Door check problems
Discussion in '1st Gen Tundras (2000-2006)' started by slowdisco, Sep 27, 2018.
  1. Jul 24, 2022 at 8:18 PM
    #61
    richsadams
    richsadams New Member
    Northwest
    2000 SR5 AC 4x4 4.7L
    Ah, well that's pretty obvious once you look at it! So I managed to get it all apart... of course the pieces went everywhere, but looking at the other one I managed to get the squeezy bits back where they belong.
    Now for the fun part! I pulled the driver-side door check and low and behold, it's been replaced at least once already. As you can see in the photo, it's built exactly like the inexpensive replacement including the pin at the end to hold everything together.
    I was about to throw in the towel but after staring at it for a bit and giving it some thought I figured I really had nothing to lose, so I went ahead and tried disassembling the casing just like we did on the new one. This one didn't have any tabs to bend back, so I gingerly but carefully took the same small flat-blade screwdriver I used to pry the back of the new one off and another low and behold - it came free!
    So I pulled the squeezy bits out of the old one. The orange plastic parts had been rubbed flat as expected. I pulled the squeezy bits out of the new one. I put the new bits in the old door check case, pressed the back back on in my vice as best as I could, reinstalled it in the door and, ta-dah... I have a working door check! Phew!
    I haven't pulled the passenger side apart, but I'm guessing it's the same story.
    For a time I was pretty sure there were a couple expensive door checks in my future. :( But I was wrong! I hate being wrong. Except this time. :D
    Haven't seen the Toyota replacement. Wonder if that's one of them? Disappointed that it apparently doesn't last any longer than the original. Not surprising though I guess.
    Just glad this worked... in a round-about manner anyway.
    It was getting dark and I wanted to button things up on the driver's side but I'll post before and after photos of the passenger side when I get it done.
    Thanks so much for all of the support, it's truly appreciated. :thumbsup:
    artsr2002[QUOTED] likes this.
  2. Jul 26, 2022 at 8:49 PM
    #62
    richsadams
    Northwest
    Update to my update above... pulled the passenger side door check and it turned out to be original or similar since it had the part at the top that can be twisted off. I did that and then tried to remove the case as I had on the other one. It didn't have the 4 tabs like the newer one, but no matter how hard I tried to split the case, it just bent the ends and would not open. Upon further inspection I found that the two bolts that attach it to the body had apparently had a couple of tack welds on the back to keep the case from coming apart... ever... again. So it looks like someone replaced the "squeezy bits" before and didn't want it to fall apart. It didn't, and, sadly it won't.
    So I threw it back in and I guess I'll either have to pay stupid money for a new one or find a used one somewhere and rebuild it. At this point I think I've worked on it long enough and I'm just going to spring for a new OEM. $90. Why? Dunno. You can buy the same part for the Gen 2 or 3 models for under $30. Insane, but it is what it is.
    Thanks again for all of the help! :thumbsup: Learned a lot and have gotten very good at removing the door cards! ;)
  3. Sep 4, 2022 at 11:43 AM
    #63
    richsadams
    Northwest
    Ended up springing for a new passenger side door check. $90.66 from McGeorge Toyota. I think I could R&R the door panels in my sleep now. o_O
    Still no idea why these cost 3 times as much as the ones for later model Tundras... or almost any other vehicle, but it is what it is. Works perfectly (as it should) and the wife will be a happy camper, so that's what's really important. :thumbsup:
    daveeasa likes this.
  4. Sep 4, 2022 at 1:07 PM
    #64
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I'm a bit late but some folks have drilled out the tack welds to remove the studs and just replaced with similar sized bolt/nut. That would work also and save you money.
  5. Sep 4, 2022 at 1:17 PM
    #65
    richsadams
    Northwest
    Been there done that for the driver side but due to previous owner’s “fix” I wasn’t able to do that for the passenger side. Earlier posts detail the whole saga.
  6. Oct 26, 2024 at 6:15 PM
    #66
    Centi403
    Centi403 New Member
    2006 TRD Yamaha Edition
    Today I attempted to clean out my truck and the self closing doors finally pushed me over the edge. My solution, which only time will tell how long it lasts, was to drive a self tapping screw through the arm where the door is supposed to catch. On one side I seated the head of the screw just abo e flush so the barrel was taller through the catch.
    On the other side I seated the head flush with the top of the bar, which mostly expanded the sides.
    Now I can swing both doors open and they stay that way. After 5 years it's an amazing feeling.
    G_unit3000 likes this.
  7. Oct 26, 2024 at 6:17 PM
    #67
    For a mere $18, seller 'scarlettpimp' on fleaBay has repair kits to do it the right way.
    One such item: https://www.ebay.com/itm/116273512789
    Welcome to the forum. I see you're one of the few Canucks with a Yamaha Edition! Hopefully you post pics, pretty cool package aesthetically.
    #67
  8. Oct 26, 2024 at 6:54 PM
    #68
    Centi403
    Centi403 New Member
    I'll have to get some new picture of it. It's actually clean now.
    This fix was just because today it finally drive me nuts. All it cost me was 2 self tapping screws. As long as it lasts a little while it'll be worth it.
    Once this fails I'll look into doing it proper.
  9. Oct 28, 2024 at 3:56 AM
    #69
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    This reminded me of my door check that was yanked right out when I bought my truck. Luckily there was one in the parts tote that came with it. Went a little cave man flux core on it, but at least I have a stop now. No detent though... :rofl:
    I should prob paint that mess.
    (These welds not approved by @JakeJake :anonymous:)
    G_unit3000 and whodatschrome like this.
  10. Oct 28, 2024 at 4:46 AM
    #70
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Not bad for a Bangladeshi kid wearing safety squints :rofl:
  11. Oct 28, 2024 at 5:18 AM
    #71
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    is that just a rebuild kit or is it supposed to make it tighter/better?
    #71
  12. Oct 28, 2024 at 9:45 AM
    #72
    Rebuild kit, but I don't have experience. Others on here do, and were happy from that specific seller.
  13. Oct 28, 2024 at 10:28 AM
    #73
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I can add my review. It's been about a month since I rebuilt both the rears on my DC. They work great! Door stays open and closes silently.
    G_unit3000 and JakeJake like this.
  14. Oct 28, 2024 at 10:50 AM
    #74
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    Hmmm.... be aware that these look to be 3D printed. Not that there's a problem with that, but hoping the seller created the original design. It appears the design can be readily found on 3D printing sites.
    https://www.thingiverse.com/thing:3486480
    https://www.thingiverse.com/thing:6663791
    https://www.thingiverse.com/thing:4922151
    Additionally, PLA is the most common printing material, but it does NOT hold up well to automotive applications due to impact of heat. Even prints in the interior of a car can deform due to heat buildup during the summer. If you have access to a 3D printer use one of the designs above and print your own. I would try PETG or even a high durometer TPU or TPE.
    G_unit3000 and Auburn02 like this.
  15. Oct 28, 2024 at 9:17 PM
    #75
    daveeasa
    Seller experimented with various materials. And suggests routine replacement. He sounds super cool to me from our conversations.
    Teutonics, JakeJake and G_unit3000 like this.
