Extremely Cheap! 5.29 gears. Motive gears OK?
Discussion in 'Performance and Tuning' started by Silver17, Oct 5, 2024.
  1. Nov 1, 2024 at 4:53 AM
    #241
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Ignore this, the kit is actually unavailable. No wonder it was so cheap lol :anonymous:
    Mdl likes this.
  2. Nov 1, 2024 at 5:00 AM
    #242
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Happens to the best of us. I went with stage 3 motorsports they sell Yukon front and rear kits.
    BreyTundy[QUOTED] likes this.
  3. Nov 1, 2024 at 5:15 AM
    #243
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Did you go with the master or mini install kits?
  4. Nov 1, 2024 at 5:31 AM
    #244
    Silver17
    Silver17 [OP] Used, but returned and sold as new member
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Im wondering how easily the front bearings can be removed without destroying them to reuse them. @VWTim said Zuk doesn’t normally replace them since they typically have so few actual rotating miles on them. It would be sweet to just need the mini install kit for the front and save a boatload of money. Otherwise I’m waiting for a Black Friday sale to hopefully find the front master kit cheaper.
    Mdl likes this.
  5. Nov 1, 2024 at 5:36 AM
    #245
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Yeah I'm in the same boat as you, the pricing difference is at least worthy of investigation. My heart says a complete overhaul is never a bad idea, but my wallet says my heart is a moron
    Mdl, Lemuel1 and Silver17[QUOTED][OP] like this.
  6. Nov 1, 2024 at 6:14 AM
    #246
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    Master install kits
  7. Nov 1, 2024 at 8:06 AM
    #247
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Ps: when I worked for an auto company Yukon couldn't be discounted by promo code, but could manually be discounted up to 10% IIRC. Call/chat with a sales rep and you might be able to swing a better deal.
    Lemuel1, BreyTundy, Mdl and 1 other person like this.
  8. Nov 1, 2024 at 5:09 PM
    #248
    ARES35
    ARES35 New member for life
    Mile high
    Received a few days ago. Just like everyone else been searching on the best deal on master kits :spy:
    Lemuel1, Mdl, BreyTundy and 1 other person like this.
  9. Nov 1, 2024 at 5:25 PM
    #249
    Silver17
    Eastern PA
    I’m jealous that everyone else is getting theirs in a cooler box than me.
    ARES35, Mdl and FrenchToasty like this.
  10. Nov 1, 2024 at 6:18 PM
    #250
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Same! We got the dork boxes
    Silver17[QUOTED][OP] and Mdl like this.
  11. Nov 1, 2024 at 6:26 PM
    #251
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You should be able to remove them without damage. I plan on reusing my front bearings and getting the mini kit for the front. I already reused the rears for the Auburn. I may get a mini kit for the rear if I can get some deals on bearings and a few thinner shims to go along with the mini kit. I'll be searching around black Friday deals! I'll be doing the install myself, even though it's been a bit.
    ARES35 and Silver17[QUOTED][OP] like this.
  12. Nov 1, 2024 at 6:26 PM
    #252
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My fronts were in a plain black box...
    Silver17[QUOTED][OP] likes this.
  13. Nov 1, 2024 at 8:33 PM
    #253
    blenton
    blenton New Member
    For anyone interested in an Auburn GripNLoc limited slip, Tandem Offroad has two units available in the garage sale section with 20% off (with discount code). They are also restocking units from Auburn in the next couple of weeks for their Black Friday sale which I suspect will be 15-20% off as well. Email them and ask for Alex; tell him you hear a little birdie might be giving pre-black Friday pricing on it.
    The GripNLoc has supposedly been updated with a different cone and clutch design than my old Auburn Pro, but I can't seem to get any details about it other than 25% more torque bias. My Auburn Pro has been great and worth every penny. I am switching to a Powertrax unit that's sitting on the shelf for the simple reason that the Auburn chews through friction modifier more quickly than I would like. I suspect my towing and hauling have a lot to do with that; it's also been doing it since way before I installed the Whipple. On the plus side, I KNOW the LSD still works after almost 7 years and 130k+ miles.
    I bring up the Auburn mostly because the Powertrax appears to be NLA. I'm actually tempted to pick one up and sell the Powertrax... but I think the Powertrax will suite my needs a little better.
    https://shop.tandemoffroad.com/coll...r-10-5in-grip-n-loc-limited-slip-differential
    Silver17[OP] and AZTundra like this.
  14. Nov 1, 2024 at 9:59 PM
    #254
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you drive pretty normal the Auburn will do well. If your a spirited driver the clutches won't last. I know myself and several others on Tundratalk burned the Auburn up within the year of install.
