General Supercharger Thread
  1. Dec 1, 2024 at 9:25 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  2. Dec 1, 2024 at 9:36 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It is and you only need it for the rear. There's a regear thread where @Lemuel1 put it in and has about 300 miles on it. Breaking it in along with the new motive gears. He says it is working very well.
    A few pages back it was brought up that speedmaster had some counterfeit parts and gave caution as summit and jegs aren't carrying their products. Jeggs still has their lsd's.
    If you get it use an installer that can overcome issues. Seems the speedmaster has tight carrier splines that will need to be overcome.
    e30cabrio likes this.
  3. Dec 1, 2024 at 10:00 AM
    Danimal86
    Daniel
    Sacramento, CA
    Thanks....i'll hold off for now and wait to hear the consensus if its going to be the go-to.
    Seems pretty dang reasonable for just overr $500
    HulkSmurf14 and Mdl[QUOTED] like this.
  4. Dec 1, 2024 at 10:18 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Or the powertrax should be back in stock soon. You could email them for an update.
  5. Dec 1, 2024 at 10:23 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    what DeatschWerks 650 injectors fit 15 and up?
    all ive seen are saying 07-15
    Mdl likes this.
  6. Dec 1, 2024 at 11:36 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Silver17 has them and another on a 2016 on up.
  7. Dec 1, 2024 at 11:38 AM
    NatesNightMare
    Pinetop Az
    so even though they say 07-15 theyll fit and work on my 18?
    HulkSmurf14 likes this.
  8. Dec 1, 2024 at 11:38 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    i have on my 2020
  9. Dec 1, 2024 at 11:40 AM
    NatesNightMare
    Pinetop Az
    next question, what the next up fuel pump better than the maggy one?
  10. Dec 1, 2024 at 11:43 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I was about to edit and include your 2020. Haha
    nobodyintexas[QUOTED] likes this.
  11. Dec 1, 2024 at 11:46 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  12. Dec 1, 2024 at 11:52 AM
    NatesNightMare
    Pinetop Az
  13. Dec 1, 2024 at 11:54 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    yes works fine both injectors and pumps. Those are what’s included with the Whipple kits
  14. Dec 1, 2024 at 11:54 AM
    NatesNightMare
    Pinetop Az
  15. Dec 1, 2024 at 12:02 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    snivilous[OP] likes this.
  16. Dec 1, 2024 at 12:07 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    The truck year I have yet to see make any difference.
    I did the DW300 pump and DW650 injectors on both a 2008 and a 2021 over the summer.
  17. Dec 1, 2024 at 12:11 PM
    NatesNightMare
    Pinetop Az
    yeah im looking to do the fueling upgrade as i just became a retired diabled vet so i got some backpay. so im making sure the right injectors and pump to get
  18. Dec 1, 2024 at 12:19 PM
    snivilous
    SW UT
    My complaint with the 650s is they don't leave a lot of overhead, they're only 20% larger than the injectors you already have. I don't know of a good alternative that's truly plug and play, but @TurboKits was talking about releasing some 800cc injectors. I would personally prefer something in that range. If you're nearly maxing the current injectors, then the 650s will only take you down to the spot you'd like to be to start with and essentially no room to grow without hitting the limit rapidly. If you don't want to upgrade stuff later that's a different story, but if you don't have a lot of disposable income and can't afford to buy another set AGAIN and then wait to sell the 650s that would suck---but currently there's no options other than the DW650s that I would personally recommend let alone being a larger size so.... food for thought. You might be better off holding onto that cash and see if the TurboKits injectors get released (course there's also the question if those are drop in plug and play, whether they'll be reliable, etc too).
    And you can always bump the fuel pressure to make the DW650s a larger injector, but that's just more shit to add to the pile to band aid that they're not huge. And lots of people run the 650s and are happy, but I figure I'd lay all the thoughts on the table!
    HulkSmurf14, reywcms, Wynnded and 2 others like this.
  19. Dec 1, 2024 at 12:29 PM
    NatesNightMare
    Pinetop Az
    i honestly dont think ill upgrade much after this if anything. i just would tather get a bit more room as i believe ott said they pushed them as far as they could for best performance etc. i dont think theyre maxed but close. plus i also just want the bit of space so when/if i drop quiye a bit in elevation im not overdoing it or have to "play it safe"
    Mdl likes this.
  20. Dec 1, 2024 at 12:40 PM
    snivilous
    SW UT
    In that case I'd get the DW650s and DW300 and send it. That seems to be the most reliable setup and no playing games to make it work out of the box.
  21. Dec 1, 2024 at 12:41 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    There are a ton of counterfit pumps, I suggest getting whichever you get from a known good source. I had 2 from Walbro fail out of the box.
    NatesNightMare and Mdl like this.
  22. Dec 1, 2024 at 12:52 PM
    NatesNightMare
    Pinetop Az
    OTT said ill have to retune, you agree?
  23. Dec 1, 2024 at 12:56 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Hopefully your TAP's got you setup with the VA and went through your medical to get it all covered.
    It's a bit spendy the turbokits 880's look promising but at $979...
    https://www.turbokits.com/2007-2021-tundra-5-7l-880cc-drop-in-performance-injector-set.html
    Going with 650's you will hVe to tune injector constant and maf.
    TurboKits, e30cabrio, bflooks and 2 others like this.
  24. Dec 1, 2024 at 1:03 PM
    NatesNightMare
    Pinetop Az
  25. Dec 1, 2024 at 1:15 PM
    snivilous
    SW UT
    Yea definitely, truck will run rich otherwise. You shouldn't have to immediately, the worse that happens is it throws a too rich engine code--so if you HAVE to drive it without retuning it you can and it'll be fine. The fuel pump you can do whenever and doesn't need a retune.
  26. Dec 1, 2024 at 1:22 PM
    NatesNightMare
    Pinetop Az
    they also wanted me to have a wideband afr, which i do, but it doesnt have any other adapter to read from a pc. is it a MUST?
  27. Dec 1, 2024 at 1:48 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Are you going to make/buy a new shroud or run it as-is?
  28. Dec 1, 2024 at 1:51 PM
    snivilous
    SW UT
    Nah, most people don't/can't properly log it with a computer. Worse case I have people take a video with their phone of the gauge and that's more than plenty to tune it.
  29. Dec 1, 2024 at 1:54 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Going to run it as-is for now and see how it does, it's a Spal 16" fan that moves a ton of air, so I'm hoping it'll be good.
    Mdl and helidave[QUOTED] like this.
  30. Dec 1, 2024 at 2:03 PM
    JustDSM
    JustDSM New Member
    Justin
    If you’re going to a larger diameter intake (as you mentioned to us) and injectors you’re going to need a wideband we can log if we’re tuning it.
