Toyota OEM TRD Front Recovery Hooks
Discussion in '3rd Gen Tundras (2022+)' started by RatPanda, Nov 12, 2024.
  1. Nov 21, 2024 at 8:13 AM
    #121
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    My state requires a front license plate. But I really would like to have front tow hooks. Hmm
  2. Nov 21, 2024 at 8:13 AM
    #122
    sudobash
    sudobash New Member
    There are provisions for a front plate on this replacement piece.
    Dfrink and trazerr[QUOTED] like this.
  3. Nov 21, 2024 at 8:16 AM
    #123
    trazerr
    trazerr New Member
    Oregon
    Oh, good to know. Thanks! Makes it more tempting now.
  4. Nov 21, 2024 at 8:36 AM
    #124
    LB-1889
    LB-1889 New Member
    Correct you just remove your existing license plate frame, then I prefilled drilled the dimples, installed with existing fasteners.
    trazerr likes this.
  5. Nov 21, 2024 at 8:43 AM
    #125
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I think they released the kit so it will be easier to tie down on a flatbed? :crapstorm:
    Tom976, Tundyfan and kirkb like this.
  6. Nov 21, 2024 at 9:39 AM
    #126
    H-10BTR
    H-10BTR New Member
    2023 Tundra TRD Pro
    Update 1. No need to remove the whole grill assembly to get the lower valance off.
  7. Nov 21, 2024 at 11:23 AM
    #127
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    So, how did you do it?
    I can see the upper and lower clips holes, how did you access the side ones?
  8. Nov 21, 2024 at 11:24 AM
    #128
    H-10BTR
    H-10BTR New Member
    2023 Tundra TRD Pro
    Goobax likes this.
  9. Nov 21, 2024 at 11:29 AM
    #129
    H-10BTR
    H-10BTR New Member
    2023 Tundra TRD Pro
    I don’t have an air dam so maybe that makes a difference but I just disconnected all the clips holding the valance on from underneath and behind the bumper. It wasn’t difficult to get to them. Install of the new valance was just as simple. It did help to loosen the plastic parts above and to the sides a bit to have more room to work with.
  10. Nov 21, 2024 at 11:31 AM
    #130
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    I have no air dam so that wouldn’t be a factor. Are the cuts you made on both sides? Cannot visualize location(s) due to zoom.
    Edit:
    Never mind, template photo 2.3 shows where they go. :)
    H-10BTR likes this.
  11. Nov 21, 2024 at 11:49 AM
    #131
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    $511.69 delivered is darn decent.
    Just ordered.
  12. Nov 21, 2024 at 12:51 PM
    #132
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Looks good. Kinda wondering if I should paint match mine though. Have a CSM truck and it’s just a lot of dark in the middle area between the grill and lower portion
    H-10BTR[QUOTED] and sudobash like this.
  13. Nov 21, 2024 at 2:30 PM
    #133
    H-10BTR
    H-10BTR New Member
    2023 Tundra TRD Pro
    Done! I love the look so much better in person than in pictures. Looks better without the TRD shackles on imo. Gonna buy some normal sized shackles in red soon. If I did this project again I would 100% leave the grill attached and remove the valance like I described above, that was pretty easy. The only thing I would do differently would be to install the bracket to the bumper prior to installing the new valance. That way will give you a bit more room for a torque wrench. IMG_2741.jpg IMG_2738.jpg
  14. Nov 21, 2024 at 4:20 PM
    #134
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Boooooo... :duel:
    Tunrod[QUOTED] likes this.
  15. Nov 22, 2024 at 8:02 AM
    #135
    H-10BTR
    H-10BTR New Member
    2023 Tundra TRD Pro
  16. Nov 22, 2024 at 8:03 AM
    #136
    I like the red tassels much better
    H-10BTR[QUOTED] likes this.
  17. Nov 22, 2024 at 8:19 AM
    #137
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Looking good. Which ones did you get?
  18. Nov 22, 2024 at 8:19 AM
    #138
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Needs a TRD sticker now
    Breathing Borla likes this.
  19. Nov 22, 2024 at 3:27 PM
    #139
    downthepines
    downthepines New Member
    This is a necessary mod and looks stout. How long are you guys spending on the install?
  20. Nov 22, 2024 at 3:51 PM
    #140
    LB-1889
    LB-1889 New Member
    Did it myself.
    I also plastidiped all the silver body parts behind the grille when I had it off.
    sudobash and 22whatwedo like this.
  21. Nov 22, 2024 at 3:53 PM
    #141
    thomez
    thomez New Member
    NE Ohio
    Silver ‘24 Tundra Platinum
    He asked how long the install took you :)
    Yaboy likes this.
  22. Nov 22, 2024 at 4:14 PM
    #142
    LB-1889
    LB-1889 New Member
    Missed that…since I did some other stuff while I had my front clip off probably 2.5 hrs for the install with the front clip removal would be my guess.
    I have taken the front clip off before so it was much easier the second time around. I also did it by myself, last time I had a buddy.
  23. Nov 22, 2024 at 4:49 PM
    #143
    H-10BTR
    H-10BTR New Member
    2023 Tundra TRD Pro
    Reno 7/8” aluminum shackles from Amazon.
    About 1.5 hours for me. Took my time and had a 4yo “helping” me. I think I saved some time not taking the entire grill off.
  24. Nov 24, 2024 at 3:52 PM
    #144
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Got my kit in the mail yesterday and opened today. No mounting hardware was included though?
  25. Nov 24, 2024 at 4:02 PM
    #145
    LB-1889
    LB-1889 New Member
    Assume you went through every box, there was a lot of packing boxes in mine to fill space. Should have been a bag with 8 bolts and some washers.
    H-10BTR and sudobash like this.
  26. Nov 24, 2024 at 7:45 PM
    #146
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Yeah, double checked and nada. I’ll call the dealer in AM
    sudobash likes this.
  27. Nov 25, 2024 at 6:05 AM
    #147
    Driverwanted
    Driverwanted New Member
    2025 Limited TRD-Off Road Long Box
    Doesn't appear to be available for sale in Canada yet ? Anyone else have luck up north ?
    called 3 dealers - one said it's only able to be installed by them , but they would have to investigate, a second said they can't order it yet and a third said it wasn't a valid part number.
    ordering something heavy like this from the US - the shipping would likely be even more than the part lol. **EDIT**..... LOL Sparks Shipping to me 1041.33 USD
    Anyone in Canada who lives close to the boarder want to go grab one for me ?
    Mrconnsmythe likes this.
  28. Nov 25, 2024 at 7:40 AM
    #148
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Dealer said unusual to come without a hardware kit but they are looking into what can be done. The part numbers for the bolts on the install guide are showing discontinued to them so they can’t order just the parts and said usually there is a part number with HW or HK suffix but they can’t find it and have to call Toyota to figure out what to do next. Said they would be open to ordering another kit and see if it’s in there to file the missing part claim but of course kit is back ordered.
    all that to say, was there anything on the bag of hardware to indicate part numbers for those that got it?
  29. Nov 25, 2024 at 7:41 AM
    #149
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Man that is disgusting. Reality for us though.
  30. Nov 25, 2024 at 7:50 AM
    #150
    sudobash
    sudobash New Member
    Correct. Not in the Canadian parts catalog yet, at least not to order.
