  1. Nov 29, 2024 at 8:45 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Aw, man…i’m so sorry for your loss. Our four legged family members don’t last forever and it’s the worst thing ever when we have to say our last goodbye to them. I’m shedding a tear for you right now. Another new mutt can never replace our old friend, but what they can do is start a new adventure in life with you. You have hundreds of memories with her and she will never be forgotten. Take as much time as you need for a new pooch to search you out. Maybe a week, maybe a year, maybe 20 years from now, but there will definitely be one out there that is seeking you…but you just don’t know which one it is yet.
  2. Nov 29, 2024 at 8:48 PM
    whodatschrome
    lots of dents
    And that goes the same for you too Fish. I’m just playing catch up with the thread and saw that you lost a four legged family member as well. My condolences.
  3. Nov 29, 2024 at 9:11 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I think you and Jake's bachelor pads kick ass, respectively. Just sayin...
    bmf4069[QUOTED] likes this.
  4. Nov 29, 2024 at 9:28 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The argument isn't about whether you should replace the fluid it's about how. Power flush vs multiple drain n fills
    FirstGenVol likes this.
  5. Nov 29, 2024 at 10:36 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I feel like there is never a good mileage or time to ever do a power flush. Just seems way too harsh.
  6. Nov 30, 2024 at 2:55 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I've done em on two of my A340E transmissions with over 180k and had no issues.
    KNABORES likes this.
  7. Nov 30, 2024 at 5:36 AM
    Yup.
    It may just be that you've got shit floating around and/or whatever caused that metal to be floating around also caused the solenoid to jam or get buggered up.
    Dook55 and FirstGenVol like this.
  8. Nov 30, 2024 at 6:48 AM
  9. Nov 30, 2024 at 7:00 AM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    I was able to score a pair of the older-style (greaseable) SPC ubj's, p/n 25001, through...O'Reilly.
  10. Nov 30, 2024 at 7:14 AM
    Did SPC stop making greaseable ball joints? Originally they were not greaseable, and failed early. Then SPC started making them greaseable. That was 5-6 years ago at least.
  11. Nov 30, 2024 at 7:15 AM
    Desert Dog
    @Voss
    I just realized that you have FJ/TRD wheels on your truck. Do you have spacers installed?
  12. Nov 30, 2024 at 7:18 AM
    Desert Dog
    Yes, there's a new, sealed style. However, I heard rumor there's a "kit" available to make them greaseable. Not sure if it's true. I emailed SPC tech to verify, but that was just yesterday. Probably won't hear from them til Mon.
    455h0le_dachshund likes this.
  13. Nov 30, 2024 at 8:36 AM
    whodatschrome
    lots of dents
    I just took a peek at their website. They have some pretty trick fab tools. The bender you got is very nice! I bought a new JD2 bender (and 3 or 4 dies) back in 2012. I still have yet to unpack it. The reason being is that i haven’t found a good place to mount it in my shop….doh!
    JakeJake[QUOTED] likes this.
  14. Nov 30, 2024 at 8:44 AM
    IIRC, there are/were 3 diff't UBJ for our SPC uppers (SPC UCA p/n 25485). One greasable/zerked, which most of us probably have currently installed b/c our arms came with them preinstalled, two ungreasable/no zerk. One w/o zerk is discontinued because of some issue with an internal spring that was bothersome for inspection stations (??!).
    SPC shows that here in the red box (screencap below). And here is our current replacement option, SPC p/n 35109. The original zerked UBJ was SPC p/n 25001 and may be NLA.
    Some UBJ test info from @des2mtn here: https://www.tundras.com/posts/3658517
  15. Nov 30, 2024 at 8:55 AM
    Desert Dog
    I wanted to stay with the greaseable style for 2 reasons. One, I've had zero issues with mine, and, two, I'm a weirdo who wants to be able to grease/maintain them. Most of the complaints/issues I've seen were maintenance-related (i.e. failure to grease as-required and/or failure to use the correct grease). Since I don't find myself in either category, I want to stay with what has worked for me. Weird, huh?
    455h0le_dachshund and BroHon like this.
  16. Nov 30, 2024 at 9:04 AM
    The original zerked UBJ for our UCA is SPC p/n 25001, I'll update my post above with that info. SPC doesn't have them in their catalog any longer, so check for inventory before ordering from online stores.
    EDIT: @Desert Dog, I was wrong; you can get to 25001 at their store: https://store.specprod.com/item/25001/-OBS-REPLACMNT-BALL-JOINT-KIT/
    And it's possible some local stores like (yuck) Oreilly's may carry them.
  17. Nov 30, 2024 at 9:15 AM
    Desert Dog
    Correct. I referenced that p/n in a prior post. Direct from SPC is pricey, but for someone who just has to have it for whatever reason, it is available from SPC at this time. I saved some coin from O'Reilly, and was surprised when they were available through them. I purchase very little through them, but never have had the ssues you've apparently had. I've had more issues with O'Reilly in-store due to slowness and me knowing more than the employees, but other than that, my experiences have been satisfactory.
  18. Nov 30, 2024 at 10:05 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    So doing a full flush through the trans cooler lines isn't the best method over repeated drain and fills where the fluid is never fully swapped? Was planning on a full flush soon.
  19. Nov 30, 2024 at 10:13 AM
    Desert Dog
    Either is ok and harmless. The issue most have is discomfort with a power-flush. A separate procedure.
  20. Nov 30, 2024 at 10:16 AM
    ToyotaDude
    ToyotaDude Member
    What is that?
  21. Nov 30, 2024 at 10:18 AM
    I want to say Timmy has a video showing flushing using the radiator drain lines. Maybe I'm crazy.
    ToyotaDude[QUOTED] likes this.
  22. Nov 30, 2024 at 10:46 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    he has a vid using the trans cooler lines
    shifty`[QUOTED] and FrenchToasty like this.
  23. Nov 30, 2024 at 11:00 AM
    Desert Dog
    Briefly, it's a procedure that uses a machine to pressurize a trans to force fluid and material out. I don't have a comprehensive video available at this moment, sorry.
  24. Nov 30, 2024 at 1:07 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    G_unit3000, CodyP and FishNinja like this.
  25. Nov 30, 2024 at 1:47 PM
    FishNinja
    Lee
    06DC2wd
    since there isn't very much stress on the UBJ's of Toyota IFS. And you don't drive enough.
    Youre not in much danger at all.
    BroHon[QUOTED] and Desert Dog like this.
  26. Nov 30, 2024 at 2:16 PM
    Desert Dog
    BroHon[QUOTED] likes this.
  27. Nov 30, 2024 at 2:19 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    But make sure your auto insurance is up to date
    :mudding:
  28. Nov 30, 2024 at 3:01 PM
    Desert Dog
    Home, sweet, home. ~ 74° @ 4:00. Makes it worth the 3-4 brutal months we have to deal with here.20241130_154221.jpg
  29. Nov 30, 2024 at 3:05 PM
    Desert Dog
    @FrenchToasty, uh huh, I know you know :D
  30. Nov 30, 2024 at 3:12 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Ouch. Thats a whole lotta sharp edges.
    I really wanna link the Southpark Mr. Slave vs. Paris Hilton Whore off, but its...uhhhh....something.
    bmf4069 and shifty`[QUOTED] like this.
