  1. Oct 27, 2024 at 2:55 PM
    I don't think so.
  2. Oct 27, 2024 at 3:14 PM
    Neo
    Neo New Member
    Alabama
    HOLY STINKIN' SMOKES!! Mine appears to be mounted to a white plastic plate, which is then held on by the stud and nut you can just see in the lower left of this photo. Did you have to remove a fastener to pull the whole assembly down? That plastic plate also holds something else wrapped in electrical tape below the nut.
    455h0le_dachshund likes this.
  3. Oct 27, 2024 at 3:40 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I mean you said it was a dodge so.... :p
    whodatschrome[QUOTED] likes this.
  4. Oct 27, 2024 at 3:43 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I bet it's behind the gauge cluster, which is way easy to remove. That's where my 03's RS3200 is. Whiles it's easy to get to, it's not easy to mess with. It's in there good behind a metal dash bar.
    Anyways if you're just trying to program a new fob, why do you need to get to the brain? There should be a long procedure to program it. At least for the rs3200, it's like turn key on, roll down driver window, open door, turn key off, shut door, turn key on, roll up window, hit the lock... blah blah blah.
    There's some videos on YouTube how to do the programming.
    Edit: you found it already.
  5. Oct 27, 2024 at 3:46 PM
    No I don't remember having to do that. Did you move the ball vent like I suggested?
  6. Oct 27, 2024 at 3:59 PM
    Neo
    Neo New Member
    Alabama
    If you mean this piece, then yes.
    Okay, headed back down to see if I can work it free and far enough out to program.
  7. Oct 27, 2024 at 4:58 PM
    shifty` Goons of Hazzard
    Reclamp the boots. There's info on which clamps to buy on here. Lemme see if I can find it. DO NOT replace the axle! Seriously dude. OEM CV axles are fantastic.
    Here you go, @ToyotaDude to the rescue! https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1916#post-3451375
    Hutcheson[QUOTED] likes this.
  8. Oct 27, 2024 at 5:00 PM
    RS3000 requires shorting some wires or some crazy shit. Or if you have a spare laptop with TechStream on it, I'm sure you can just program the fugger.
  9. Oct 27, 2024 at 5:05 PM
    Hutcheson
    Hutcheson New Member
    Caleb
    2004 DC Limited
  10. Oct 27, 2024 at 5:06 PM
    I haven't been following the discussion that close but I was able to add a new keyless entry to mine. It was a pain but I eventually figured it out with help from a few ppl here.
    shifty`[QUOTED] likes this.
  11. Oct 27, 2024 at 5:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Damn. I'm glad I never had to program new fobs on my 99 Tacoma then. Even though it's rs3000 was easy to access
  12. Oct 27, 2024 at 5:46 PM
    Neo
    Neo New Member
    Alabama
    @FirstGenVol you were following close enough to keep me pointed in the right direction. Big thanks!
    Turns out my RS3000 ECU was actually hard mounted to a metal plate that was itself mounted to a stud with a 10mm nut roughly in the location @FirstGenVol mentioned. I dismounted it because I didn't recognize the recessed program switch was accessible (if almost out of view) on the bottom. Once I had access to the program switch, it took me less than 60 seconds to clear all previous remotes and then add the original and the spare remote following the PDF instructions posted by @shifty` here. Thanks to all who responded.
    EDIT: FWIW this 2002 AC LTD has the RS3000 ECU, but uses the BAB237131-056 fobs.
  13. Oct 27, 2024 at 7:02 PM
    I have my suspicions there are a couple of fobs that work for the RS3000 systems. I think it may support the older and newer style fobs....
    FiatRunner likes this.
  14. Oct 27, 2024 at 7:11 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Interesting suspicion. I have my doubts.
  15. Oct 28, 2024 at 3:28 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Any recommendations for surp belts? Are the $60+ dollar ones worth the ChaChing?
    Thing started squealing like a banshee this last week. That's what I get for scrubbing it super clean when I did my fan bracket :mad::rofl: Got in there with my stethiscope and its on the alt pulley, WD40 spritz and she goes silent, so I'm pretty sure it's not the alt bearing.
  16. Oct 28, 2024 at 4:18 AM
    bfunke
    bfunke Tundra Curmudgeon
    OEM, AISIN or Gates are what I’ve always used.
    ToyotaDude, shifty` and BroHon like this.
  17. Oct 28, 2024 at 5:03 AM
    I went with the Gates HD. Green one.
  18. Oct 28, 2024 at 6:40 AM
    The solution used to be Gatorback belts until someone else bought them out and now it’s Continental Elite? Also heard Gates HD as a replacement. A new OEM will last you another 50k miles before happening again. Been down that road on both factory warranty and platinum extended care warrants a couple of times.
    BroHon[QUOTED] likes this.
  19. Oct 28, 2024 at 7:14 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Just ordered a Gates NBH-25060882HD $50.54
    NAPA has two HD green, they said both are Gates brand. One slightly bigger than the other, both show as "fit" though. At least if I have a problem I can take it right back/ local store. The one I can get today is the larger one.
  20. Oct 28, 2024 at 7:25 AM
    I’ll probably go with the Continental Elite Poly-V since research shows the Goodyear Gatorback were made by Continental for sometime before the packaging stopped referencing the Gatorback. I know those work in the cold weather, but I don’t know as much about the Gates HD Green and who here from the North or Canada have been running with them for some time (over 50k miles) to solve their squeal issue.
  21. Oct 28, 2024 at 10:00 AM
    Well, this is the 2nd person in one month that confirmed having the RS3000 box in their truck, and confirmed the remote with FCC ID ending in '056' worked for their truck. That same remote works for my '06 with RS3200. I want to say both RS3000 people were driving '02 or maybe one had an '03.
  22. Oct 28, 2024 at 10:03 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Is there an advantage to using the RS3200 fob with the RS3000 system? I've been thinking of getting another fob.
  23. Oct 28, 2024 at 10:09 AM
    If possible? Dunno. Does the football shaped remote have a panic button? Does RS3000 support panic function? That's ultimately what I'd be checking.
  24. Oct 28, 2024 at 10:12 AM
    FiatRunner
    Jack
    It does- you hold down the lock/unlock button. Both lock/unlock/panic are all activated by the same button, someone told me the other one is for a second Toyota vehicle.
    Can't you roll the windows down with the fob on the RS3200? Or is that just on Sequoias?
  25. Oct 28, 2024 at 10:20 AM
    No option for window rolldown on the RS3200 I'm aware of. I didn't even know that was a thing for the Sequoias.
  26. Oct 28, 2024 at 10:23 AM
    FiatRunner
    Jack
    Just looked it up- it only works if you put the key in the lock and hold it in the unlock position. All the windows and the sunroof will open.
    On my Lexuses you can hold the unlock button on the fob and it'll roll down all the windows. Mixed those two up.
  27. Oct 28, 2024 at 10:23 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I don't know about no fcc IDs.
    I'm more interested in what the fob looks like
  28. Oct 28, 2024 at 10:26 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Someone told me the reason the rs3000 fob has 2 buttons is you can program the 'other' button for a different vehicle.
    FiatRunner and shifty` like this.
  29. Oct 28, 2024 at 10:42 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    It's like you boys aren't even speaking English today.
  30. Oct 28, 2024 at 10:44 AM
    FiatRunner
    Jack
    I was told that too. Had to confirm with the manual.
