Screwed up and used the green stuff
Discussion in '1st Gen Tundras (2000-2006)' started by bing5, Nov 23, 2024.
  1. Nov 23, 2024 at 2:08 PM
    bing5
    bing5 [OP] Long member
    New Mexico
    2004 Double Cab. 270k+
    Like she came out of the factory.
    I had to replace the radiator in the Tundra several months ago. I filled the new radiator with distilled water and old Prestone green antifreeze. Thinking I should flush it out and replace with Asian red?
    Any good ideas on flushing the system out completely?
  2. Nov 23, 2024 at 4:30 PM
    bfunke
    bfunke Tundra Curmudgeon
    Search is your friend. Go buy 5 gals of distilled water (cheap) drain your radiator with heater full hot and remove lower hose. Then open the two 10 mm block drains. Fill it up with tap water and repeat 2-3 times till water comes out clear. Now do same with distilled water to get rid of tap water from system. Finally drain and fill with Asian Pink - you’ll need 2-3 gallons of premix or 1 gallon of concentrate for 50/50 mix. If radiator cap not new when your did radiator, replace it.
    bulldog93, mtucker, shifty` and 3 others like this.
  3. Nov 23, 2024 at 8:12 PM
    bing5
    New Mexico
    Thanks much. You're right...I'm lazier on the search than I should be. Thanks for the mild scolding :)
  4. Nov 23, 2024 at 8:23 PM
    10 Bears
    10 Bears New Member
    11 CREW 5.7
    None at the moment
    "Open the two 10 mm block drains"
    I've never heard of doing this. I usually go the Chilton or Hayes route with distilled water and turning the heater on high to get as much old coolant out.
    But this method sounds like a full on military style assault on removing the green stuff. I like it....
    Tundra2 and whodatschrome like this.
  5. Nov 24, 2024 at 7:49 PM
    bing5
    New Mexico
    1 gallon of concentrated pink is insufficient I'm thinking? Looks like total cooling capacity at 12+ quarts and want at least 50/50 mix?
  6. Nov 25, 2024 at 1:48 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Right! So 1 gal = 4 qts. 50/50 mix > 8 qts. So...
  7. Nov 25, 2024 at 4:30 AM
    gagecalman
    gagecalman New Member
    Maryland
    2006 Tundra DC SR5 4WD 4.7 V8
    You need 2 gallons of concentrate.
    I like and use PEAK OET extended life red/pink concentrate coolant for Asian vehicles. I also use the green in my Subaru. I called them and was told their red, green and blue are basically the same (for Asian vehicles) but they change the color so it looks like what is supposed to be in it.
    Now if you can believe it they state "Service life of up to 15 years/400,000 miles with a complete cooling system flush and fill". I wouldn't run it that long lol.
    Here's my issue with the OEM pink. It only comes as 50/50. That's okay if you have a completely empty system or you want to top off your overflow. But if you flush with distilled water and there's some left what are you going to wind up with. 40/60 or 30/70. Who knows.
    That's why I like the Peak concentrate. I shoot for 60/40. Just my 2 cents.
    bulldog93 and shifty` like this.
  8. Nov 25, 2024 at 4:54 PM
    bing5
    New Mexico
  9. Nov 25, 2024 at 5:09 PM
    bing5
    New Mexico
    Painfully obvious I know....was trying to wiggle around shelling out $50 in antifreeze ;)
  10. Nov 26, 2024 at 1:58 AM
    w666
    Maryland
  11. Nov 26, 2024 at 7:50 AM
    bing5
    New Mexico
    Nice! Knew about the parts on RA. Chemicals didn't occur to me. Thanks
  12. Nov 26, 2024 at 8:10 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  13. Nov 26, 2024 at 9:59 AM
    I have beef with "universal" coolants, especially with the 2UZ-FE many of us use in our trucks for this subforum. Maybe it's different for later years, dunno.
    But generally speaking, I don't buy into this concept of "one size fits all" for coolants. Toyota calls for silicate free, borate free, nitrite free, and amine free coolant in HOAT format for our 1st gen trucks post-2004 (and I believe backdated to 1998). If you look at the bottle for the "universal" coolant you linked, all it says is "HOAT" compatible. It doesn't bother to mention anywhere I could find in their documents or product info if it lacks silicate/borate/nitrite/amine. That's sketch to me; why doesn't it say?
