Platinum side molding keeps breaking
Discussion in '3rd Gen Tundras (2022+)' started by Jagator, May 11, 2022.
  1. Nov 5, 2023 at 12:53 PM
    #121
    glozanoff
    glozanoff New Member
    Toyota tundra 2023 platinum I force
    3/3 for me too. Got it repaired twice and today it expanded. It’s only 77 degrees. Was in the sun and bend back off tape. This time hopefully they place it even further back. Only had truck 10 months.
  2. Nov 6, 2023 at 9:35 AM
    #122
    glozanoff
    Look how much it expands when in sun. Last night it was 1/2 inch apart.
    CrayCray, dagsom, Abraham5G and 2 others like this.
  3. Nov 9, 2023 at 3:31 PM
    #123
    glozanoff
    Update. Went to dealership and will be moving it back a little compared to previous outline. Maybe 1/8 an inch as the expansion in sun is about 1/8 and will hit front door when open and 77 out
  4. Nov 10, 2023 at 7:21 PM
    #124
    guido-tkp
    guido-tkp New Member
    Maine
    2023 Platinum Tundra 6.5’ Bed
    Finally got mine fixed today (first time). Covered under warranty without any trouble.
    Woodrow bangs likes this.
  5. Nov 11, 2023 at 6:15 PM
    #125
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    My dealer was great. Replaced all 4 moldings and it looks really nice. Time will tell but I’m optimistic.
  6. Nov 11, 2023 at 7:49 PM
    #126
    glozanoff
    I had my replaced but notice it will expand about 1/16 to 1/8 an inch. If it is In line with the door it will catch on heat. Make sure it’s a little back from door frame. Mine was in line with door and that is what happened above on a direct sun 77 degree day. Dealership agreed after 3
    Times to move 1/4 inch back
    they did make some small dents in the process so now going back
  7. Nov 16, 2023 at 12:13 PM
    #127
    fordtc
    fordtc New Member
    Thomas
    2024 Tundra
    Well I have a 2024 and the problem is still happening. Drivers rear door was loose when I picked it up and it seems to seperate from the door when it gets warm out. In FL that is every day. Dealer has ordered replacements and just waiting on them to come inPXL_20231027_121812300.PORTRAIT.jpg
  8. Nov 16, 2023 at 2:09 PM
    #128
    glozanoff
    They moved mine back because it would expand 1/8 inch and catch front door in heat. Now about 1/4 an inch back. Have not had any issues with coming off tape other than when it hits the door. Live in South Carolina so had several 100 degree days. Time will tell. Watch closely because when they removed mine they scraped and dented the door.
  9. Dec 6, 2023 at 4:48 AM
    #129
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    And now my newly installed door trim is pulling away from the doors. Adhesive not great. Toyota does trucks well, not plastics.
    glozanoff likes this.
  10. Dec 14, 2023 at 9:30 AM
    #130
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    Dealer offered to replace my side moldings again. I'm not sure I love these side moldings enough for more trial and error on if they will last long term (clearly they won't). So I'm thinking of removing the side moldings and just adding a simple "Tundra" or the 2nd Gen Platinum badge to the drivers/pass doors. Just sharing for those dealing with these darn molding issues as well. Anyone on here already do this? Remove side moldings on a platinum?
  11. Dec 14, 2023 at 10:48 AM
    #131
    glozanoff
    I am about to. Had a car turn into me and the entire left side needed repainted. I had them leave the left off to see thoughts and pick up tomorrow. The right side has dents from replacing so going to get that repaired and most likely ask for the other side. It looks more blacked out. Can always add on down the road or put a tundra decal. I have had these replaced 4 times as they kept having to move further back on door. Also spoiler plastic is now digging into my tailgate when sun expands. This plastic is an endless battle. If you take off you can always just add on later or resell and new owner can add them on.
  12. Dec 15, 2023 at 5:53 AM
    #132
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    This is actually a great idea. Take them off and decide later. Thank you I'm going this route.
  13. Jan 11, 2024 at 4:32 PM
    #133
    Gsdmom
    Gsdmom New Member
    2024 Black Tundra Platinum
    Finally got the call today that my replacement molding is in. Appointment is scheduled for next week. So took about 2 months for the part to be ordered and delivered to the dealership. Now the question is, will they try and make me pay for it? I’m prepared to call Toyota customer care if I need to, I’m not paying a dime for poor design issues.
  14. Jan 11, 2024 at 4:50 PM
    #134
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    FWIW replacing them wasn't a great solution either. Mine were and now the adhesive is not adhering in parts so I'm sure it will only get worse. I do think they look nice but the darker trucks are more of an issue it seems and may think of alternatives. The simple "TUNDRA" and "Platinum" emblems from last generation are an idea I'm thinking on.
