Towing reverse question/issue
Discussion in '3rd Gen Tundras (2022+)' started by bthompson12, Feb 10, 2023.
  1. Feb 10, 2023 at 1:00 PM
    bthompson12
    bthompson12 [OP] New Member
    Bruce
    GA
    22’ Blueprint SR5 4x4
    I towed my bass boat the other day for the first time. While attempting to back down the boat ramp the truck kept automatically slamming the brakes on me, which was super frustrating and made it look like I didn’t know what I was doing. It would flash “brakes” on my displays. Is there a way to turn this off?
  2. Feb 10, 2023 at 1:05 PM
    CSilver1794
    CSilver1794 New Member
    Xuyen
    2023 Tundra TRD Pro
    This button should do it.
  3. Feb 10, 2023 at 1:06 PM
    vegask
    vegask New Member
    Kurt
    Northern NV
    2023 Tundra SR5 Premium
    I believe you press the button to the right of the ODO Trip reset button by your left knee. Were you not in tow mode?
  4. Feb 10, 2023 at 1:15 PM
    bthompson12
    Bruce
    GA
    I’ll try that button in the morning. I likely didn’t have it in tow mode either. While in tow mode should it automatically turn that off?
  5. Feb 12, 2023 at 11:30 AM
    JDSTOY
    JDSTOY New Member
    2024 GMC 2500HD, 2022 Limited 6.5, 2000 Limited
    Tow mode does not turn it off. Very frustrating when you are trying to use the truck for truck stuff.
  6. Feb 12, 2023 at 12:02 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My experience so far after 3 camping trips with the Airstream is that I can back up with out the brakes going off on their own. I have the trailer added to the settings along with the brake gain set at 6.0. I do get a message that the safety features are turned off and that is the truck doing that. I haven't had to shut off anything, just plug in the 7 pin connector and the trailer is noticed by the truck software. I have tried towing in normal mode and in tow mode, I am not too sure the difference between the 2 tow modes that show up but I usually just let it pick the first one that pops up on the display. I do notice that the truck takes a few starts to turn the safety features back on after the trailer is parked and disconnected.
    Maybe the issue is the trailer setup or if the trailer uses the 4 pin connector?
  7. Feb 12, 2023 at 12:11 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Did you have the trailer electrical connected? Trailer brakes?
    Every time I've connected a trailer up to the truck, The automatic braking assist is shut off, automatically. Once the trailer is detected, which occurs when you plug in the trailers electrical harness, the truck automatically disables these features. Take a look in the owners manual when you have some time and it will walk you through the process that should be occurring.
  8. Feb 12, 2023 at 2:18 PM
    Duke_962
    Duke_962 New Member
    Nwnj
    2022 tundra sr5 4x4
    Rci skid plate,
    I have a 4 and 7 pin trailer. They disable different things once the trailer is hooked up. Have not tried a 7 pin without tow or tow + modes. 7 pin does shut off more features then 4 pin since there is feed back to the truck via the brake controller.
    Kentucky Tundra likes this.
  9. Feb 12, 2023 at 6:22 PM
    bthompson12
    Bruce
    GA
    So I actually was backing up my buddies boat and it was a 4 pin. I took mine yesterday which has the 7 pin and I had no issues at all backing up the trailer. I periodically pull my buddies boat so moving forward I’ll just have to hit that switch when I do
    Duke_962 likes this.
