  1. Oct 30, 2024 at 9:56 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    as @TRDFerguson and @BiggHertz mentioned all forward gears neutral. Reverse holding strong lol
  2. Oct 30, 2024 at 9:57 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    you sent me the site…
    TOYOTARIG, ATV25, HulkSmurf14 and 2 others like this.
  3. Oct 30, 2024 at 11:03 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I was thinkin' the same $hit!!!
    AZTundra[QUOTED] and reywcms like this.
  4. Oct 31, 2024 at 9:19 AM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Gotta teach them young lol. In my defense, just installed new ceiling lights from Costco in my son’s room. It’s the brightest room for a good picture.
  5. Oct 31, 2024 at 9:30 AM
    Reddawg1100
    Reddawg1100 New Member
    FL
    21 SR5 Midnight Black DC, AKA: Bat Truck
    Custom rims, front leveling spacers
    What tool and/or method did you use to remove the stock bumps? I've got a set of superbumps I need to put on.
  6. Oct 31, 2024 at 9:32 AM
    JrJrOffroad
    JrJrOffroad Somewhere in the west
    Anthony
    Monument, CO // Cave Creek, AZ
    Just a set of channel lock pliers- they came off pretty easy.
    Reddawg1100[QUOTED] and BR73 like this.
  7. Oct 31, 2024 at 9:41 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Big pair of channel lock pliers and for me it was easier with the wheel removed for more room to work
    Reddawg1100[QUOTED] likes this.
  8. Oct 31, 2024 at 10:13 AM
    Reddawg1100
    FL
    That looks awesome, can't believe you made that out of legos! ;)
  9. Oct 31, 2024 at 10:18 AM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    So I'm shopping for bump stops for my 2020 as crossing a few rutted and muddy places going camping and hitting bumps on the gravel I drive on every day caused it to bottom. I've looked at Perry, Timbren....is there any difference, any better than each other?!??! Thanks
  10. Oct 31, 2024 at 10:29 AM
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    I’m pretty happy with my Wheelers super bumps on the front. I have a set to go on the rear when I pull the airbags and put the RAS system on. I threw the fronts on a day before a 2500 mile trip around Southern Utah. They improved the ride so much that even the girlfriend and kids commented on it.
  11. Oct 31, 2024 at 10:30 AM
    Fobroader
    Alberta
    2020 Platinum
    if the wife commented something positive about a mod, thats good enough for me, thank you good sir!!!
  12. Oct 31, 2024 at 10:34 AM
    Fobroader
    Alberta
    2020 Platinum
    Also, why do the fronts of all only come with two bump stops when there are 4 oem bump stops?!?! To me that would seem like a good way to apply a nice torsional load on your LCA when it does hit, I think I'm going to order 4 for the front.
    Vizsla and Bprose like this.
  13. Oct 31, 2024 at 10:52 AM
    I keep waiting to see an axle, leaf springs, or engine block on the kitchen table. I think he is well aware of his wife's tolerance window lol. If he ever disappears, we should look for oil or grease on the carpet. :D
  14. Oct 31, 2024 at 11:04 AM
    Vizsla
    Vizsla 2 = 2.5
    I agree. Noticed a pattern resulting in damage on trucks used very hard, enough to remove mine (in hindsight there was no reason for me to have them with a secondary shock). Probably fine for most uses.
  15. Oct 31, 2024 at 11:32 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    I have 4 on the front of mine. Wheelers in the back and Perry parts in the front.
  16. Oct 31, 2024 at 11:32 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    I've got Wheelers Super Bumps up front and Sumo's on the rear PXL_20241020_212847189.jpg PXL_20241020_212833905.MP.jpg
  17. Oct 31, 2024 at 11:42 AM
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    Pattern? What are you seeing? I went back and forth on trying to understand why the front bump stops only came with 1 for each side, but after discussing on here and with the vendor I was under the impression that was the intended use. Are there others suggesting the need for 4 up front?
    250000yota and BR73 like this.
  18. Oct 31, 2024 at 2:32 PM
    250000yota
    Russ
    Berthoud, CO
    I’m pretty happy with my Wheelers super bumps on the front. I have a set to go on the rear when I pull the airbags and put the RAS system on. I put them on the day before a 2500 mile trip through southern Utah. They improved the ride so much that both my girlfriend and son commented how much nicer the truck rode while off road.
    BlueRibbon4x4 likes this.