    It's also problematic to mix coolants, and the vast majority of 2000-2006 1st gen (+2007 Sequoia) came with red or pink from the factory. Mixing yellow with red/pink, mixing brands, you never know what you'll get. But we've seen what's happened with some of our 2UZ-FE owners, and it's not pretty. Like, this exact type of buildup, @Tundra2 had that crap ended up jammed in everything in his engine, like the throttle body bypass, the lines to the oil cooler, clogging everything up to the oil cooler, clogging the internals of the oil cooler, completely clogging cooling hoses, one radiator hose, another radiator hose. This was the consistency of it. His previous owner was a dumbass and didn't understand you can't mix coolants and there's no such thing as "universal" coolant.
    Beyond that, using pink super long life (SLLC) has diagnostic benefits, it shows leaks absurdly well compared to other colors that won't throw a red (harhar) flag.
    tl;dr - Toyota says use SLLC pink in my 1st gen engine. They built the engine and know what's best for it, so I use their recommended coolant and OEM filters because that's what was designed to work with it, and it's what they tell you to. I'm not gonna knock you if you prefer generic/one-size-fits-all, I just question the validity of the "Universal" claim Prestone and a few others are using, and we've seen negative results from mixing OEM/factory pink with other colors. Anyone moving from pink to other colors should be opening the block drains and running/flushing a few cycles of distilled water through their block before switching colors.
  14. Nov 26, 2024 at 4:15 PM
    bing5
    New Mexico
    I'm going pink :)
  15. Nov 29, 2024 at 10:18 PM
    bing5
    New Mexico
    Haynes manual states to remove the thermostat during flushing and crank heater to high to flush the heater core. Makes sense to me...not sure if entirely necessary to achieve the goal....
  16. Nov 30, 2024 at 2:33 AM
    w666
    Maryland
    If you run the engine up to operating temperature (thermostat is open) the water circulates through the heater core. Yes, you have to have the heater cranked to hot because there is a mechanical valve on the firewall that opens/shuts flow to the core. There are various types of cold water/garden hose flush techniques, in which case it would be necessary to remove the thermostat.
    shifty` likes this.
  17. Nov 30, 2024 at 5:29 AM
    And honestly, this is true for nearly every vehicle I've ever owned that had a heater core. I feel like it's pretty standard practice that any fledgeling wrencher like @bing5 should know, if you're dealing with coolant, and the car has heat, open/run the heater during flushes and fills to circulate fluid fully.
    Tundra2 and bfunke like this.
  18. Nov 30, 2024 at 5:15 PM
    bing5
    New Mexico
    I'm now in the pink so to speak...
    Thanks to bfunke, shifty, and others for the tips. Very straightforward. Most difficult part was locating the coolant drain plugs in the block. My Haynes manual showed them at the locations indicated in the illustration. Not sure what they were smokin'.....must be a first edition. o_O
  19. Nov 30, 2024 at 5:40 PM
    Identical image to the FSM, so more like, "what Toyota was smokin'"
    bing5[QUOTED][OP] likes this.
  20. Dec 1, 2024 at 3:44 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I just went through this myself because my former shop used the green coolant when they replaced my timing belt 100k miles ago
    it took quite a few flushes, and I also drained it using the 2 block drains. I think the problem is what is still in the heater core. There is a method where you can disconnect the hose going to the heater core at the valve on the firewall and blow air into it to get more of the old coolant out
    Someone already mentioned their problem with the pink was that it would be diluted with the old coolant or water that was still in the system after draining. That was my concern as well, but the pink is good for 100,000 miles where as the concentrate is only about 50,000 if I remember correctly. That's why I'm doing it again down the road but try to blow out what is in the heater core this time
    shifty` and Tundra2 like this.
  21. Dec 1, 2024 at 11:01 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    the largest oldest independent yota shop in my town uses a universal ( they also specialize in subies) it is a off green color. Except ours has to be mixed for minus 60 degrees.
    I had called them because they had put a timing belt kit in a few years back for previous owner and told them I had green coolant, thats when they told me they use the universal as of a few years back
