New Exhaust System
Discussion in 'Performance and Tuning' started by reywcms, Jan 27, 2024.
  1. Nov 14, 2024 at 7:07 PM
    #751
    blenton
    blenton New Member
    28” helmholtz will knock out 1800 RPM drone. 25-26” is good for ~1950-2050 rpm.
    Wynnded likes this.
  2. Nov 14, 2024 at 7:08 PM
    #752
    centex
    centex New Member
    I’m kicking that around. There’s room to install those but my fab skills to do it are questionable.
  3. Nov 14, 2024 at 7:21 PM
    #753
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    FrenchToasty, centex and RobertD like this.
  4. Nov 14, 2024 at 7:21 PM
    #754
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    Thanks. Thought there was a difference for 2.5 inch vs 3 inch pipe.
  5. Nov 14, 2024 at 8:06 PM
    #755
    blenton
    blenton New Member
    In an open-ended system like a subwoofer vent, it's the volume of air that interacts with the box/driver and resonants, so port diameter is important and is factored in to the resonance. A smaller diameter vent would require a shorter length compared to a larger diameter vent.
    In a helmholtz resonator that is closed on one end, the distance from the opening of the pipe to the closed end is what's important; it creates a mechanical time delay as the sound wave starts at the open end, travels to the closed end, then travels back to to the open end. If that distance is 1/4 of the wavelength of the frequency you are targeting, then it creates destructive interference since it travels 1/4 of the wavelength down, and another 1/4 wavelength back to arrive back in the system 1/2 wavelength different, or with opposing peaks and valleys. That's what cancels the drone/sound. Think about wiring two subwoofers backwards from each other: while one cone moves out, the other cone moves in and you net exactly zero bass. Doesn't matter the size of the woofer if they are wired backwards they will still cancel each other out; tube diameter only determines HOW much is cancelled out, with diminishing returns. So you can cheat and use a smaller diameter tube than the main system with good results.
    Wynnded and reywcms[OP] like this.
  6. Nov 14, 2024 at 8:09 PM
    #756
    blenton
    blenton New Member
    Is SPD running a Black Friday sale yet? I keep waffling back and forth on the downpipes. I've pulled a trailer almost 3k miles in the last month and don't want too much racket... but mo' powahhhh!!
  7. Nov 14, 2024 at 8:15 PM
    #757
    centex
    centex New Member
    Buy the exhaust. You’ll be happy with it. I was and still am. I’m just bored and tinkering because I can. I’ve had zero complaints from my family or friends about the noise while daily driving or towing. I’ve had zero negatives towing the rzr with this exhaust nor driving around town. It’s just a rowdy dumped exhaust. If you’ve had one you’ve had this.
    I’m debating painting my new tips with flat bbq paint just to ensure I get max torque and flow.
    Torque, Chad D., VWTim and 1 other person like this.
  8. Nov 14, 2024 at 8:37 PM
    #758
    blenton
    blenton New Member
    That's my hold up - a rowdy dumped exhaust is a little too rowdy for me. My current exhaust isn't exactly boisterous, but it can be somewhat vociferous at times. I've driven my truck around kinda straight piped for a day and it wasn't for me...
    I also don't usually tow anything as small as a razor. I often do two or three hours on the highway 70 MPH with a few thousand feet elevation gain sometimes. Done and too much noise can be fatiguing.
    :rofl::rofl::rofl:
    bflooks likes this.
  9. Nov 14, 2024 at 10:26 PM
    #759
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I understand the way it works. I thought another exhaust maker stated 2 separate charts for a a 2.5 inch system and a 3 inch. Although I only had the 2.5 inch one.
    Thanks again...
    blenton[QUOTED] likes this.
  10. Nov 14, 2024 at 10:32 PM
    #760
    blenton
    blenton New Member
    I apologize if I spoke to you as if on my high-horse. That wasn't the intention, but sometimes my filters glitch a little and words vomit forth.. If they did post a chart, I'd be interested to see it. I have not seen one in all of my research but that doesn't mean I'm opposed to learning more about it.
    RobertD, Torque and Mdl[QUOTED] like this.
  11. Nov 14, 2024 at 10:43 PM
    #761
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I did transpose my column for the rpm's and length so appreciatemy bad info. I didn't take it any other way than more information out there how it cancels the drone. It's all good.
    RobertD, Torque and blenton[QUOTED] like this.
  12. Nov 15, 2024 at 4:54 AM
    #762
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    The downpipes do ratchet up the sound a lot with the same catback under higher loads. It took my catback from mild to wild under heavy throttle. It didn't annoy me on the towing trip I just had, but I’m still in the phase where I’m totally entertained by it. I also have side exit duals so with the windows up it’s not too bad, but with the windows down driving through town it’s pretty loud. It will definitely draw some attention. Idling and low throttle driving though it is not much louder than just the catback.
    I am curious about those valvetronic mufflers with a valve that either goes to straight through with almost no noise cancelling, or through a chambered portion of the muffler that may even be quieter than stock. Could be perfect with a set of the midpipes. You can have either option at the push of a button.
    blenton[QUOTED] and Torque like this.
