General Supercharger Thread
  1. Nov 12, 2024 at 7:21 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I got it all finished up and put the new belt on, starts and idles just fine, checked for leaks and got it up to temp. I'll get to test it out tomorrow morning and keep an eye on IAT delta, and listen for squealing.
    Other than needing longer mounting hardware and a longer belt, everything else fits without issue. My air filter is in a better spot and is no longer rubbing, hood clearance is also not an issue.
    ZPhilip, e30cabrio, jhrrld and 7 others like this.
  2. Nov 13, 2024 at 4:19 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    I'm tempted to do it, i have the maggy 2650 though, just eyeballing it, looks like the hat of the 2650 might come into contact with the cowl, or at minimum be very close to it with 1" spacers.
    Mdl likes this.
  3. Nov 13, 2024 at 7:06 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Mine has a few inches yet to the top of the rotor pack, a little less at the pulley where the hood slants down, I'll try to get an actual measurement.
    Update: I'm pretty sure my torn o-rings had been a problem for a while, it drives like a new truck today, the part-throttle bog down is no longer occurring, and it was super responsive. The belt is no longer squealing, just a chirp when shifting. Very happy with the results, I'll have a longer drive at lunch to check IAT deltas.
  4. Nov 13, 2024 at 7:22 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Any chance to snap a pic of the fuel rail to see what spacing it provides. After looking at the area I'm not sure I could squeeze in a nozzle for extra juice. Or maybe a port at an angle? Thanks!
    Wynnded and reywcms like this.
  5. Nov 13, 2024 at 7:44 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    On the outside, there isn't much room between the spacer and the rails, I would install the ports on the valley side of the spacers under the SC, tons of room under there now. Unfortunately I never got a pic of the spacer-port interface.
  6. Nov 13, 2024 at 8:44 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Awesome! Looks like you at least resolved an issue with those o-rings. Looking forward to your impressions on the runner.
    e30cabrio and reywcms like this.
  7. Nov 13, 2024 at 12:59 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Feels amazing, but that could be because I fixed a vacuum leak and installed new spark plugs...IAT deltas are lower 15-17F above ambient while driving, 20-33F above ambient while parked and idling for ~5 minutes. I've seen it get 50F above ambient while idling for 20-30 minutes in the pick up line at school, so I'll have to check that again when in that situation.
    No more squealing belt, just a chirp at start up and when shifting, so I'm very happy with the results...and I have a nice stealthy solution for Water/Meth later.
    Saltyhero13, Wynnded, Mdl and 5 others like this.
  8. Nov 13, 2024 at 1:01 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    SO much room for the sneaky bits! Nice work! Trend setting is fun! :dancingbacon:
    Mdl, reywcms and e30cabrio like this.
  9. Nov 13, 2024 at 1:52 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    wonder how these will do with a Mag 2650
  10. Nov 13, 2024 at 2:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice! @e30cabrio has an Aquamist W/M that is great for setting up a multi port w/m injection. If I wasn't doing the gears and lsd I'd be on getting the runner setup and all the other goodies.
  11. Nov 13, 2024 at 4:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Oh and Wheelers Offroad started their black Friday sale. Their front super bump stops look good for the SC'd tundra hitting a big old pot hole when you can't slow down in time...:p
  12. Nov 13, 2024 at 5:08 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I actually really like their super bumps, been running a set up front for a couple years.
  13. Nov 13, 2024 at 5:30 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Put on the green belt a few months back and now have a noise tied to rpm in the belt area. Replaced the belt with the OEM Mag belt and same sound. Now going to replace the two idlers and tensioner/idler. I hand spun each idler when the belt was off and at least one did seem odd. 50k miles, supercharged 34k of those. Hopefully not the alternator or power steering bearings. Ive exploded a belt on a Mustang once where an idler seized so now these noises make me paranoid.
    e30cabrio and HulkSmurf14 like this.
