Fog light advice for a 2018 SR5 with factory LED
Discussion in 'Lighting' started by panicman, Dec 4, 2024.
  1. Dec 4, 2024 at 7:05 PM
    panicman
    panicman [OP] Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I looked and may have just missed it, but I'm looking for opinions and guidance on LED fog lights to upgrade from my 2018 LED fogs that came (I think) as part of my TRD Offroad upgrade option package in 2018.
    The current lights create a fairly bright but indistinct puddle that extends out and forward about 20-ish feet. I would say they are "okay".
    I do have to contend with heavy fog, heavy rain, and sometimes snow, and I feel like there are probably upgrades that will blow the doors off of the factory set up.
    I would like to see further forward. I would be fine going with amber, if that offers improved vision in shitty conditions.
    What do you think? What have you had or seen that really impressed you?
  2. Dec 4, 2024 at 7:14 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    My Diode SS3 Pro SAE are awesome. The only problem, which isn’t limited to the SS3 pods, is that the factory housings suck and you’ll get shudder when you hit bumps. I was able to fix some of it with strategically placed zip ties, but it wasn’t ideal. @memario1214 can give his recommendations on the latest and greatest out there, since I know DD and BD have both come out with new offerings since I was in the market.
  3. Dec 4, 2024 at 7:16 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You want then to fit in the oem round housing or are you willing to change those? You could go with the oem rigid from the trd pro or rigids sae fogs which I have. You can add lens covers in amber if you want to, they are removable.
    panicman[OP] likes this.
  4. Dec 4, 2024 at 7:20 PM
    panicman
    Eric
    Thanks you guys!
    MadMax, can the amber lenses be changed without removing or disassembling the lamp from the bumper? That sounds ideal.
    As far as whether to stick with the factory housing or change, I'm willing to change, but would hope it would come as a full kit so I don't have to improvise.
  5. Dec 4, 2024 at 8:26 PM
    MadMaxCanon
    Yes it can, assuming you don't have the pods sunk in so the fronts are flush with whatever surround you go with.
  6. Dec 4, 2024 at 10:18 PM
    panicman
    Eric
  7. Dec 4, 2024 at 10:51 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    I'm running the Baja Designs sae fogs. They have been excellent, and the customer service has been top notch. They are much heavier than the stock and can shake due to the factory housing.
    Baja Designs and panicman[OP] like this.
  8. Dec 5, 2024 at 3:36 AM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Diode Dynamic SAE pros here, only set I have tried. Absolutely awesome, ai have been very happy with mine.
    Like said above use good thick zip ties to assist in limiting or eliminating shakes. I have not had a issue and they have been in 2 years now
  9. Dec 5, 2024 at 4:02 AM
    I'll see if I can find the video again but they compared the Rigid, BD, and one other (I don't remember if it was DD or not) but the Rigids were the winner among those models for most usable light output. I run 4 Rigid SAE's on mine.
    panicman[OP] and MadMaxCanon like this.
  10. Dec 5, 2024 at 4:51 AM
    MadMaxCanon
    panicman[QUOTED][OP] likes this.
  11. Dec 5, 2024 at 5:33 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Baja Design Squadron Sports with factory housing and zip ties. No issues.
    I like that the lens are interchangable. Changed mine from Baja Amber to Factory Amber to match my grille lights
  12. Dec 7, 2024 at 11:30 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Another vote for BD Squadrons. I run sports in my fog locations with amber wide cornering lenses. About a quadzillion times better than the OEM LED fogs…
    I don’t notice any shaking or wobble with mine.
  13. Dec 7, 2024 at 11:43 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'll preface this with I really don't use my fog lights much.
    I can't stand drivers that leave theirs on all the time.
    After trying Rigid's crappy brackets on my 2014, I did this mod.
    You can run about any Rigid D-series..
    They won't shake or move at all.
    Looks great using OEM TRD Pro bezels.
