Magnuson Magnum 2650
Discussion in 'Performance and Tuning' started by Fspmdt, Aug 8, 2023.
  1. Nov 9, 2024 at 8:18 AM
    #181
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    So you’re saying I need more boost
  2. Nov 9, 2024 at 8:18 AM
    #182
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I consistently hit 8-10psi with pops up to 12 psi everyday on my little 1900. The 13-14psi is only on special events. That thing is a whiner but I understand we're talking about its big bro. Whines over the 3 inch exhaust from LT's on back.
    snivilous, Wynnded and reywcms like this.
  3. Nov 9, 2024 at 9:14 AM
    #183
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    Would you do 650s or 750s on the 76mm? Man why are injectors so expenisive... do you know if I can run the stock maggie pump with bigger injectors ?
  4. Nov 9, 2024 at 9:36 AM
    #184
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    with the pulley and tune i hit 7-9psi up here but like sniv said im not constanly running WOT etc. even now i could use bigger injectors but shes runs great. ive even traveled to lower elevations and while towing
  5. Nov 9, 2024 at 9:38 AM
    #185
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The 650s will be fine, but frankly they get tapped out pretty fast and aren't a huge bump over the 535s the Magnuson comes with. The issue with larger injectors is you start to run into quality concerns. I would prefer a 750 injector or even larger, but the DW injectors which ive had good luck with are only offered up to 650. The 650 should be able to run at 10-12 psi fine, especially if you bump fuel pressure with the TurboKits bolt on regulator. But you don't have much fueling to spare (with that said, 650 is the most common size people run and without issue).
    The Magnuson pump is the limiting factor if you run larger injectors. Someone on the forum (I forget who has what setups) did some testing (with the 76mm at sea level) and did the DW650s first and got a boost in fueling, and then did the DW300 pump afterwards and got more fueling, meaning the Magnuson pump was limiting the flow from the 650s but the 650s alone did give a bump, just weren't fully unleashed without the pump upgrade.
    Ctaylor76[QUOTED] and reywcms like this.
  6. Nov 9, 2024 at 9:40 AM
    #186
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I can definitely hear my blower with my spd exhaust but it’s not a Maggy lol
  7. Nov 9, 2024 at 9:48 AM
    #187
    Ctaylor76
    Chaz
    Houston
    Yeah maybe I wait a little longer get the 750s bigger pump do it right and go with 72mm
    Having to redrop the fuel tank such a bitch.
  8. Nov 9, 2024 at 10:54 AM
    #188
    Ctaylor76
    Chaz
    Houston
    Your talking about this kit Toby with the 650s and stock pump ?
    https://www.turbokits.com/mwr-fuel-regulator-and-return-kit.html
  9. Nov 9, 2024 at 10:57 AM
    #189
    snivilous
    SW UT
  10. Nov 9, 2024 at 11:02 AM
    #190
    Ctaylor76
    Chaz
    Houston
  11. Nov 9, 2024 at 11:08 AM
    #191
    snivilous
    SW UT
    Yea, bolts in. It'll make whatever injectors you have flow more since you can crank the pressure a bit. Couple guys running it.
  12. Nov 9, 2024 at 11:17 AM
    #192
    Ctaylor76
    Chaz
    Houston
    So i could possibly run that with the 650s do like a 76mm pulley without having to drop the tank and swap the pump ?
    NatesNightMare likes this.
  13. Nov 9, 2024 at 11:37 AM
    #193
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’d say do the pump. Higher fuel pressure at the regulator doesn’t mean more flow if the pump can’t supply the volume at higher RPMs to maintain that pressure. The magnuson pump probably won’t cut it.
    j_supra, Mdl, Wynnded and 2 others like this.
  14. Nov 9, 2024 at 11:55 AM
    #194
    NatesNightMare
    Pinetop Az
    you think magnuson would have put a bit better stuff in thier kits for the price they are
    Silver17[QUOTED] and koditten like this.
  15. Nov 9, 2024 at 12:06 PM
    #195
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    The stock kit pump and injectors are fine for the stock pulley, and that's all magnuson cares about
    Ctaylor76, snivilous and Silver17 like this.
  16. Nov 9, 2024 at 2:04 PM
    #196
    Ctaylor76
    Chaz
    Houston
    Yeah it really is, but I'll probably buy that regulator kit first.
  17. Mar 2, 2025 at 1:48 PM
    #197
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    In my thoughts they made the TRD blower which I never had an issue with in my Tacoma.
    Yeah....I know this is a bit old but I'm getting ready to install the Maggie in my 2016 Tundra.
  18. Mar 2, 2025 at 2:08 PM
    #198
    Saltyhero13
    Saltyhero13 Throbbing Member
    Preference. Which is different than a performance or functional benefit.
    Wait...you're not even the person I asked.
  19. Mar 2, 2025 at 2:42 PM
    #199
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    LOL...Pay attention.
  20. Mar 2, 2025 at 3:30 PM
    #200
    Silver17
    Eastern PA
    Yeah! Like this! :stirthepot:
  21. Mar 2, 2025 at 3:53 PM
    #201
    Saltyhero13
    Well people around these here parts don't normally answer questions they weren't asked.:hattip:
    Jacking with you by the way.
  22. Mar 2, 2025 at 4:29 PM
    #202
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    LOL..i've been asking every where.
    I'm pushing 60 and dont have a lot of time to F around.
    Wynnded and Saltyhero13[QUOTED] like this.
  23. Jun 23, 2025 at 3:21 PM
    #203
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Pretty old post, but I happened to be reading through it today and it's worth while mentioning that for the 2650 kit, Magnuson is supplying 480cc Denso injectors, not 535cc. Not sure why they chose to donwsize from the original TRD 1900 pump, but kind of annoying that they have been choked down even more!
    This information is coming direct from Magnuson when my current tuner contacted them to get information on my injectors and fuel pump.
  24. Jun 23, 2025 at 4:22 PM
    #204
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    Damn, they really don't want anyone exceeding the stock output. No warranty with bigger pulley. Bare minimum fuel pump. Now bare minimum injectors! Lame. Makes it seem like they don't have faith in their own product lol
  25. Jun 23, 2025 at 5:14 PM
    #205
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Stock injectors are reported to be 42lbs which equals 440cc. What's the point???
    snivilous likes this.
  26. Jun 23, 2025 at 5:19 PM
    #206
    snivilous
    SW UT
    That's what I was thinking, 535 already wasn't a big step up, 480s are insane, not even a 10% increase? That seems weird, so weird I question what their rep said.
    reywcms, Wynnded and Mdl like this.
  27. Jun 23, 2025 at 6:00 PM
    #207
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    He was just the phone guy. :tinfoilhat:
  28. Jun 23, 2025 at 9:31 PM
    #208
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Agreed but it was through email and he forwarded the response to me. Said Denso 480cc injectors and 240lph pump...
  29. Jun 23, 2025 at 9:44 PM
    #209
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    The more I think about this, the more I'm convinced they gave the wrong information and what concerns me is my tune is being written with this in mind.
    From the 1900 to the 2650, including the 2650 upgrade kit, the tunes are all the same so no way they changed to smaller injectors.
  30. Jun 23, 2025 at 10:04 PM
    #210
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
