Reminder for 2020 owners with factory warranty still left..
Discussion in '2.5 Gen Tundras (2014-2021)' started by Gort, Nov 14, 2024.
  1. Nov 14, 2024 at 2:52 PM
    Gort
    Gort [OP] New Member
    Canada
    2020 Tundra SR5+
    Reminder for 2020 owners with factory warranty still left, check your timing chain cover for an oil leak. Our trucks/engines are around that age where if you have the oil leak issue it can begin to show.
    I'm at 77000 KM or 48000 Miles and the dealership just found a slight leak on the timing chain cover during the inspection.
    My warranty runs out March 2025 so after some humming and hawing about the quality of dealership work, I called back and asked them to see if its covered and if they can do it, they confirmed and they booked me in right away with no hassle.
    If you're familiar with this issue you know it can be a costly fix down the line. As its one of the few things known to go wrong with these engines it's worth checking it out while you still have warranty and save yourself thousands of dollars.
  2. Nov 14, 2024 at 3:00 PM
    JohnWhicker
    JohnWhicker New Member
    Is this a recall for this or is it documented? Thanks for letting us know. I have a 2021 with just 7000 miles on it but is good to check it anyway. I also have extended warranty for 10 years on it.
  3. Nov 14, 2024 at 3:56 PM
    I have 49K on my 2020 and no issues at all.
  4. Nov 14, 2024 at 4:01 PM
    Gort
    Canada
    2020 Tundra SR5+
    Not a recall from what I know, but a common issue you usually need to go after Toyota pro-actively for.
  5. Nov 14, 2024 at 4:06 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    If I ever get a cam tower seep I'm going to milk it until the end of time.
  6. Nov 14, 2024 at 6:37 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That’s a new issue for me.
  7. Nov 14, 2024 at 7:32 PM
    Gort
    Canada
    2020 Tundra SR5+
  8. Nov 15, 2024 at 5:36 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Ahh Interesting. Something to definitely watch out for. Unfortuantely, my miles are way past factory warranty lol
  9. Nov 15, 2024 at 5:39 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I have a 2021 with 50k. It always smells a little like burned oil after I drive it. Sort of assumed it was just the undercoating. But that should have burned off a long time ago.
  10. Nov 15, 2024 at 6:10 AM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    How long ago did you undercoat it?
    I went a little crazy w my thickness of fluid film undercoat last yr and it stunk for like 2 months. Lol
  11. Nov 15, 2024 at 6:15 AM
    Chris001
    Chris001 New Member
    Ontario, Canada
    2018 Tundra Double Cab SR5
    LED interior, tint, auto lock tailgate, Rhino Liner, Blacked out emblems
    I've had the timing cover seep for 5 years and dealer would not touch it as its not a leak. I just periodically check the oil level and all is good so far.
  12. Nov 15, 2024 at 7:09 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    2020 Platinum with a little over 50k on it, no can tower or timing cover leaks visible. rear differential housing has some very light weeping around flange, just looks like stain, no liquid visibly leaking.
  13. Nov 15, 2024 at 7:42 AM
    ScenicRoute
    October 2022 was last time it was done.
  14. Nov 15, 2024 at 8:07 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I have tiny bit, but honestly I don't trust dealership to do a good job, I'll re-seal everything properly when building a new engine.
  15. Nov 18, 2024 at 8:08 PM
    Gort
    Canada
    2020 Tundra SR5+
    My biggest fear, but I am a pretty detail oriented person and I'll hold them accountable if anything related to it messes up.
  16. Nov 18, 2024 at 8:18 PM
    yakeng
    yakeng 3URFE Apologist
    I’m at 78,000 on my 2020. No leaks, but even if I did have a warranty and a leak, no way I’d ever had the dealership monkeys touch it.
    Tunrod likes this.
  17. Jan 25, 2025 at 9:36 AM
    Gort
    Canada
    2020 Tundra SR5+
    Got the service completed a little while back, here is my quick review. They made no fuss about it being covered by warranty, they called me back right away to book it in and had my truck in for a total of 3 days and they provided me with a courtesy car for the duration.
    I got the truck back in good shape! No weird noises or any strange feelings while driving it. I took the truck through its paces as well and tested out driving on the highway, some light 4x4, some quick starts and stops, and no weird behavior. Maybe I got lucky but I'm glad its fixed.
    TheBeast and 18DCTRD like this.
  18. Jan 30, 2025 at 9:43 AM
    Dallas007
    Dallas007 New Member
    Dave
    2021 Tundra Pro Max
    How come most people don’t like dealership service departments but when buying a used truck the fact it has “regular dealer service records” it’s a good thing?
    Jaypown likes this.
  19. Jan 30, 2025 at 3:30 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    I'm at 71k on my 2020. No leaks. No way to know if it has anything at all to do with it, but from the 1st OCI's on all my cars, I use HM oil formulations. It hasn't hurt anyway.
  20. Jan 30, 2025 at 5:17 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    I echo the OP’s message. Took my 21 in yesterday for the timing cover repair under warranty. Truck has 48k at the time of diagnosis in Jan. 7, 2025. So, it’s being work on at the moment. Was told it would take up to 2 days for the work.
    Gort[OP] likes this.
