Reverse lights
Discussion in '3rd Gen Tundras (2022+)' started by paradizecityz, Jan 17, 2022.
  1. Jan 17, 2022 at 4:28 PM
    paradizecityz
    paradizecityz [OP] New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Didn’t think the reverse lights were enough so what do I do? Add more lights!!
    Taco-Spike and BlueRibbon4x4 like this.
  2. Jan 17, 2022 at 9:13 PM
    SnowRunnerTundra
    SnowRunnerTundra New Member
    2022 Hyundai Santa Cruz Limited
    nice, on my Tacoma it was halogen so I swapped to high output LED bulb and life is good
    but the new Tundra come with LED reverse lights already and I don't think they can be easily swapped, so adding that might be the easier way.
    How was tapping into the reverse light wires? Do you have to figure out which wire is which in order to get it to work? or the light is non polar?
    paradizecityz[OP] likes this.
  3. Jan 18, 2022 at 8:37 AM
    paradizecityz
    Richmond, TX
    Yeah, I've always changed the reverse lights to LEDs, even on my 2019 and I still added this lol
    More light works for me with dark window tint, it just helps
    Tapping into the reverse lights was very easy and with the 2022, the reverse lights being in the bumper instead of tail lights, its even easier access. Took me like 10 minutes to do with most of my time being used to clean up and make it look nice
  4. Jan 19, 2022 at 6:41 AM
    Keepontrying
    Keepontrying New Member
    da Burgh
    2022 TRD OR, CM 6.5 ft. bed, Blueprint (aka Black, Blue or Purple)
    Can you post the product that light bar? And you just spliced it into the back up light hot wire?
    Thanks. as I get older need all the help seeing when i back up.
  5. Jan 19, 2022 at 6:51 AM
    Looks like the VLEDS one.
    https://www.vleds.com/lp-reverse-72-w-5500k.html
    paradizecityz[OP] and Taco-Spike like this.
  6. Jan 19, 2022 at 7:00 AM
    Taco-Spike
    Two Trucks
    VLED bar posted above ^
    Yes, it comes with T taps to just splice. They're okay, not water proof, better when used inside the cabin and not exposed to elements.
    I would suggest getting or making an actual reverse light harness that connects to the reverse wiring connectors with a IP rated pigtail VLED 2 pin connecter for this. No hacking factory wiring that can short if wet, moister build up and corrode.
  7. Jan 19, 2022 at 7:06 AM
    paradizecityz
    Richmond, TX
    Yup, it's the VLEDs License Plate Reverse lights:
    They supplied everything and you don't have to splice anything. It comes with a DUO Tap so you'll just put the wires through it. Once done, I wrapped everything with electrical tape and tucked it away so hopefully it won't be an issue with water or elements :)
    Taco-Spike[QUOTED] likes this.
  8. Jan 19, 2022 at 7:09 AM
    Taco-Spike
    Two Trucks
    Duotap* I forgot what it was called. :thumbsup:
  9. Jan 19, 2022 at 7:22 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    have tan all generations of their LPF and love them, kept the one off my 19 for my 22
  10. Jan 19, 2022 at 7:27 AM
    paradizecityz
    Richmond, TX
    I had the one on my 2019 as well. Wish I kept that so I could save some money for other mods lol
  11. Jan 19, 2022 at 8:28 AM
    SnowRunnerTundra
    in your 2022 Tundra, is there a red wire and a black wire like the photo shown, and is that how you tapped them? I assume that tap is single use, and you can't redo it if wrong wires are tapped
  12. Jan 19, 2022 at 8:31 AM
    paradizecityz
    Richmond, TX
    Yes, if you look under the truck at the reverse lights, you'll see the red, black (could be white/black cable, can't remember) and they also have a green. I tapped into the red and black.
  13. Jan 19, 2022 at 8:37 AM
    Taco-Spike
    Two Trucks
    I don't have a 2022, maybe OP could help with color wires but I would think it would be the same?
    That is how you tap it, as shown in the picture.
    You can use them more than once, but you have to be careful if you pry them open not to damage the claps tabs that crimp the wire in place. I've used these T duotaps, T single taps, single and double straight taps more than once when re-wiring. Also be careful about the wire itself doing multiple taps. If it doesn't work the first time, swap the wires in the same splice / tap location.
  14. Nov 1, 2024 at 9:58 PM
    Rocco2Gen
    Rocco2Gen New Member
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    Can anyone tell me where you tap in with the DUOTAP.
    Was it in the tail light housing?
    I question because the reverse light is in the bumper.
    Help understanding the tap in location would be greatly appreciated!
  15. Nov 1, 2024 at 11:17 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
  16. Nov 2, 2024 at 2:59 PM
    Rocco2Gen
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    Solid option and I might go that direction.
    Thank you!