  13. Nov 15, 2024 at 6:58 AM
    #763
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Agri-Cover,RCI skid,ADARAC,Fox 2.0,TruDuals
    Dynomax used to have a muffler with a butterfly valve that did a similar thing. The more throttle, the more the valve opened and let the eagles fly. If I recall correctly, you could adjust the tension but complaints of it rattling or getting stuck open/closed ran rampant on the Dodge forums. This was years ago so not sure if they still make it. The valvetronic mufflers sound ideal especially the video I saw a while back where they installed a set on a Mustang and connected it to ODB2 so it was synced with throttle position.
    Silver17[QUOTED] and ZPhilip like this.
  14. Nov 16, 2024 at 11:00 AM
    #764
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Spoke to Keith yesterday and sent him pics of the pipe dump over the axle along with measurements. He is fabbing up a couple resonators for this particular exhaust similar to what he has available on his site:
    They will mount on the downhill slopes of both tailpipes and aim in the direction of the driver side. Will update with more info once they arrive and I get them installed. He estimates a 20-50% drone reduction.
    Mdl likes this.
  15. Nov 16, 2024 at 11:08 AM
    #765
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I dumped mine I put the hemholtz before the muffler. When I spoke with him he said he gets a lot better reduction after the muffler.
  16. Nov 16, 2024 at 11:11 AM
    #766
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep, and since there really isn't much pipe coming out of the muffler on this system, the best position for them is coming down from the highest point of the bend over the axle (per Keith). He even had Terry, his shop guru, in the background of the phone call discussing placement.
    Mdl[QUOTED] likes this.
  17. Nov 16, 2024 at 11:18 AM
    #767
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    That's about the only place you can put them and clear the spare tire when they are positioned 90deg to the direction the tailpipes are running. On the uphill portion, youd have potential interference with the driveline or fuel tank.
    I figured if drone was bad on my system, I'd tap into the uphill portion but run them forward the front parallel to the rest of the system using some elbows, similar to Magnaflow or TWC solutions.
  18. Nov 16, 2024 at 11:19 AM
    #768
    centex
    centex New Member
    I’d be interested in a set. I took the tips off I made today and think I’ll leave them off unless I tow. Above 2000 they are fine and the noise is gone but the drone below 2000 was just annoyingly loud. The dumped exhaust is way tamer in that it’s not a drone it’s just the exhaust note.
  19. Nov 16, 2024 at 11:23 AM
    #769
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Initially, he was planning to put them there (on the incline). I don't have a spare tire mounted on the underside so I have plenty of room in the aforementioned placement. The resonator going on the passenger side pipe will have a "T" mount with the resonator bending 90 deg toward the driver side. It'll look pretty funky but no one will be able to really see it.
  20. Nov 16, 2024 at 11:24 AM
    #770
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What tips did you have?
  21. Nov 16, 2024 at 11:32 AM
    #771
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    He'd need to know the angle of the incline though.
  22. Nov 16, 2024 at 11:40 AM
    #772
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    He's built many systems like this before so he understands the design. The first idea he was bouncing around looked like your picture, but it got scrapped for the post-bend placement.
  23. Nov 16, 2024 at 11:51 AM
    #773
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    He originally, back a few years, had them placed right after the muffler bending back over the top but you get better drone reduction placed where he stated.
  24. Nov 16, 2024 at 12:25 PM
    #774
    reywcms
    reywcms [OP] New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    You could run this with a helmz in the x-pipe like they do for other kits. And the direction doesn’t matter. We’ll be doing a straight pipe opposite direction on the old man’s exhaust
    JMGmanAZ, MVRCA, blenton and 4 others like this.
  25. Nov 16, 2024 at 12:51 PM
    #775
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    That looks badass too.
    I believe 26-28" length is needed to kill drone at 1800ish RPM
    reywcms[QUOTED][OP] likes this.
  26. Nov 16, 2024 at 1:43 PM
    #776
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    honestly 3" with carven TRs are great. i dont mind hearing a bit of exhaust though neither beside i also have the stereo :rofl:
    just ran out about 30min away yesterday and was running 70-80mph and its was actually pretty quiet
  27. Nov 16, 2024 at 1:56 PM
    #777
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I tried this way but didn't kill all the drone. Will follow Keith's advice to put it aft of the mufflers. Know it's not SPD but kill that drone...
  28. Nov 16, 2024 at 1:58 PM
    #778
    centex
    centex New Member
    Just some I built out of 3”.
    Mdl likes this.
  29. Nov 16, 2024 at 2:01 PM
    #779
    centex
    centex New Member
    I love the way this sounds. Just like to experiment and tinker. Sometimes it’s a win and sometimes it’s not.
    Torque likes this.
  30. Nov 16, 2024 at 2:32 PM
    #780
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    There so many quality exhaust shops in Conroe and Houston that can weld that up.