    DIY RIGID TRD PRO Fog Lights Brackets | Toyota Tundra Forum
    I've tried a few D-series fog lights; amber, SAE, and now LED pods.
    I didn't care for the amber after a few months.
    With the SAE I kept getting high beam flashes from oncoming drivers.
    Granted my LED pod fogs are more for show than function, but it's not an issue since I rarely use the actual 'fog light' anyway..
    The amber, I don't have a pic of the SAE.
    The LED pods have LEDs in the corners that come on with my parking lights.
    The actual fog lights are bright with a wider beam than the headlights, but nothing special.
    29f6317e-8d30-47df-ad54-c03c88e8edc4_9a32528175e58e482d38c7c0eccabceabc1fc207.png9a252798-81ea-4c1a-84c9-b556ba9436bb_be6060371329f5e0e45359e69417952f1b3d3b0e.png
    TacomaTRD4x402 and panicman[OP] like this.
  14. Dec 8, 2024 at 6:24 AM
    yamabob
    yamabob New Member
    Chicagoland
    2018 Limited
    I have a 2018 Limited with the Diode Dynamics clear Pro lamps, love them. They are a substantial difference from the factory fog lamps. I zip tied mine like everyone else and get no shaking. I think they are adjusted correctly as I don't get anyone flashing their brights at me but still feel guilty running them sometimes. Very happy with the change and was way easier to install than I thought they would be,
  15. Dec 10, 2024 at 9:49 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    The new "Factory Amber" Lens looks so good. Clean Install!
    Best,
    Brahian Herrera | Forum Sales & Support
    Email: brahianh@bajadesigns.com | Phone: (760) 560-2252
  16. Dec 14, 2024 at 12:57 PM
    panicman
    Eric
    After watching too many GD fog light videos, I went with Baja Designs Squadron SAE. I also ordered the factory amber lenses. I'll post back after installation and use.
  17. Dec 28, 2024 at 9:37 PM
    panicman
    Eric
    Aaaaaand I'm back!
    The Squadrons are installed and they look great.
    However, I'm worried I chose the wrong lens. I got the factory amber cornering lenses, and the pattern is bizarre:
    I cannot see the amber flood on the ground sitting in the cab. @Baja Designs Is there a way to adjust these, or do I need to pull them and put the clear amber lenses in?
  18. Dec 29, 2024 at 10:13 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    I don’t have SAE Squadrons for clarification on your question, but I’d sure hope they do more than that! My Squadron Sports with wide cornering lenses are a million times more useful than that pattern if yours are doing what they’re supposed to.
    I bet @Baja Designs can help with an answer!
  19. Dec 30, 2024 at 12:14 PM
    Baja Designs
    San Marcos, CA
    On our SAE Model, the Reflector is what gives the pattern, and that is why all the SAE models come with a spot lens. The pattern you change them to is Wide Cornering so that's why it looks off. It's pretty much defusing the light x2. Also, want to highlight that the Factory Amber lens is not street-legal, and that is why we only offer them in Clear and Baja Amber on the website. If you have any questions please reach out to brahianh@bajadesigns.com
    Happy Holidays.
  20. Dec 30, 2024 at 3:17 PM
    panicman
    Eric
    Well that explains it!!
    the factory amber looks awesome, but I'll pull them and put the amber in. Thank you @Baja Designs !!
  21. Dec 30, 2024 at 4:03 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Good point on the Wide cornering lenses being the culprit. I didn’t even think about that! Maybe. Because I’m more familiar with the original SAE offering that was just an insert behind the lens.
    Assuming when he puts the original lenses back in, that problem will be solved.
  22. Jan 1, 2025 at 1:24 AM
    panicman
    Eric
    Problemo solved. What a difference. Note that the earlier pics have Christmas lights on. The BD fogs really do dump a lot more light on the scene.
    Factory-
    New Baja-
    Chad D. likes this.