  19. Oct 31, 2024 at 3:17 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Watching the Super Bumps installation video and they say just replace the one...hum I wonder why?
    2014 Black tundra likes this.
  20. Oct 31, 2024 at 3:24 PM
    Vizsla
    Vizsla 2 = 2.5
    Broken motor mounts and bent frames, I did both when my truck was MT (3” lift Fox coilover) running aftermarket bumps. But again on trucks used hard, likely beyond the design limitations of the chassis. My truck is LT and heavily reinforced front and rear now. This is a pic from when I ran one of the popular bumps that dented (red arrow) a very strong LT lower control arm before the front oem bump engaged. IMO this supports the torsional load @Fobroader mentioned. No idea if 4 is the correct choice, never gave it a thought after reinstalling the oem bumps.
  21. Oct 31, 2024 at 4:18 PM
    redrum448
    redrum448 New Member
    Dont laugh (this is my first truck) ...what do they do?
  22. Oct 31, 2024 at 4:25 PM
    RobertD
    Robert
    DFW, Texas
    Bump stops keep moving parts from hitting stationary parts. In the front, the bump stops keep the lower control arm from hitting your frame. The stock bump stops are small and a very hard dense rubber (I think) its jarring when the LCA hits them. Most of these aftermarket stops have a larger profile but a softer composition so they help soften and slow the LCA so its less of a stop and more a deceleration.
    Pretty similar with the rear, your axle moves up and down and the bump stops helps keep it from hitting frame.
  23. Oct 31, 2024 at 4:59 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Accomplished a bit of DIY maintenance today. Rear diff drain n fill, power steering drain n fill, and HVAC blower motor upgrade w/ K&N cabin air filter. :yay:
    Blower motor upgrade is by far an amazing improvement!
  24. Nov 1, 2024 at 6:14 AM
    redrum448
    I figured they prevented "collisions" obviously but I thought it was in extreme conditions not "all the time" ... interesting
  25. Nov 1, 2024 at 6:20 AM
    250000yota
    Russ
    Berthoud, CO
    This exactly. The advantage to the Wheelers super bumps is they are a lighter, softer material, that gives more of a progressive slow down rather than the hard rubber factory bumps. Per the instructions for the Wheelers bumps, you retain the front factory bump stops (seen in the back in my photo, photo taken from the back looking forward) so that if you hit a big enough bump, and use up all of the travel of the progressive Wheeler bumps, you still stop the up travel of the suspension before it hammers the frame. These bumps are kind of a step between the factory bumps and a full set of hydraulic bump stops.
    Here is the kit I basically pieced together. I bought the fronts second hand from a guy who never installed them, then bought the rear kit to go with my RAS once I pull my air bags off.
  26. Nov 1, 2024 at 6:27 AM
    RobertD
    Robert
    DFW, Texas
    Its kinda between the 2. You might not touch them every day, but it's not just extreme. Do you ever go over speed bumps or accidentally hit a pothole? Those are 2 common situations where you will likely contact the bump stop.
    With these aftermarket ones they really smooth out those situations. Some swear they feel the difference like night and day, others say they kinda tell. Like most truck mods, its in the end user to determine if its worth it but this is not a bad mod to consider.
  27. Nov 1, 2024 at 6:28 AM
    Tripleconpanna
    Sorry it took so long to confirm this... But, we've been getting hammered here on the coast this past week, so I figured it would be a good time to update. The last couple of days we've had a ton of rain and wind gusts up to 60mph... So, at this point, I can say w/absolute surety, that the drawers are pretty damn water tight :thumbsup: I had no sign of water intrusion after this last week's endeavors.
    Just to be fair though, my decked system is sitting under an ArmorFlex tri-fold tonneau cover. So, I'm sure there's a little bit of deflection from that system, but with that being said the way the decked system is engineered and w/the gaskets properly secured, etc. I'm pretty confident that the system would still be pretty darn secure...
    ATV25 and bulldog93 like this.
  28. Nov 1, 2024 at 7:00 AM
    CaptRussia253
    Ruslan
    Painted the sliders for the 4runner and picked up a brand new cvt mt Shasta for the Tundra. Couldn’t pass up the $500 deal!
    rdiddy5, Gaston, mgm16trdpro and 10 others like this.
  29. Nov 1, 2024 at 7:03 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    How was the Power Steering drain and fill? Been tossing around the idea of doing this soon as well
    CaptRussia253 likes this.
  30. Nov 1, 2024 at 7:20 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    You have the sickest fleet of rigs out there
