Recommended transfer case oil
Discussion in '1st Gen Tundras (2000-2006)' started by bing5, Nov 16, 2024.
  1. Nov 16, 2024 at 8:54 PM
    bing5
    bing5 [OP] New Member
    New Mexico
    2004 Double Cab. 260k+
    Looking to swap my transfer case lubricant. Don't think it's ever been done in 260k+ miles.
    Is Valvoline or Mobil 1 75w90 gear oil acceptable, or should I pony up more $$$ ? Seems nuts to pay for Toyota-branded lubricants.
    Thanks
  2. Nov 16, 2024 at 8:59 PM
    Either one should be acceptable. I run with Valvoline myself. Might want to do the front diff too if the transfer case hasn’t been done. I assume the rear diff has been done though, right?
    des2mtn likes this.
  3. Nov 16, 2024 at 9:03 PM
    bing5
    New Mexico
    Thanks.
    Had the place where I take it for oil changes do the front and rear diffs a year or so ago.
    Jack McCarthy likes this.
  4. Nov 17, 2024 at 6:50 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    And you're asking about fluid preferences for the T-case? Do you even know what they put in the diffs?
  5. Nov 17, 2024 at 6:56 AM
    I used Mobil1 75w90 LS (full syn) in my t-case.
    FWIW, my t-case oil looked brand spanking new when I dumped it, and I'm 100% positive it had never been changed. I've heard similar commentary from others on here.
    Forewarning: DO NOT overtighten the t-case fill/drain plugs. You can/will strip them out. Heed the torque specs in the FSM on those plugs.
    The only major caveats with the diffs and t-case on this truck are, if you have LSD rear, you have to be really careful about what lube you choose back there (chatter/clutch pack wear), synthetic can be problematic. T-case and front aren't as picky.
  6. Nov 17, 2024 at 12:30 PM
    bing5
    New Mexico
    Ha! Fair point. For 25 years, I let others do my vehicle maintenance. It's only in the last 6 months or so that I've gotten off my ass to start doing a fair amount of it myself. Getting back up to speed...
    Last maintenance of any serious caliber I did was on a 70s-era Chevy with a trusty 350.
    lots to learn. Thanks for all the info, tips, and patience fellas.
    dbittle and ATBAV8[QUOTED] like this.
  7. Nov 17, 2024 at 3:14 PM
    bfunke
    bfunke Tundra Curmudgeon
    I think AISIN made our transfer cases until 2014 when Tundras got Borg Warner T-cases. The newer ones like 70W oil but the old ones are happy with 75W90 oils.
  8. Nov 17, 2024 at 3:25 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    We're here to help! Those three items are super easy, and I think for peace of mind, I would be inclined to just do all three at the same time.
  9. Nov 17, 2024 at 3:49 PM
    bing5
    New Mexico
    10-4
  10. Nov 18, 2024 at 9:05 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Changed fluids in the T-Case and front diff a few weeks back. Glad I did it finally after 7 years and 100K miles of ownership. The best deal on fluid is the Wally world Supertech full syn 75W-90 at ~$10/quart. I also used the Supertech 80W90 GL5 oil for the LSD rear diff and the stuff works perfectly with 0 LSD chatter and no need for additives. I have used Motul 90PA and Lucas 80W90 in the past and this is just as good at $5/quart.
    Pic speaks for itself.
    assassin10000 likes this.
  11. Nov 18, 2024 at 10:45 AM
    Where's the towel for the rear diff and it's schmear? Damn, no wonder you're not hearing any chatter. You done left it out of the picture. :rofl:
    Mustanley[QUOTED] likes this.
  12. Nov 18, 2024 at 11:05 AM
    Mustanley
    Hendersonville, NC
    I didn't bother with rear because that fluid only had 25K on it. I'm responsible dealing with the rear fluid for some reason. That front diff is a pain to refill so I had been putting it off for far too long.
    shifty` likes this.
  13. Nov 18, 2024 at 11:25 AM
    I'm just ribbin' you. My front diff looked like utter ass too. Almost like water had gotten into it on the bottom half of the fluid, some glitter, pile of slurry on the magnet. Here were my pics for comparison. I did this within my first 10k-15k miles of ownership, and quickly realize I should've done the front way sooner, and rear somewhat sooner. https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1549#post-3084622
  14. Nov 18, 2024 at 11:53 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Nice!
    Now there's 3 known good options.
  15. Nov 18, 2024 at 8:05 PM
    bing5
    New Mexico
    Dumb question: is it still necessary to swap the fluid if I rarely use 4WD? We're talking next to never. In 260k+ miles, don't think it's been swapped.
    Also, what's the story with crush washers? My Haynes manual doesn't mention them. Should I plan on replacing?
  16. Nov 18, 2024 at 10:29 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Fluid does age/oxidize/absorb moisture. Wouldn't hurt to change it once in 250k mi.
    Sure you're not using 4x4 but even in 2wd the transfer case is spinning and transferring power to the rear wheels.
  17. Nov 19, 2024 at 5:06 AM
    FYI, if you want the 4WD to continue operating as normal, you NEED to engage it semi-regularly. And you need decent, not-old fluid in there to avoid anything from sticking, seizing, or corroding in place.
    I know, I know, nobody can be bothered to read the damn manual, but ... Toyota warns you about this. If you don't need 4WD, go buy a 2WD. :rofl:
    woodamsc likes this.
  18. Nov 19, 2024 at 7:22 AM
    bing5
    New Mexico
    Knew you were gonna say that! ;)
    shifty` likes this.
  19. Nov 20, 2024 at 8:16 AM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    @shifty is hammering home a good point and that means low range use as well. My truck sat for two years... first time using low range it was a little slow to engage. Exercised system and back to smooth engagement. I would be bummed to troubleshoot this 4x4 system.
  20. Nov 20, 2024 at 8:27 AM
    Who needs to troubleshoot when you have @FiatRunner?! :rofl:
    Best 4WD diag thread ever.
  21. Nov 24, 2024 at 4:59 PM
    bing5
    New Mexico
    Went ahead and swapped the transfer case oil with Valvoline 75w90 synthetic. Really liked the flex fill neck on the packaging. It made is easy to fill. Old stuff just kinda looked like old motor oil in color - deepish brown. Did not see any shavings. Thanks for the tips.
    shifty` likes this.
  22. Nov 24, 2024 at 5:57 PM
    bing5
    New Mexico
    Also drove the truck 20 minutes or so in 4WD low. Hadn't done that in 19+ years if I recall. Had some kinda weird jerkiness towards the rear of the truck when getting rolling from a stop. Normal behavior for 4WD low? Pardon my igorance....likely in the Owner's Manual. RTFM
  23. Nov 24, 2024 at 6:16 PM
    4LO is ultra low like granny gear. Its gonna be jumpy.
  24. Nov 24, 2024 at 6:39 PM
    bing5
    New Mexico
    10-4. Thanks
  25. Dec 13, 2024 at 3:53 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    Hey? Anyone have torque specs for rear diff drain and fill plug? Couldn’t find it on the torque spec sticky thread. Also T-case? The front diff is listed though.
    *edit* rear drain and fill plugs seem to be 39 ft/lbs. t-case is 27 ft/lbs. I haven’t looked these up to confirm just what other people have posted for 00-06 tundras.
    Do not over torque!!!