  15. Nov 1, 2024 at 10:05 PM
    #255
    blenton
    blenton New Member
    Yup. Burnouts will do that. Haha. The Auburn was the only one available able the time, so I just closed my eyes and scrolled past all of the posts about dead Auburns on the forums. I have been honestly impressed that it has survived up to this point. I don't usually try to spin my tires on pavement, but in the snow and ice - well, that's a different story. There's a roundabout between my shop and house that gets slicked up late at night. Sometimes the truck just ends up going all the way around it. It just keeps turning left even though I have the wheel turned to the right. I can't explain it. Unfortunately, there's a cop shop 1/4. mile down the road, too. Fortunately, I may or may not have witness police cruisers suffering the same ailment in the same roundabout...
    Mater and Mdl[QUOTED] like this.
  16. Nov 2, 2024 at 4:39 AM
    #256
    bflooks
    bflooks New Member
    Metrowest MA
    I haven't looked at the Motive install instructions but the Nitros were a soft 500 miles, then a quick break-in specifically for towing. It was only 2 heat cycles or something minimal, and it was all done before the first drain/full. Polished or not, I'd follow the towing part at a minimum, especially our weights and profiles.
    This is just my.02. opinions seem to vary on any break-in process, with or without polishing. I just didn't want to pay for things twice so a few days of break-in was worth it to me. Regardless, can't wait for you to report back on your towing. You're going to love it.
    Mdl, Mater and Silver17[QUOTED][OP] like this.
  17. Nov 3, 2024 at 12:26 AM
    #257
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    I would definitely re-use the front bearings. Especially if the diff was maintained reasonably well. Would probably re-use the rears as well unless they had really high miles. But I would make that decision when I pull them apart and get to look at them and feel them. Any experienced gear installer should have the tool to pull the bearings without damage.
    My friend threw an auburn in the rear and said the bearings looked like new with 200k and reused them. I'll be doing the same with my grip pro install with similar mileage.
    Same with ring gear bolts. My friend reused his and so will I. Zuk and nitro gear have said they are fine to re-use. Make sure to use red loctite.
    ARES35, ZPhilip and Mdl like this.
  18. Nov 3, 2024 at 12:41 AM
    #258
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Lots of pullers out there that can grab the cage of the bearings without damaging them. I've had to re-use a lot of bearings in my time and never had a failure from them.
    I also wanted to say that long burnouts will kill an Auburn and our transmission. I've already been through it.
    ARES35, ZPhilip and j_supra[QUOTED] like this.
  19. Nov 6, 2024 at 1:48 PM
    #259
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    So now that Motive is blowing out gear sets, when are they gonna discount their master install kits?
    Mdl likes this.
  20. Nov 6, 2024 at 1:56 PM
    #260
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Man I hope so. Their install kits are on the upper end of the pricing scale that I've seen.
    Mdl likes this.
  21. Nov 10, 2024 at 8:12 AM
    #261
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Sigh
    <unzips>
    Gears in house.
    Lord knows when I’ll have time to actually research the rest. Hoping to let @TRDFerguson figure it all out first
  22. Nov 10, 2024 at 8:25 AM
    #262
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    @memario1214 is supposed to be sourcing master install kits for me and I’ve got a couple lines on donor diffs at local pick and pull yards… but I’m still a ways out lol
    memario1214 and FrenchToasty like this.
  23. Nov 10, 2024 at 8:31 AM
    #263
    RainMan_PNW
    Casey
    Clark County, WA
    would be tiddies to get everything down to Zuke in Prescott beforehand, and I could just roll into T2S and swap out in camp... :muscleflexing:
  24. Nov 10, 2024 at 8:46 AM
    #264
    Let’s do it!!
    Mater and TRDFerguson like this.
  25. Nov 10, 2024 at 9:00 AM
    #265
    ZPhilip
    Philip
    West Chester, PA
    I thought about going that same route of sourcing junkyard cores and building them at home and swapping when time allows. My search started and ended at eBay when I saw rear third members at like $900, fronts were much cheaper. I was dreaming of finding some cores for $200 and diy it.
  26. Nov 10, 2024 at 9:02 AM
    #266
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I found a front diff for $100. The rear I’m hoping I can get for sub-$500 but doubtful that’ll happen… I also thought about DIYing in my garage, but I don’t trust myself to set it all up right.
    CaptRussia253, Mater and FrenchToasty like this.
  27. Nov 10, 2024 at 9:22 AM
    #267
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Clamshell for rear is cheap on carpart.. but then you gotta get a locker. Gunna end up paying one way or the other; might as well make it great!
  28. Nov 10, 2024 at 9:54 AM
    #268
    RainMan_PNW
    Casey
    Clark County, WA
    Goddammit
    Now I’m shopping lockers
    Fuck fuck fuckity fuck
  29. Nov 10, 2024 at 10:05 AM
    #269
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    I spent a good chunk of time this AM looking at sites (JEGS, summit, etc) and was assuming 20% off for BF + free shipping. Given my tax rate here, even with 20% off, Mr. Haeffner came out on top. Unless there’s a glitch on Amazon, pretty sure that’ll be most people’s best bet.
  30. Nov 10, 2024 at 10:06 AM
    #270
    FYI zuk won’t install ARB…….
    I think one of the plumbing bros can hook you up with a Elocker
