Extremely Cheap! 5.29 gears. Motive gears OK?
Discussion in 'Performance and Tuning' started by Silver17, Oct 5, 2024.
  1. Nov 25, 2024 at 11:37 AM
    #361
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You can always send them back. Not like the other thread where time has passed by. It'll give you peace of mind having a good start.
  2. Nov 25, 2024 at 2:40 PM
    #362
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    On one hand, there is typically not any appreciable gear mesh in that spot.
    But, you didn’t pay for damaged goods. I’d return them…
    Mdl likes this.
  3. Nov 25, 2024 at 7:02 PM
    #363
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I ordered a Timken bearing kit for the rear. Got a good deal only it did not come with the shim kit. I spoke with Motive and confirmed the shims that come in their kit. Rear shims are SK44, SK23 and SK13. A front GM 9.5 shim kit works for the Toyota 9 IFS which include SK47 and SK13. I ordered the shims through Drivetrain America.
    I'll confirm once the shims arrive. Also Dana 44 rear shim kit Motive 1115 works too. This is according to what is included in Motive and Yukon kits.
  4. Nov 27, 2024 at 1:29 PM
    #364
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Anyone get their gears installed yet?
    Mine came the other day and just waiting for some real world feedback!
    Silver17[OP] and Mdl like this.
  5. Nov 27, 2024 at 1:44 PM
    #365
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I just picked up some metal to fab up the clamshell holder for the press. I'm waiting on my rear bearings and 2 Toyota seals...
  6. Nov 27, 2024 at 5:54 PM
    #366
    Silver17
    Silver17 [OP] Used, but returned and sold as new member
    Northeast
    2017 TRD 4x4 Harrop SC
    Do you have the details on the part numbers and good place to buy the necessary Toyota seals as opposed to the ones in the master kits?
    Also, just looked at my front Yukon kit and it uses Nachi bearings that are made in Japan. Not sure how they are. I’ve used Nachi bearings before in large electric motors at work but this is a whole different application. Hoping they are of similar quality to Koyo or Timken…
    Mdl[QUOTED] likes this.
  7. Nov 27, 2024 at 7:14 PM
    #367
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nachi Are good bearings. Guess they say "all japanese bearings are good".
    Rockauto substituted a BCA bearing kit for the Timken I planned on. 2 pinion bearings are Koyo an carrier are NSK. Which I'm happy with.
    I only ordered front/rear pinion seals and front drivers side from fred anderson with the sale. My local Toyota parts has some shims and seals if I need them. Deciding on Toyota fipg or that right stuff by permatex?
    I wrote down a few items from Zuks website.
  8. Nov 28, 2024 at 8:57 AM
    #368
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  9. Nov 28, 2024 at 1:05 PM
    #369
    blenton
    blenton New Member
    I checked with my local wrecking yard for used differentials; the yard is part of the car-part.com network, so I can search parts in other yards/states and have them shipped the wrecking yard for reduced or free freight.
    I can get a front diff for ~$180, but the rear differential is only sold as a full unit - as in, entire rear axle. $1000. Darn. I was hoping to source a used set and rebuild them in the shop over the winter, then swap them when I have some downtime on the truck.
    Mdl, TRDFerguson and FrenchToasty like this.
  10. Nov 28, 2024 at 1:35 PM
    #370
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    When I installed the Auburn it took me 5 hrs. Started at 10 when the kids wet to bed and buttoned it up at 3am. I'm hoping this time around it goes well and no issues. The front will take a bit longer...
    carn_dogg and blenton[QUOTED] like this.
  11. Nov 28, 2024 at 2:53 PM
    #371
    carn_dogg
    Pat
    Eastern Shore MD
    This is a lsd statement alone? Aka no gears during lsd install
  12. Nov 28, 2024 at 3:11 PM
    #372
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yes. Just swapping ring gear to Auburn and reusing the bearings. I probably would of been done sooner but my brake drums were being a PITA.
  13. Nov 28, 2024 at 5:03 PM
    #373
    blenton
    blenton New Member
    My brake drums were also being belligerent when we did the auburn years ago. My buddy pulled out the torch and heated up the outside of the drum for a minute until they made a distinct ‘TINK!’ sound. They slid off east peasy after that. Learned a new trick.