  15. Jan 11, 2024 at 4:56 PM
    #135
    glozanoff
    I took my off they come off in heat from glue or expand! If you do put them on put the back one 1/4 inch back or more or they hit. I’m having dealership fix the dents from removing and keeping them off. That’s why trd pro does and it looks clean
  16. Jan 11, 2024 at 4:56 PM
    #136
    glozanoff
    Also spoiler expands and causes paint chips on tailgate so that’s also a spoiler fix and repaint and Toyota is aware and working on solution.
  17. Jan 17, 2024 at 11:41 AM
    #137
    Gsdmom
    Gsdmom New Member
    Just left the dealer with a loaner. They successfully replaced the broken part, but in the process of removing the old one the tool they used created a bunch of little dents in the door. Now they are fixing the dents they made. In the meantime I’ll settle for an SR5 with the TRD package. Thankful my dealer was at least honest enough to point this out, I probably wouldn’t have noticed if they had me just come and pick it up.
  18. Jan 17, 2024 at 12:28 PM
    #138
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    The dents in the door?? I've seen this posted more then once. while other posts mention that you can just pull them off with heat and light pulling. Seems odd
  19. Jan 17, 2024 at 12:35 PM
    #139
    Gsdmom
    Gsdmom New Member
    I know….not thrilled about it. Where I’m located we just had a snow/ice storm, so when I brought the truck to the dealer this morning they told me they were going to have to heat the truck up to get all the ice off first, then take the molding off. My guess is they were getting impatient and decided to start trying to take it off anyways, then after getting it off realized they left dents behind. Now I have to wait until their “dent guy” comes next week.
  20. Jan 17, 2024 at 12:41 PM
    #140
    Woodrow bangs
    Baltimore
    2023 MBM Platinum
    We have an ice event here too. My dealer is replacing mine next week. The dent my ish in the process they can keep it after all I been through. Love the truck but I'll just get a different one without the dumb plastic issues. Still no update on the tailgate issues, but I'm sure they will have a fix in time. Do not repaint your gate, I did and it came back.
  21. Feb 20, 2024 at 3:01 PM
    #141
    Phxav8tr
    Phxav8tr New Member
    Remote
    ‘22 Platinum
    Had my ‘22 door badge trim replaced at the dealership due to it peeling back at the edges. As other people have posted, the dealership said it was under factory warranty so there was no charge. They replaced both sides at no cost to me.
  22. Feb 24, 2024 at 1:26 PM
    #142
    Foolishfrog
    Foolishfrog New Member
    Mitch
    2024 6.5 Pearl Platinum for towing camper
    I’ve had my Platinum for 3 months and I had the rear door driver side snap off in exactly the same way. Exactly like the pictures in the very first post in this thread. Wondering if the right answer is to just remove them all and be done with it.
  23. Feb 24, 2024 at 1:28 PM
    #143
    Foolishfrog
    Mitch
    I really like the way yours looks
  24. Feb 24, 2024 at 5:04 PM
    #144
    S Schott
    S Schott New Member
    S
    Took those pieces off a week into owning a platinum for a cleaner look.
  25. Feb 25, 2024 at 2:11 PM
    #145
    Ryan P
    Ryan P New Member
    2022 Tundra Platinum
    For those that have removed these, what did you use to get rid of the left over tape residue?
  26. Mar 12, 2024 at 8:46 AM
    #146
    JStab
    JStab New Member
    Pensacola, FL
    2023 Magnetic Tundra Platinum
    All of the skin on both thumbs and acetone
  27. Mar 12, 2024 at 9:36 AM
    #147
    blschaefer1
    blschaefer1 New Member
    Use a heat gun to loosen up the leftover adhesive. Most of it will peel/roll off. Anything left, use something like Goo Gone or better yet some 3M Adhesive Remover.
  28. Aug 10, 2024 at 9:35 PM
    #148
    PVT Pablo
    PVT Pablo
    Paul
    Puget Sound, WA
    2023 Tundra Platinum Hybrid
    Dobinsons IMS 2"/1", BMS 1" Wheel spacers with OEM Platinum Wheels. Icon Sway Bar Spacer. 285/65/20 Firestone Destination XT Tires.
    Mine are starting to separate from the truck. They haven't touched or broke, but the adhesive is failing.
    With the constant expansion and contraction, they are bound to fail. Every single one, just a matter of time.
  29. Nov 27, 2024 at 11:12 PM
    #149
    Alexv305
    Alexv305 New Member
    Alex
    Any chance you still have your moldings? I am interested in them
