Heated seats not working
Discussion in 'Electrical' started by DarknessReigns, Nov 22, 2023.
  1. Nov 22, 2023 at 7:46 PM
    DarknessReigns
    DarknessReigns [OP] New Member
    I have a 2019 Platinum and both front heated seats stopped working.
    First thing that came to mind was a blown fuse, but I cannot find any fuse for Seat Heaters.
    Any ideas?
  2. Nov 22, 2023 at 8:51 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Which fuse panel did you check? There’s one in the cab by the footwell or the engine bay.
  3. Nov 26, 2023 at 4:37 PM
    DarknessReigns
    I checked both footwell and under the hood.
    There is no Seat Heater fuse in either of them.
  4. Nov 26, 2023 at 4:49 PM
    Patch999
    Kyle
    2017 Bad@$$ TRD Pro
  5. Nov 26, 2023 at 7:00 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Looks like the seat heater gets power from the IG No. 5 fuse.
    Where that is, IDK..
    upload_2023-11-26_20-57-33.pngupload_2023-11-26_20-57-54.pngupload_2023-11-26_20-58-24.png
  6. Nov 28, 2023 at 3:50 PM
    DarknessReigns
    Thank for your reply. I actually pulled that same diagram from another post I found on here with the electronic PDF's. Problem is, I do not have an IG No.5 fuse. I have all the way up to IG No.4 But that is it.... Still stumped by this.. Not sure if because my truck is a platinum, there are more electronics and the seat heaters run off another fuse somewhere?
  7. Feb 10, 2024 at 4:38 PM
    bkcottrell77
    bkcottrell77 New Member
    Did you ever figure out what the problem was? I have a 2014 limited that is having the same problem. Both seats quit warming at the same time.
  8. Feb 11, 2024 at 5:23 AM
    DarknessReigns
    Hey! I apologize I failed to come back to respond to this. I ended up bringing my truck to the dealer to diagnose it and it turns out, it was my fault. I had pulled the fuse (under the hood) and put it back in the wrong spot! As soon as the fuse was back in the right place, the heat started working again.
  9. Nov 7, 2024 at 6:58 PM
    Timsem
    Timsem New Member
    2021 Tundra TRD Pro
    I have an issue with my seat warmers. Which fuse was it exactly?
