Help backing trailer ?
Discussion in '3rd Gen Tundras (2022+)' started by Tb2, Feb 17, 2023.
  1. Feb 17, 2023 at 12:38 PM
    Tb2
    Tb2 [OP] New Member
    James
    What am I doing wrong I have put in the trailer, have pushed button that has trailer icon and when I back the trailer it slams on brakes . I have tried with out pushing button still brakes come on . I feel stupid this crazy do I need to turn sensors off or what
  2. Feb 17, 2023 at 12:56 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    What kind of trailer are you backing up?
  3. Feb 17, 2023 at 1:00 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  4. Feb 17, 2023 at 1:01 PM
    Tb2
    Tb2 [OP] New Member
    James
    Just a single axle 12 ft trailer
  5. Feb 17, 2023 at 1:04 PM
    Tb2
    Tb2 [OP] New Member
    James
    I plugged into the trucks flat pin side .
  6. Feb 17, 2023 at 1:05 PM
    xc_tc
    xc_tc New Member
    The button on the right with the trailer on it is for trailer backup assist but you need to set it up before using. It’s on page 394 of the manual.
    You need to press the PKSB button on the left side of the steering wheel. Has a picture of a car with a cone behind it.
    Rcflyersd and bulldog93 like this.
  7. Feb 17, 2023 at 1:10 PM
    Tb2
    Tb2 [OP] New Member
    James
    Thank you I will try it . I have ready the manual and can not for the life of me figure it out .
    Does the truck have some type of assistance backing up the trailer ?
  8. Feb 17, 2023 at 1:12 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    YouTube would work wonders for you. Search 2022 tundra backing up trailer
  9. Feb 17, 2023 at 1:12 PM
    xc_tc
    xc_tc New Member
    “Trailer Backup Guide is a system to assist when back- ing up a trailer by providing either (1) steering control to assist backing up straight (Straight Path Assist) or (2) guidance for manual steer- ing backup (Guidance mode).
    Trailer Backup Guide uses the rear camera to detect the trailer and a trailer hitch light, which allows the driver to use the system at night time.
    The system calculates the trailer angle by image pro- cessing from the rear cam- era and calculates trailer length and hitch length during the trailer setup (cali- bration) maneuver.”
  10. Aug 28, 2023 at 8:32 AM
    Breathing Borla
    AZ
    I think it just takes practice with trailer backing, it isn’t easy when you first try. Also the shorter the trailer the harder it is
    There is no reason to open the door once you practice it , just need the mirrors and turn around and look out the back window
  11. Aug 28, 2023 at 8:38 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Yes, that is a bit frustrating. I typically back up to a couple feet from the trailer, then get out to check and make sure everything is okay and ready for hookup, then get back in and back up the last couple feet without closing the door - there should not be a need to fully close the door just to open it again 2 feet later, but this truck will not allow it. Just old habits that need to be adjusted.
    Same with not turning the backup sensors off. That thing will slam on the brakes hard! LOL. Scared the crap out of me the first time it happened.
  12. Aug 28, 2023 at 8:40 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    There are some assisted back up features but that depends on the trim level of your truck. I think the Capstone has this and maybe the Platinum/1794 as well.
    I think you need to be in "tow mode" as well so the truck knows that the trailer is there. Otherwise, the truck thinks you are backing into something and slams the brakes on.
    Backing up and trailering does take some getting used to!
  13. Aug 28, 2023 at 9:02 AM
    justcuz
    justcuz 2.5 Gen Member
  14. Nov 12, 2024 at 10:04 AM
    Foolishfrog
    Foolishfrog New Member
    Mitch
    2024 6.5 Pearl Platinum for towing camper
    Somewhere on a post I read here yesterday, in order for the brakes to not slam on you have to plug in the (a) 7 pin trailer connector.
  15. Nov 12, 2024 at 10:16 AM
    Breathing Borla
    AZ
    hit the little crashing into a cone button
    Rcflyersd and Hella Krusty like this.
  16. Nov 12, 2024 at 12:09 PM
    Hella Krusty
    Hella Krusty New Member
    If you have a 7 pin on your trailer, the truck detects the trailer and away you go. If you plug into the 4 flat pin ...what Borla said above
  17. Nov 14, 2024 at 10:43 AM
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    Stupid thing is even when plugged into the 4 pin flat connector the ruck still recognizes that a trailer is connected, this should disable the auto brake IMHO. Why it doesn't is baffling.
    Does anyone else truck take forever to recognize that the trailer is unplugged after you disconnect? Especially if you do not restart your vehicle?
  18. Nov 14, 2024 at 11:22 AM
    Breathing Borla
    AZ
    I think the simple explanation is , it's a complex machine and isn't perfect.
    Ive had the delay in the trailer dropping off once or twice, goes away with a few restarts, again, nothing is perfect, just a software deal.
    it doesn't do anything to normal driving when this happens, so just drive away.
    O, and of course, boost on!
  19. Nov 14, 2024 at 12:31 PM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    The are some things that are a very simple investment of time to disable alerts/functions that can make the truck more enjoyable. Or, you can just complain about it. A very short list, and I'm sure there are more:
    1. Press the crashing cone button you mention to turn off the brake zone application.
    2. Pressing the off button on the left side of the wheel to turn off the audible beeps.
    3. Pressing the start/stop button to turn it off.
    4. Holding down the left side of the cruise control button to turn off the adaptive cruise control.
    22whatwedo and Rcflyersd like this.
  20. Nov 14, 2024 at 1:12 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    It should be mentioned that hitting this button will permanently disable the annoying feature until you hit the button again, even thru start/stop cycles of the truck. Mine stays off 100% of the time.
  21. Nov 14, 2024 at 2:19 PM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    As others have stated, the little 'backing into a cone" icon button down by your left knee should disable the auto emergency braking but not the annoying beeping sound when backing up a trailer
  22. Nov 20, 2024 at 12:18 PM
    Tumbler
    Tumbler New Member
    That is not an entirely accurate statement. If a trailer is connected several of the drive assist functions are disabled. Which is annoying.
    While I agree nothing is perfect it is not complicated to monitor the presence of a wired connection on a continuous basis and change state of an ECU status immediately upon change of connection. Having to restart the vehicle a number of times to clear it is ridiculous. They should do better.
  23. Nov 22, 2024 at 3:24 PM
    Bigbadpoppa
    Bigbadpoppa New Member
    correct me if I'm wrong, the trailer assist does nothing for 90 degree turns right? For some reason I thought it would, but on the vids it's all just for straight lines?
  24. Nov 22, 2024 at 3:34 PM
    Breathing Borla
    AZ
    straight back up only
    I’ve never used mine though , I just back up my own trailer but I’ve been doing it a long time
    I could see this helping newer folks , trailer backing can be hard at first
  25. Nov 22, 2024 at 3:36 PM
    Bigbadpoppa
    ok thanks, I won't fuss with setting mine up. Straight backup isn't my issue, it's the 90degree backups on very tight residential city roads that are my kryptonite.
  26. Nov 22, 2024 at 3:51 PM
    Breathing Borla
    AZ
    understood , just have to practice
    the 360 camera deal
    Helps if you have that
    the shorter the trailer the harder it is to go straight back as well