  14. Nov 28, 2024 at 5:35 PM
    #374
    carn_dogg
    Pat
    Eastern Shore MD
    Roger that. Thanks
  15. Nov 28, 2024 at 6:01 PM
    #375
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ok... that parking brake was driving me nuts! Heat. Gotcha!
  16. Nov 28, 2024 at 7:29 PM
    #376
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ecgs shipping $18 for a little bushing? What?
  17. Nov 29, 2024 at 2:19 PM
    #377
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Shims for the rear pinion and carrier. Now I just need the lsd to arrive.
    Edit: the shims will work but ID for pinion head are larger. Toyota shims will have tighter tolerances.
    @carn_dogg after the break in period. I'll put the speedmaster through a beat down and see how it holds up.
    carn_dogg and Silver17[OP] like this.
  18. Nov 29, 2024 at 2:25 PM
    Silver17
    Northeast
    When it blows apart, you won’t know if it’s the counterfeit speedmaster or discount gears. We can wager bets before you open it up. :rofl:
    ZPhilip and Mdl[QUOTED] like this.
  19. Nov 29, 2024 at 3:03 PM
    #379
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Haha. The local gear shop likes Motive gears so hopefully it won't be that. The lsd will be interesting but I called a few places and left msgs. Emailed outlaw offroad that did @Lemuel1 gears and lsd to see their impressions. I'll have to find some cheap tires for my spare wheels to rip up as I'm not going to rip on new shoes...yet.:p
    Silver17[QUOTED][OP] likes this.
  20. Nov 29, 2024 at 3:14 PM
    #380
    carn_dogg
    Pat
    Eastern Shore MD
    Yes. This is good to hear. I’m hoping for the best here. Gears should be quality and have a hard time believing the speedmaster is ass. Mine has yet to ship. I would think Monday at the earliest given holiday and weekend.
  21. Nov 29, 2024 at 5:17 PM
    #381
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    So far so good 250 miles down. Minor whine at low speeds. Got a little off-road today and locker worked amazing.
    Mdl[QUOTED] and carn_dogg like this.
  22. Nov 29, 2024 at 5:18 PM
    #382
    carn_dogg
    Pat
    Eastern Shore MD
    Great to hear!! What’s break in, 500 miles of moderate driving before you can give it the beans?
    Mdl likes this.
  23. Nov 29, 2024 at 5:19 PM
    #383
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    Yes……. I have gently laid into it twice and the change is amazing.
    ZPhilip and Mdl like this.
  24. Nov 29, 2024 at 5:41 PM
    #384
    carn_dogg
    Pat
    Eastern Shore MD
    Glad to hear it. Did you figure out what your install shop meant when they said they had ‘a time’ with installing the gears/lsd?
    Mdl likes this.
  25. Nov 29, 2024 at 6:02 PM
    #385
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    Nah I never asked them, they are closed till Monday anyways.
    Mdl likes this.
  26. Nov 29, 2024 at 6:05 PM
    #386
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I called and left a msg as well as an email to the installer.
    carn_dogg[QUOTED] likes this.
  27. Nov 29, 2024 at 6:47 PM
    #387
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Is the whine when you let off and coast? Hopefully after some more miles and fluid change it will ease up.
    Great to hear about the lsd!
  28. Nov 29, 2024 at 7:01 PM
    #388
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What does whine at let off and coast mean? My regeared diff in my 350Z did that. Got used to it and never got worse, but was annoying.
  29. Nov 29, 2024 at 7:42 PM
    #389
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Could be preload on Pinion is off a bit=loose. Or carrier is set a little tight to pinion or backlash if off a hair. Sometimes everything looks great but could use a little tweak to stop it. Most just live with it.
    ZPhilip[QUOTED] likes this.
  30. Dec 2, 2024 at 5:02 AM
    #390
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Ok, rest of parts ordered.
    • speedmaster limited slip
    • Yukon master install kits front & rear
    I got the front kit from Stage 3 for $489 and the rear kit from Amazon for $399.
    There is an Outlaw Offroad in Nashville. I would love for them to do the install. If they can’t/won’t/whatever, maybe I’ll head to Atlanta to try that Outlaw shop based on @Lemuel1 ’s feedback.
    Going to ask Outlaw if they know anyone near-ish who will cryo treat my gears first.
    Mdl and Silver17[OP] like this.
