Manual transmission fluid
Discussion in '1st Gen Tundras (2000-2006)' started by jsvwx, Oct 29, 2024.
  1. Oct 29, 2024 at 1:33 PM
    jsvwx
    jsvwx [OP] New Member
    New York
    2001 AC SR5 V6 5M 4WD
    I just purchased this truck from the original owner. It has 167 k miles but none of the fluids have ever been changed. The clutch and tranny seem okay still. Both are stock. However, I've been noticing in the mornings it's a little rough to upshift until it warms up. I want to replace all the fluids. Any recommendations on a preferable brand? The manual calls for 75W-90. Thanks
  2. Oct 29, 2024 at 1:47 PM
    I mean, if it was me, and I wanted to go with non-synthetic, I'd go with Lucas 80w90 for your MT. If I wanted synthetic, I think Valvoline has their 'Daily Care' or whatever 75w90 that's designed for the 4spd MT.
  3. Oct 29, 2024 at 2:06 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I always liked Red Line MT 90 in my Tacoma with a manual tranny. But there are plenty of good fluids out there...
  4. Oct 29, 2024 at 2:59 PM
    bfunke
    bfunke Tundra Curmudgeon
    Are Tundra synchros made of brass? I’ve been told newer GL-5 oils contain sulfur and are corrosive to brass and that a GL-4 oil is a better choice. It will soon be moot as manuals are getting so rare as to be deemed millennial anti theft devices. Maybe an engineer on this forum has some insight?
  5. Oct 29, 2024 at 3:45 PM
    MT-Tundra
    Montana
    I can't imagine the 2001 Tundra manual transmission was much different than my 1998 Tacoma. I definitely used GL4, which is what the Red Line MT90 is.
  6. Oct 29, 2024 at 4:39 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Second on the Redline MT90. Really really good stuff.
    I run Redline oils in my Fiat and it made the transmission shift significantly smoother and killed a lot of the differential whine. I also put their Shockproof Superlight in my old Honda Insight when it had similar symptoms to yours. Worked like a charm.
    MT-Tundra and FrenchToasty like this.
  7. Oct 29, 2024 at 5:36 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    I'm just going to assume you mean none of the fluids except engine oil.
  8. Oct 29, 2024 at 6:39 PM
    jsvwx
    New York
    That's correct. Yes he was very anal with that but never believed in changing any of the fluids. Lol
    Dook55[QUOTED] likes this.
  9. Oct 29, 2024 at 6:47 PM
    jsvwx
    New York
    I'm not sure if there's an advantage to going synthetic or not?
  10. Oct 29, 2024 at 6:52 PM
    jsvwx
    New York
    Regarding the Redline MT90, should that only get used for the MT? Reason I ask is because it looks like the transfer case and MT both take the same GL-4 or GL-5 75W-90 gear oil. The front diff takes a GL-5 75W-90 hypoid gear oil and the rear diff takes a GL-5 SAE 90 hypoid gear oil. If I'm changing all of them out, can any of the same fluids be used more than once or so I need all different fluids?
    FiatRunner likes this.
  11. Oct 29, 2024 at 6:53 PM
    jsvwx
    New York
    So you use the Shockproof Super light in one of your MT's instead of the MT90 or mixed together?
    FiatRunner[QUOTED] likes this.
  12. Oct 29, 2024 at 7:11 PM
    FiatRunner
    Jack
    I'd be hesitant to run the MT90 in the differentials or transfer case. I believe it is specifically designed for use in a manual transmission, not in a transfer case or differential. It's a GL4 so it will not harm brass synchros.
    I personally run Valvoline gear oil in my transfer case and differentials, and I think that most of the gear oils you could buy at a parts store would suffice. Unless you are towing or hauling very frequently, I don't think it's critical to run super fancy oils in the diffs and transfer case. When I changed mine after 100k miles they were all surprisingly clean. Redline oils, while being very good, are also very expensive.
    I used Shockproof Superlight in the transmission in my Honda, as it called for a very light weight oil. For your transmission, I'd recommend MT90. It's a 75W-90 (not sure why it isn't called MT75-90) that's meant specifically for manual transmissions.
    jsvwx[QUOTED][OP] likes this.
  13. Oct 29, 2024 at 7:30 PM
    jsvwx
    New York
    Thank you!
  14. Oct 30, 2024 at 6:53 AM
    MT-Tundra
    Montana
    It's annoying to buy multiple fluids, but probably safer. I don't know enough to know, which is why I use what they call for. Transmission calls for GL4, other gearboxes GL5.
