dec 6, 2024 at 12:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @armyoffoo Thanks! I saw the setup but thought you had to keep it in place.
    armyoffoo likes this.
  17. Dec 6, 2024 at 12:38 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The 3UR-FE doesn't have EGR.
  18. Dec 6, 2024 at 1:11 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Hmm ok so when we order headers and they ask do you need it with or with out EGR we say no EGR ?
    Wynnded[QUOTED] likes this.
  19. Dec 6, 2024 at 1:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Are they thinking of the sais aip system? With or without the air pipe?
    Wynnded and reywcms[QUOTED] like this.
  20. Dec 6, 2024 at 1:14 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    No- essentially that’s two different things from my understanding. Do our stock headers have any provisions lol? If not then the answer would be no EGR lol but I haven’t looked.
    Mdl[QUOTED] likes this.
  21. Dec 6, 2024 at 1:18 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Looks like our stock headers have provisions whether the naming convention is same unknown in regards to egr vs airpipe etc
    e30cabrio and Mdl like this.
  22. Dec 6, 2024 at 1:49 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm sorry, I think I'd need to question them as to why they're asking that question in regard to an engine that doesn't have it. I've read that the 4.6L does/can have it, and maybe that's where their query originates? Dunno.
    e30cabrio, Mdl and reywcms[QUOTED] like this.
  23. Dec 6, 2024 at 1:51 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    @Jowett any input on this? I saw you mentioned no EGR for tundras in another thread.
    Wynnded likes this.
  24. Dec 6, 2024 at 1:58 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I think there’s confusion on the egr vs sais either way looks like stainless works also includes tubes which is what I’m guessing arh is also referring to. https://stainlessworks.net/headers-...MInYnL4OWTigMVfiStBh1CKDpAEAQYAiABEgLgqfD_BwE
  25. Dec 6, 2024 at 1:59 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Only air injection on the 5.7, no egr.
    I neglected to mention the 4.6 does have egr.
    e30cabrio, Wynnded, Mdl and 1 other person like this.
  26. Dec 6, 2024 at 2:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    e30cabrio, Wynnded and M3Tundra-JK like this.
  27. Dec 6, 2024 at 2:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's the air pipe for the aip.
    Yeah, seems their calling it egr but it's the aip/sais.
  28. Dec 6, 2024 at 2:33 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Made progress on my original oil cooler project, after getting side-tracked by my electric fan and electrical upgrade projects...Now I just need to swap out the oil filter housing and make some lines, should be nice short runs.
    I changed the heat exchanger mounting, since previously I was mounting to the AC condenser. I still need to clean up my brackets and paint them. I used M6 nutserts everywhere, 2 in the core support for M6 rubber isolators for the bottom mounts, and 3 in the top cross-bar
    Found a nice spot for the remote filter/thermostat, room for a longer filter and about 1/2" all around. Mounted to the frame with M8 nutserts.
    Clear path for lines to route from exchanger to filter mount:
  29. Dec 6, 2024 at 3:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Good to stay clear of the sway bar. I made sure the sway bar was tight and had no excessive play. I didnt do a remote mount and yours look great!
    armyoffoo[QUOTED] and e30cabrio like this.
  30. Dec 7, 2024 at 8:55 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    sway bar? whats a sway bar? :rofl::rofl:
    Mdl, j_supra and reywcms like this.
