Transmission getting hot while in 4H ?
Discussion in '3rd Gen Tundras (2022+)' started by fastarget, Oct 29, 2024.
  1. Oct 29, 2024 at 9:21 AM
    fastarget
    fastarget [OP] New Member
    2023 Max Platinum
    Took the son hunting last weekend, and had to go up and down on some steep, dirt roads.
    Noticed that the transmission gauge was reading hot, then the fan was coming on to drop the temps multiple times. It was not hard 4wheeling, just some steep slopes and the engine around 2K rpms, 6 to 15 mph range.
    No mud or obstructions anywhere, all went back to normal when we were on flat ground. No issues since. What were we doing wrong?
  2. Oct 29, 2024 at 9:27 AM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
    Not enough airflow would be my guess
    GODZILLA likes this.
  3. Oct 29, 2024 at 9:29 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Maybe try 4L in 2nd gear next time?
    fastarget[OP] and AZBoatHauler like this.
  4. Oct 29, 2024 at 9:35 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Your issue is using 4-Hi instead of 4-LO on an incline at such a low speed. 4-LO is not just for obstructions. 4-LO has the mechanical advantage and you'll see less torque converter slippage. Your engine and transmission will spin at a higher RPM in 4-LO, therefore the trans fluid will pump through the system and to the cooler faster.
  5. Oct 29, 2024 at 10:19 AM
    18" TRD Off Road Wheels
    If you need 4x4 and are going 20 MPH or less then you need to use 4 Lo instead of 4 hi.
  6. Oct 29, 2024 at 10:45 AM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
  7. Oct 29, 2024 at 12:22 PM
    fastarget
    2023 Max Platinum
    Thank you all for the info. Will try 4L next time, it may allow less surging back and forth as you go uphill and modulate speeds. As previous threads, some small things are still a bit of a disappointment, but small turbo engines in big vehicles, are not ideal for crawling around like that. Overall the truck is smooth on the road, and no issue since. Going to steal the 200 LandCrucher :) from the wife next time.
    AZBoatHauler likes this.
  8. Oct 29, 2024 at 12:23 PM
    AZBoatHauler
    So.Arizona
    Smart man.
    fastarget[QUOTED][OP] likes this.
  9. Oct 29, 2024 at 12:25 PM
    fastarget
    2023 Max Platinum
    There is no substitute .......nice rig
