Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. Aug 2, 2024 at 4:58 AM
    #2461
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Hey GoJo - i appreciate your help. Would you check one thing for me please?
    Take a listen when the radio is on, or and streaming music.
    Are your dash speakers working?
  2. Aug 2, 2024 at 7:59 AM
    #2462
    GoJo
    GoJo New Member
    UTAH
    2019 Tundra SR5 CM Silver Sky
    Yea they are working, my fade also working as it should as well.
    purplenova[QUOTED] likes this.
  3. Aug 2, 2024 at 8:12 AM
    #2463
    purplenova
    Tom
    Ohio
    Thanks so much for your help.
  4. Aug 2, 2024 at 1:00 PM
    #2464
    purplenova
    Tom
    Ohio
    does anyone know how to change the default "Android" boot logo?
    Cant find info anywhere
    I have the new G13 Model HA2220H2
  5. Aug 2, 2024 at 5:53 PM
    #2465
    GoJo
    GoJo New Member
    UTAH
    its in the system settings can't remember the exact tab, but same place you go into to change the microphone settings but a couple tabs to the left
  6. Aug 3, 2024 at 1:32 PM
    #2466
    purplenova
    Tom
    Ohio
    I ended up doing the same. Sent back my Amazon order and saved some money. Not what I wanted to do but, oh well.
    burt_macklin[QUOTED] likes this.
  7. Aug 5, 2024 at 4:31 PM
    #2467
    purplenova
    Tom
    Ohio
    Are these the parts to you bought to use factory GPS antenna?
  8. Aug 5, 2024 at 4:48 PM
    #2468
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    yes, on the 10.2 unit that I currently have
  9. Aug 5, 2024 at 5:10 PM
    #2469
    purplenova
    Tom
    Ohio
    Same unit I have.
    Just making sure I order the correct parts.
    Thanks
  10. Sep 14, 2024 at 8:07 PM
    #2470
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Hey my Dasaita 10.2 Android HU will continuously scan while using the radio and I'm scratching my head as to why.I'm sure it's operator error:annoyed:
  11. Sep 15, 2024 at 4:26 PM
    #2471
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Well finally starting to figure out this head unit thanks to this forum
  12. Oct 30, 2024 at 10:06 AM
    #2472
    ahenning33
    ahenning33 New Member
    Andy
    Payson, AZ
    2014 Super White Tundra SR5 TRD
    Hello all,
    Been reading through the 83 pages of this thread and am now super confused and have a headache lol.
    Was wondering if anybody could get me the down and dirty of what I need to install this headunit https://www.dasaita.com/products/da...ad-unit-optical-output?variant=45764601807066 in my 2014 non-jbl crewmax
    I would like to reuse the factory antenas and usb slots and retain the option of having sirius. If possible I'd also like to have the ability to view tpms, engine & trans temp, etc.
    Also, would you recommend ordering directly from Dasaita or piecing everything together from Amazon.
    Thanks a bunch!
  13. Oct 30, 2024 at 10:34 AM
    #2473
    purplenova
    Tom
    Ohio
    I have that exact unit in my 2016 Non-JBL. Maybe i can help or make matters worse. lol
    The factory antenna will be retained as there is a plug-in for it in the new HU.
    The GPS antenna - there are several posts within the group that show the items purchased to retain the GPS antenna. I however experienced intermitten connections using the factory gps antenna so i just ran the dasaita antenna and all is well.
    The usb slot under the HVAC control is retained. The dasaita has connections for that as well.
    The tpms and the trans temps are a toss up.
    You can download the Torque app to the Dasaita and using the ELM327 OBD2 adapter you might be able to see the temps, i honestly dont know becase I dont use it..
    I might be wrong, the 2014 SR5 doesnt display TPMS on the dash does it? If not, i believe you will need an add on using a USB connection. (dasaita has that add-on, but Amazon probably has it as well and cheaper)
    There are two places on the Dasaita that report TPMS and neither of
    which would work for me, even though Dasaita says it should.
    Sirius XM - not aware of an add on for the Dasaita, unless you already have found one or asked Dasaita
    From what ive read, you can downlad the Sirius app onto the head unit and run it from there.
    Be prepared to have all tech support from Dasaita come at least a day after you ask. They are in China!
    All updates to the OS are available on their website. - https://www.dasaita.com/community/forum
    FB page -https:// I purcahsed mine directly from their website - i would suggest using Amazon if possible and pay close attention to the return policy, just in case !!!
    ahenning33[QUOTED] likes this.
  14. Oct 30, 2024 at 10:35 AM
    #2474
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I went with this one, plug and play. Just make sure to get the harness that matches the year and it all just plugs in. You can then get a bluetooth/wifi OBD dongle and use whatever monitoring app you want. I happen to use Car Scanner Pro.
    https://www.amazon.com/dp/B0CM5PKPGK?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
    ahenning33 and purplenova like this.
  15. Oct 30, 2024 at 7:53 PM
    #2475
    ahenning33
    Andy
    Payson, AZ
    I appreciate the info. How long have you had that unit your truck? Any issues or buyers remorse?
