Installing a solar array on the Tundra
Discussion in 'Off-Topic Discussion' started by gosolo, Oct 6, 2017.
  1. Oct 6, 2017 at 5:46 PM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    I’m considering the install of solar panels across the top of my snug top. Longer term power for the coming zombie apocalypse (long trips and longer stays). Ability to keep up the battery charge would be nice plus keeping multiple accessories from death would be nice.
    This topper never comes off. When I’m hauling cargo I use a trailer.
    Has anyone got experience doing anything similar? I’ve had several portable systems but never done a permanent setup.
    Suggestions and recommendations are appreciated.
  2. Oct 6, 2017 at 5:51 PM
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    :popcorn::popcorn::popcorn:
    This sounds like a great option for family trips and I'm sure other experienced members on here will chime in
    gosolo[QUOTED][OP] likes this.
  3. Oct 6, 2017 at 6:31 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Super common thing to for a sailboat. The marine industry will be your friend in setting up something like this and an enemy to your wallet.
    Bob and gosolo[OP] like this.
  4. Oct 7, 2017 at 5:36 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Check out expedition portal forums. Good info there. Also a few guys on tacomaworld have done similar projects.
    gosolo[OP] likes this.
  5. Oct 7, 2017 at 7:37 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  6. Oct 7, 2017 at 7:39 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    I will be doing this and hooking the panels to the second battery. I’ll pull some info together.
  7. Oct 7, 2017 at 7:46 AM
    Pretty common on RV's to mount some panels on the roof.
  8. Oct 7, 2017 at 8:24 AM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    rbraddock on tacomaworld has a panel and charging system, he's a good guy, you might want to talk to him.
  9. Oct 7, 2017 at 9:24 AM
    Pudge
    CT
    I don't know anything about this stuff but seems to me if you're going through the wiring and expense. It may be worth going dual battery and / or a deep cycle battery in addition.
    gosolo[OP] and smslavin like this.