  14. Nov 13, 2024 at 5:44 PM
    NatesNightMare
    Pinetop Az
    i honestly may be thinking my odd sound is coming from the blower coolant pump
    Mdl and HulkSmurf14 like this.
  15. Nov 13, 2024 at 5:48 PM
    HulkSmurf14
    2014 Tundra Limited
    @Ponderosa_Pine Swap your idlers when doing your tensioner! Easy insurance... don't use aftermarket unless you love doing it over...
    @NatesNightMare Pull the fuse on the pump and see if the noise changes for a minute...
  16. Nov 13, 2024 at 6:02 PM
    NatesNightMare
    Pinetop Az
    ill try and remember tomorrow
  17. Nov 13, 2024 at 6:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Had an idler seize on me over the summer and shredded the belt. 100k on the idler changed it out along with new tensioner have one more idler to swap out to be in the clear.
  18. Nov 16, 2024 at 5:21 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Offtopic warning.........
    Weird seeing Tim Hortons, Renaults and MGs.
  19. Nov 16, 2024 at 6:16 AM
    Tundras.com Forum Santa
    Tundras.com Forum Santa Milk and Cookies
    Santa
    3" Lifted Sleigh. sPOD lights on each reindeer. HeftyFab sliders
  20. Nov 16, 2024 at 7:58 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Judging by the knocked over traffic pylons, they have Mustangs there too.
  21. Nov 16, 2024 at 1:51 PM
    e30cabrio
    The drivers here take all reasonable movement and behavior as a suggestion. ignore all of them.
    helidave[QUOTED] and HulkSmurf14 like this.
  22. Nov 18, 2024 at 10:31 AM
    helidave
    flagstaff
    2015 DC 4x4
    I bought a used ecm to keep as a spare. Can I install it, program my vin and immobilizer with techstream, start the truck, and then remove it without having to reprogram anything with the stock ecm? I want to verify the junkyard one works before the warranty expires but I don't want to mess anything up with the stock one.
  23. Nov 18, 2024 at 11:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If I recall correctly, you can do it.
    helidave[QUOTED] and Wynnded like this.
  24. Nov 18, 2024 at 2:32 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Well boys. Headed to level10 tomorrow morning. Looks like my stock trans is a goner. Dropping off tomorrow for a week and having Pat rebuild mine into a ‘built’ trans.
  25. Nov 18, 2024 at 2:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Man...a few failed these past few months! I'm a:fingerscrossed:!!
  26. Nov 18, 2024 at 2:34 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Yeah I’ve been expecting it for a bit. It’s been acting up and then slipped quite a bit yesterday coming home from a camping trip. Wife drove it today and came back with a few codes.
    NatesNightMare and Mdl[QUOTED] like this.
  27. Nov 18, 2024 at 2:57 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Damn. I really gotta do that VB upgrade. When I had my rack bushings done I had the trans flushed and he said the fluid wasn’t burned but it was definitely ready to be changed. Had 30-40k on that fluid.
  28. Nov 18, 2024 at 3:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Last year I had that p2714. Supposed to be bad news for the tranny. A few have gotten away with fluid/solenoid changes.
    I'll be having to think about the transmission sooner than later. Doing the VB upgrade was told 50/50 that it would help if caught soon enough.
    ARES35 and HulkSmurf14 like this.
  29. Nov 18, 2024 at 3:06 PM
    carn_dogg
    Pat
    Eastern Shore MD
    Glad to hear you’re still going strong after having gotten it. Did you have any of the other codes? As I understand it, the trans just has too much debris from it coming apart and passage ways are blocked. Nothing can fix other than rebuild. Wish it wasn’t the case.
    ARES35 and NatesNightMare like this.
  30. Nov 18, 2024 at 3:11 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Having replaced two transmissions, I would definitely recommend installing a valve body kit and a trans cooler (immediately) for supercharged applications. Otherwise a full rebuild will eventually be likely. It seems like there is an exponential impact of adding more hp/torque above the original 500hp TRD dealer option.