    You would be correct in saying that the '14 SR5 doesn't display tire pressure and it's not a deal breaker, just thought it would be a cool feature
    BR73 likes this.
  16. Oct 30, 2024 at 7:56 PM
    #2476
    ahenning33
    Andy
    Payson, AZ
    Thanks for info, I'll look into the OBD dongle. How long have you had your head unit? Any issues so far?
  17. Oct 30, 2024 at 8:06 PM
    #2477
    purplenova
    Tom
    Ohio
    Had it since July.
    Had issues with the fade function not working but after several updates from Dasaita it seems to be ok now.
    I initially had buyers remorse but now that it's all seems to be working correctly I'm ok with it.
  18. Oct 31, 2024 at 4:01 AM
    #2478
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    I have the same unit in my 2020 SR5 and all is good.You will need to purchase a SIM card to use the apps thru the head unit which I still haven't done.I use Android Auto most of the time anyway.You will need to adjust sound levels and play with the equalizer for better sound.
  19. Oct 31, 2024 at 5:27 AM
    #2479
    drgordon13
    drgordon13 New Member
    2020 Gray Tundra TSS
    So after much deliberation I purchased this unit:
    https://www.amazon.com/dp/B0CP39NX1Y
    Couple of quick questions before I attempt the install...
    What the heck is the canbus? Is that for steering wheel control? If so does it tell you where to use it and it is included right?
    I have a non JBL no amp 2020 SR5
    External mic or not? I have read mixed reviews!
  20. Oct 31, 2024 at 5:29 AM
    #2480
    drgordon13
    Dasaita Android 13 Radio for Toyota Tundra 2014-2021, 10.2 Inch QLED Touchscreen, Wireless CarPlay, Android Auto, 5G WiFi, 4G LTE, DSP, GPS Navigation, 6GB+64GB
    Link didn't show description so just wanted to show which unit I bought.
    BR73 likes this.
  21. Oct 31, 2024 at 5:52 AM
    #2481
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Canbus is for the Carplay with iPhone that plugs into the unit.I plugged up the external mic but I'm going to go back in and remove it because I get a lot of feedback thru the unit when talking on the phone
  22. Oct 31, 2024 at 5:53 AM
    #2482
    purplenova
    Tom
    Ohio
    The canbus is needed to utilize the steering wheel controls and it will plug into the small connector on the provided harness.
    You will/should get tow bags clearly labeled with the harness id. Make sure to use the correct harness. The canbus box is use
    by both harness's, so you will only get a singel canbus box. See the attached pic.
    Look under your front passenger seat, you should see a black plastic box/cover - that is the amplifier.
    The mic seems to be a mix of good and bad reviews. My wife can here me good if im parked, but once i start driving, the sound is lower, i think due to
    external road sounds. but there is supposed to be a fix the require additinal hardware. I will try and find that info.
    Found it ! - LOL
    Dasaita mic adapter
    https://www.dasaita.com/.../dasaita-microphone-adapter-3...
    External microphone
    https://shop.enfigcarstereo.com/product/enfig-mic-toy1/
    Install video
    https://youtu.be/rIR7upVoHS4?si=zrn-RuYIqzUrcAE4
    BR73 likes this.
  23. Oct 31, 2024 at 6:16 AM
    #2483
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Thanks for the link and info.... I'm ordering today :yes:
  24. Oct 31, 2024 at 6:26 AM
    #2484
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    It shows for an Android 12 but it looks like it will work on a 13 hopefully
  25. Oct 31, 2024 at 6:55 AM
    #2485
    purplenova
    Tom
    Ohio
    Good catch - i did not pay atention to that description. I did see on the Dasaita facebook page that others are suing the same method
    to get a good call quality. Will need to ask Dasaita if this is also for A13 units
    BR73[QUOTED] likes this.
  26. Oct 31, 2024 at 6:57 AM
    #2486
    purplenova
    Tom
    Ohio
    !!! Wait on ordering that microphone and adapter. There is a note on the dasaita website regarding G12 units
    I just sent Dasaita an emial to their support person ive been interacting with.
    Probably wont get an answer till tomorrow morning.
  27. Nov 1, 2024 at 5:58 AM
    #2487
    purplenova
    Tom
    Ohio
    Just heard back from someone else who has the G13 head unit and has purchased the dasaita adapter cable and that enfig microphone.
    He stated it works just fine. Still waiting on a response from Dasaita Support.
    BR73 likes this.
  28. Nov 1, 2024 at 6:10 AM
    #2488
    drgordon13
    Well that's a good start...thanks for the update!
    BR73 and purplenova[QUOTED] like this.
  29. Nov 2, 2024 at 12:26 PM
    #2489
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Just ordered the mic and adapter
  30. Nov 9, 2024 at 10:52 AM
    #2490
    drgordon13
    Got the unit installed and so far so good! Love the look and it seems to be functioning well!IMG_1886.jpg IMG_1887.jpg
    BR73 and purplenova like this.
