1st Gen camper shell buying info
Discussion in 'Tonneau Covers, Caps and Shells' started by shifty`, Mar 26, 2021.
  1. Nov 14, 2024 at 2:00 PM
    #1891
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Waiting on someone to come help me put it back on :ballchain:
  2. Nov 14, 2024 at 4:34 PM
    #1892
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Mostly straight now. Definitely not impressed with these clamps. Going to order another set for piece of mind and use all 8. The four the PO included are too small. No clue how he made em work.
    Thanks for the ratchet strap idea.
  3. Nov 14, 2024 at 8:13 PM
    #1893
    shifty` [OP] Just like witches at black masses
    I have good clamps I think. I might’ve shipped to another member already. I need to look.
  4. Nov 15, 2024 at 7:24 AM
    #1894
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I can't find this "ratchet strap" idea...what's the idea exactly? I can't figure out what you're doing with it.
  5. Nov 15, 2024 at 8:00 AM
    #1895
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Trying to suck in the bottom rear corners to the rear window. I had some major gaps.
  6. Nov 15, 2024 at 8:11 AM
    #1896
    Stopped by a camper shell and truck accessories place to ask about replacement window tracks. Unobtainium. Replace the whole window they say.
  7. Nov 15, 2024 at 8:16 AM
    #1897
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Boo
  8. Nov 15, 2024 at 8:17 AM
    #1898
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    thanks for asking as I was lost on this as well.
    So does the strap stay on full time?
  9. Nov 15, 2024 at 8:31 AM
    #1899
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    No, once you got it where you want it, you put in the rear clamps then remove the strap.
    OldGuy03[QUOTED] likes this.
  10. Nov 15, 2024 at 8:42 AM
    #1900
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    That makes way more sense. And also genius.
    NickB_01TRD likes this.
  11. Nov 15, 2024 at 9:28 AM
    #1901
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I don't remember who told me to do that. Maybe it was @Sirfive
    Hell or might've been a different thread or even a different tundra forum.
  12. Nov 15, 2024 at 9:40 AM
    #1902
    MT-Tundra
    Montana
    Oh wow, thanks. Yeah, great idea. Sirfive. Am I the only one who tries so hard to avoid looking at his damn avatar? :D I'm not squeamish, just butchered a deer last night. But I hate looking at that photo :rofl:I'm sure that's exactly the reason he's using it.
    JakeJake and FrenchToasty like this.
  13. Nov 15, 2024 at 10:01 AM
    #1903
    There's other Tundra forums?? :confused:
    OldGuy03 and FrenchToasty like this.
  14. Nov 15, 2024 at 10:03 AM
    #1904
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Yeah, they aren't particularly busy and have annoying ads, but sometimes there's diamonds in the rough between the community and info.
    OldGuy03 likes this.
  15. Nov 15, 2024 at 10:04 AM
    #1905
    Kidding of course. The ads are brutal over there.
  16. Nov 15, 2024 at 10:04 AM
    #1906
    So is the Tom foolery
  17. Nov 15, 2024 at 10:05 AM
    #1907
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    :laugh: I hadn't even noticed, since I use my phone, the avatars are tiny. But I've seen that dog's balls in real life so many times, it doesn't even faze me
    OldGuy03 and MT-Tundra[QUOTED] like this.
  18. Nov 15, 2024 at 10:06 AM
    #1908
    Used that forum back in 2006 for my Tundra related inquiries. I can't keep up with both these days.
  19. Nov 18, 2024 at 4:28 AM
    #1909
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    :wave:
  20. Nov 18, 2024 at 5:37 AM
    #1910
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Mystery solved. Thanks for the tip. It worked pretty well. But my clamps are kinda cheap, so I ordered another set and will likely do the ratchet strap one more time. This time I'll crank it on both sides, not just the driver. Lessons learned
  21. Nov 18, 2024 at 6:15 AM
    #1911
    NickB_01TRD
    KY
    I like the way you did yours. I used one really long strap.
    Two of my clamps are just basic C-clamps to go along with my 4 topper style clamps.
  22. Nov 18, 2024 at 6:24 AM
    #1912
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    It's just too bad these clamps slip n slide and I didn't think to crank the passenger side come-along any. Definitely got it snugged up better than before. But I think I can do it even better next time and hopefully be done with it. I need to pick up the front anyways, to add a strip of double bubble to the bed rail closest to the cab. I can still see sunlight through it now. I'll be using all 8 clamps when the next set of four shows up. The four the PO included are tiny. I have no idea how he got them to fit his truck, because he already had the top off.
  23. Nov 18, 2024 at 6:27 AM
    #1913
    Drill holes and bolt that sumbich down
  24. Nov 18, 2024 at 6:28 AM
    #1914
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I might. I want to be sure I go it exactly where I want it first and no leaks.
    I used some thin metal brackets I cut onto 1"x2.5" pieces to try to widen the bite of the clamps. Maybe I'll wrap those in some old t-shirt material in the future.
  25. Nov 21, 2024 at 7:56 AM
    #1915
    ZDog377
    ZDog377 03 V8 AC 4x4
    If anyone is looking for a cap near Pittsburgh PA. I'm nearby and can take a look at it for you if you want.
    OldGuy03 and shifty`[OP] like this.
  26. Nov 21, 2024 at 8:15 AM
    #1916
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    RCLB Aluminum ARE with barn doors. $600 in Denver
  27. Nov 22, 2024 at 5:53 AM
    #1917
    ZDog377
    Contactor one with the doors in Pittsburgh Pa for $500. DC cab
  28. Nov 22, 2024 at 8:26 AM
    #1918
  29. Nov 24, 2024 at 9:53 PM
    #1919
    Lundy
    Lundy New Member
    San Diego
    2004 Dual Cab V8, Automatic, 4x4, SR5 w/tow pkg
    $2000, Maybe it'll fit?
    462881772_929358428636301_72399308371170_9891434e096bcadedba1cbfbd6240954e019f869.jpg
  30. Nov 25, 2024 at 4:25 AM
    #1920
    950# dry weight. Could probably make it work.