    Benefit to synthetic? If you believe the hype. Many of us do. The transmission on my 98 had a whine when I bought it, at around 190,000 miles. I don't know what my friend (first two owners were friends) used, but I started using Red Line. Whine stuck around for years but never got worse, and eventually went away. I sold the truck at 330,000, original transmission.
    I don't think Red Line or any other synthetic fluid are a magic cure-all, but I think good fluid and regular changes can head off some problems if you catch them early enough, and there seems to be some benefit to using a synthetic on gearboxes that were abused/neglected.
    jsvwx[OP] likes this.
  15. Oct 30, 2024 at 7:33 AM
    jsvwx
    New York
    Thanks for the info! I use synthetic engine oil in all my vehicles too and they run great with over 250k miles on each. I ordered the MT-90 for the tranny. How often did you change out the tranny fluid on that 98 truck? I'm assuming that was a MT too?
  16. Oct 30, 2024 at 10:04 AM
    MT-Tundra
    Montana
    Yeah, it was a manual. I didn't stick to any strict oil change protocol other than once a year. I towed with it, so it saw heavier duty use. T-case and front diff were another thing, but I'd try to get the rear diff and transmission once a year, in the fall after I was done towing the camper for the year. I think 20-30,000 miles is a good ballpark interval though for most people.
  17. Nov 14, 2024 at 2:27 PM
    jsvwx
    New York
    I changed out all the fluids and used the MT-90 for the tranny and it is noticeably smoother now; especially when cold. Thanks for advice! I guess 23 year old fluids finally needed to get replaced!
    MT-Tundra[QUOTED] and FiatRunner like this.
  18. Nov 14, 2024 at 5:18 PM
    bfunke
    Has anyone tried Swepco 201 in their manual transmission? It’s the oil of choice in the vintage Porsche community.
  19. Nov 15, 2024 at 5:29 AM
    South Western Power COmpany makes trans lube?
  20. Nov 15, 2024 at 7:38 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Its worth a try.
    The Porsche folks use SWEPCO 201 for the 901 transmission, which can be described as vague, notchy, and somewhat temperamental. The 901 served its purpose for many years and typically works on the race track (which is the point). Definitely adds character to the pre-1987 911 driving experience.
  21. Nov 15, 2024 at 9:43 AM
    MT-Tundra
    Montana
    Sounds expensive.
    Knowing I'd be changing my gearbox oils at the end of the year, I'd order one quart at a time, as I could afford them, until I had enough to change fluids. Something like $20/quart for Redline last I put one in my cart. Can't imagine paying more than that.
  22. Nov 15, 2024 at 9:46 AM
    MT-Tundra
    Montana
    How's your stick shift feel otherwise? Sloppy/floppy, or pretty tight? My Tacoma never needed it, so maybe Toyota finally upgraded that part, but on all my previous Toyota pickups, replacing the plastic bushing that sits at the seat of the stick shift made the transmission feel like new. They get thin, brittle, crack into pieces.
    I do miss being able to fill my transmission through the shifter hole in the cab. Way easier than laying underneath, pumping.
  23. Nov 15, 2024 at 9:50 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Red Line is perfect, good stuff.
  24. Nov 15, 2024 at 11:33 AM
    jsvwx
    New York
    Shifting feels tighter in the cold temps. Especially 2nd gear until it warms up then feels like before. I'm not familiar with the plastic bushing you mentioned. I'll have to look it up to see if my year has it.
  25. Nov 15, 2024 at 12:34 PM
    MT-Tundra
    Montana
    Seat and bushing. I'd guess you have them, but that doesn't mean they're worn out. Pretty easy to check.
  26. Nov 15, 2024 at 6:26 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    If you're replacing those, consider getting marlin crawler upgraded ones.
    jsvwx[OP] and MT-Tundra[QUOTED] like this.
  27. Nov 18, 2024 at 4:31 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I replaced those on my Tacoma that I had. They were basically worn to nothing. It made such a crazy difference and I had wished I knew about it sooner. In third gear you could shake the shifter like it was in neutral.
    MT-Tundra[QUOTED] likes this.
  28. Nov 18, 2024 at 7:02 AM
    MT-Tundra
    Montana
    Yep. In older pickups it made my transmission feel like new. Not sure why the Tacoma's were fine even at really high mileage, but in previous trucks it took the transmission from feeling completely sloppy, to really tight. World of difference.
  29. Nov 29, 2024 at 3:23 PM
    Bmktw2
    Bmktw2 Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Syncromesh
  30. Nov 29, 2024 at 3:25 PM
    bfunke
    I had several older Toyota PUs and replacing the seat and bushing really improved shifting if they were worn.
    Bmktw2 likes this.
