  1. Oct 29, 2024 at 4:22 PM
    :eek:
    BroHon, bmf4069, G_unit3000 and 4 others like this.
  2. Oct 29, 2024 at 5:01 PM
    Yup, I posted about that one in here somewhere. Hell if I remember where, but I found that same damn issue at one point, I distinctly have a foggy memory of it, and that's usually always right at least 40% of the time.
    Holup, I think I posted about that too, but if not, I've got the bolts readily handy downstairs. It's a common thread pitch. I had about half a dozen in my random bolts tray from project cars over the years.
    That said, feed both in till they bottom out. One full turn per bolt, alternating, until it finally breaks free.
  3. Oct 29, 2024 at 5:06 PM
    Heh ...
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-2091#post-3656062
    Didn't list it there.
    Anyway, went into my bolt tray and the 4 bolts sitting on top of the pile from when I relubed my rears recently are 3/8-16 coarse, which just so happen to also thread nicely into 10mm x 1.5 so I'm assuming either will work fine. I would also assume the latter is proper, metric, and the 3/8-16 isn't actually intended, just happens to work.
    JakeJake likes this.
  4. Oct 29, 2024 at 5:08 PM
    Outbound
    Aaron
    Northern Alberta
    Never really needed to. They use a mixture of salt/sand on our roads, and stop with the salt once it drops below 5F since it stops working at that point. That basically means there's only a month or two in the shoulder seasons where there's salt, so I take the truck through a touchless wash once or twice each spring and early winter, which blasts off the undercarriage. I only have standard surface rust on my frame.
    BroHon, bmf4069, G_unit3000 and 3 others like this.
  5. Oct 29, 2024 at 5:17 PM
    My state and the whole Northeast need to learn from your Province. I could easily deal with salt for the 10 years of ownership before they switched to calcium/magnesium chloride to save money and protect the grass at the expense of the car owner.
  6. Oct 29, 2024 at 5:20 PM
    Our state uses volcanic ash crumbles up in the northern part where they get snow. It seems to be a win win win for everyone
  7. Oct 29, 2024 at 5:29 PM
    Thanks, Shifty. Apparently it’s not in the FSM. Strange.
    I’ll pickup a couple of those and some M8x1.25 since I see that listed by others on TS.
  8. Oct 29, 2024 at 5:49 PM
    TS definitely says M8 x 1.25 It's possible I never put the bolts I used back into my bolt bin. I definitely had a couple of M 8 x 1.25 next to it, but there were more M10 x 1.5 in there so I assumed that's what it is.
    You only need two, so ...
  9. Oct 29, 2024 at 5:59 PM
    I will say, I thought these RT's looked very similar to my Method's, and SCS I'd seen. But the cutouts are definitely different size/shape and sometimes different count. Not by much, but they're definitely not quite the same. The way the interior lip of the rim is handled is different between them too.
    Hindsight 20/20, I probably wouldn't have gone with these RT111 because of the faux bash ring. But had I been smart, I'd have done it and saved about $1k on my build thus far. Actually, more than that, these RockTrix are my 3rd set of wheels now. I sold my other set at a loss of about $400? And I'm sure I'll lose about the same on the Methods. I don't even want to think what I've thrown out the window thus far on mounting/remounting/balancing between all the wheels and tires. I could've bought two full sets of RT wheels at this point with all that money...
  10. Oct 29, 2024 at 6:01 PM
    I think my problem may be the edge of the shoes catching the rust lip at the back of the drum. In which case, I’ll need to back the shoes off a bit.
    BroHon and FrenchToasty like this.
  11. Oct 29, 2024 at 7:24 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    I should’ve mentioned this in my earlier post:
    I cracked one of my drums alone the blue line when trying to remove it. I think the same thing happened as you mentioned- the shoes were caught on the edge of the drums. Whacking them with a hammer helped.
  12. Oct 29, 2024 at 7:34 PM
    I may not have to take them off to see which direction to tighten. IIRC, trying to loosen causes issues with the tab you need to push back and doesn’t happen smoothly while tightening has no resistance. The FSM is a little confusing with the drawings.
    I figure I’ll just tighten enough to feel the shoes drag against the drums when rotating with the wheel off.
  13. Oct 29, 2024 at 7:38 PM
    Have you got them off yet? FR is on the right path. The loosening sequence does seem strange, but once your getting them set, you want the wheel on to feel the grabbing force of the brake drag, and then go 2 more clicks
  14. Oct 29, 2024 at 7:44 PM
    Cool, thanks. I was concerned about going over and having to loosen which I recall being a PIA getting that tab pushed back.
  15. Oct 29, 2024 at 9:06 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Those little, smoky, cinder pebbles?
  16. Oct 29, 2024 at 9:09 PM
    Basically, I’m sure they refine them somehow to make someone’s pocket phatter
  17. Oct 29, 2024 at 9:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Probably.
    At least they're plentiful
  18. Oct 30, 2024 at 5:57 AM
    Auburn02
    Auburn02 New Member
    AL
    2006 DC 4.7 2WD
    Seems like you've got it but just for reassurance's sake, the holes on my '06 are for sure M8 thread, and you are spot on that there is a lip on the edge of the drums that will require the shoes to be backed off a bit to allow the drums to come clear.
  19. Oct 30, 2024 at 2:51 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Got all my Baja designs mounted on the bumper. Used sendcutsend for a simple 3/16 steel mount. It’s a bit on the heavier side so I need to brace it somehow, but I’m a big fan of pods up front especially from the best in the business!
    bmf4069, Mullen, Hutcheson and 14 others like this.
  20. Oct 30, 2024 at 4:15 PM
    I do not hate this. I'm looking for a way to mount my auxiliary lighting up front. May do something similar.
  21. Oct 30, 2024 at 4:19 PM
    FiatRunner
    Jack
    This looks great. How do you get to the hood latch?
  22. Oct 30, 2024 at 4:26 PM
    Finger yoga
    CodyP, bmf4069, G_unit3000 and 4 others like this.
  23. Oct 30, 2024 at 4:27 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    If I can get the file out of send cut send I can send it to you if you ever want it.
    Just reach from the side.
  24. Oct 30, 2024 at 4:29 PM
    The ol reach around
    bmf4069, G_unit3000, Auburn02 and 9 others like this.
  25. Oct 30, 2024 at 4:29 PM
    Appreciate it. Could just attach one of those tuner car recovery straps to you hood latch release.
  26. Oct 30, 2024 at 4:34 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    It’s actually not even awkward to get to. I think it definitely would be more difficult on a 00-02 though.
  27. Oct 30, 2024 at 4:37 PM
    FiatRunner
    Jack
    Ah. Didn't realize the latches were different pre/post facelift.
  28. Oct 30, 2024 at 4:38 PM
    Alabama style?
    Azblue likes this.
  29. Oct 30, 2024 at 4:39 PM
    Cleveland
    Azblue and Jack McCarthy[QUOTED] like this.
  30. Oct 30, 2024 at 4:40 PM
    I feel sheltered
