  1. Nov 24, 2024 at 9:42 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Lambo club rolling through.
    Asked one of em if his tractor was as fast as it looks.
  2. Nov 24, 2024 at 11:41 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    I think white parking lights would be illegal.
    Tundra2[QUOTED] likes this.
  3. Nov 24, 2024 at 12:05 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Are those crossovers Lambos too?
    I'll take the DC
  4. Nov 24, 2024 at 12:07 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Transborghini's. Probably kit cars. One was definately manual, but most of em sounded like flappy paddles.
    They were cool when they were working with chrysler & before. Now they're a vw shaped like a doorstop.
    455h0le_dachshund likes this.
  5. Nov 24, 2024 at 12:19 PM
    Harsh. Carry on…:burp:
    G_unit3000 likes this.
  6. Nov 24, 2024 at 12:27 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The Lambo engines in the SRT10's was cool
  7. Nov 24, 2024 at 1:07 PM
    Found a spent slug while out hiking. Based on where I am and how it mushroomed, guessing it either landed in sand or flesh.
  8. Nov 24, 2024 at 1:56 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  9. Nov 24, 2024 at 2:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Not really, you just gotta know how to keep it from going where you don't want it :D
    Wrap your Willie (heat shrink) so to speak
    All my switches on the silver truck were completing the negative (ground) side of the circuit so there wouldn't be any actual positive words coming into the cab
    You could wire a switch inline in front of (electrically) the actual toggle switches that opens and closes the circuit going to your switch box if you have one
    shifty` likes this.
  10. Nov 24, 2024 at 2:26 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I took a pair of wire cutters to it and sent that shit into the trash.
  11. Nov 24, 2024 at 3:16 PM
    I wanna install a power antenna from a Land Cruiser in my fender. Here’s one from a similar year J100 I saw in Milano. Looks great to me. And if it only goes up when you turn on the radio, mine will stay down virtually all of the time.
    G_unit3000 and 455h0le_dachshund like this.
  12. Nov 24, 2024 at 3:20 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Yeah, every one of the units had that character. Like the M in MPG, or the F for Fahrenheit, or the M in MPH. I wasn't able to unplug and replug as my scangauge cable is ziptied onto the OBD plug. The pins in the plug are worn out from a scanner being inserted so many times that it won't read unless there's something holding the cable in. Likely would've solved it though- it didn't do it the next time I turned it on.
    I only have MPH because you can adjust it in the settings so you can see an accurate MPH reading. Nice for all the highway driving I do. That MPG reading is also pretty disappointing- I've found that the scangauge reads about 1 MPG optimistic. Ideally that number is closer to 19 or 19.5 at 70 MPH.
  13. Nov 24, 2024 at 4:26 PM
    FishNinja
    Lee
    06DC2wd
    I would have done something similar if I cared for radio/didn't want my intake sucking up all sorts of shit. So fender snorkel it was
    shifty`[QUOTED] likes this.
  14. Nov 24, 2024 at 5:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I too noticed the mention of 17's and up on the Solo's, but not the TC's. Which I didn't think anything of until you mentioned it. So I decided to contact Mr. Wong and ask what he was running. He's got 16's, so all good :thumbsup:
    I just figured worse case scenario I'd have to wait longer to install, since I won't be buying wheels and tires just yet.
  15. Nov 24, 2024 at 5:18 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So it that where your intake inlet is now, the old antenna location?
    FishNinja[QUOTED] likes this.
  16. Nov 24, 2024 at 5:57 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Who was looking for a Samurai?
  17. Nov 24, 2024 at 6:11 PM
  18. Nov 24, 2024 at 7:11 PM
    Im good. Just sold ours last month
  19. Nov 24, 2024 at 7:15 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Looks like the first one already sold since I posted it. Only posted to FBM ten hours ago too. Damn.
  20. Nov 24, 2024 at 7:23 PM
    FishNinja
    Lee
    06DC2wd
    yup
  21. Nov 24, 2024 at 7:35 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I might want to do that. I like it.
  22. Nov 25, 2024 at 5:27 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Well I noticed my truck stumble a little from a stop and at low speeds omw home from work this morning. No CEL yet, but that P0172 is back (pending this time) and it brought it's friends P2196, P2198, & P0175 (also pending).
    This seems to only happen when I let it idle to warm up before I start driving.
    Everything points to rich fuel mixture.
    I'm going to clean the MAF and knock the dust out of the filter, to see if that helps.
    Maybe I'll see if @texoma can re-tune my truck this weekend.
    texoma and KNABORES like this.
  23. Nov 25, 2024 at 5:31 AM
    That stinks. This is my fear with any mods. I want them to add function without taking away reliability. I'm always afraid I'll swap in something for more performance, and then be stuck with issues. Hope you get yours sorted.
    shifty` likes this.
  24. Nov 25, 2024 at 5:33 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Remind me to bring my computer on Friday.
  25. Nov 25, 2024 at 5:48 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Will do.
    Gotta grab MAF cleaner now. Mine is out of aerosol, but the can is more than half full. I guess sitting in the garage in Texas heat for ten or so years will do that lol. Luckily I love a block from two auto parts stores
  26. Nov 25, 2024 at 6:00 AM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    Am I just anxious, or does Toyota usually have their Black Friday special on parts runnin' by now? Maybe seeing all the Black Friday deals running the whole month of November is driving my brain insane waiting for the parts deal to drop.
  27. Nov 25, 2024 at 6:02 AM
    I’m still waiting for my skid plate I ordered a month ago. :(
  28. Nov 25, 2024 at 6:51 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    It's been running great for about a year. I think the MAF and filter were choking the engine after Merus. Panhandle dust ain't no joke. And I was doing donuts in the dirt lol.
    Ran it for about ten mins around town and hiway after cleaning and it feels better. Going to change the oil and maybe do the aerosol seafoam treatment I have laying around, and clean the butterfly.
    bmf4069 and KNABORES[QUOTED] like this.
  29. Nov 25, 2024 at 7:19 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Unplug the battery to let the computer reset? Or, does it auto-learn with a tune?
  30. Nov 25, 2024 at 7:30 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    Disconnect the positive terminal and connect a 1 ohm 10 watt resistor between the positive terminal and ground for a few minutes. That's what I do but I know nothing of electronics.
