Official Lifted 2nd Gen Tundra Pics w/ Info
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, Jan 7, 2014.
  1. Feb 8, 2024 at 11:48 AM
    #481
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
    Its amazing, I actually just finished updating the rear.
    Running the RCvertex 6" in the rear and went ahead and updated the leaf springs to U748 Deavers with the David Ekstrom 3+ shackle and eliminated my 4Inch block.
    Review:
    I struggled to find a landing spot for highway. Setting 1 was softer than stock, but had too much body roll. I have moved to 3 setting in both front and rear resi's.
    Removing the block is the way to go. I'm really blown away by the whole setup.
  2. Apr 26, 2024 at 7:15 AM
    #482
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    Just finished updating my setup.
    Fox 2.5 front and rear, and Icon RXT leafs (running option 1 for now). Now for a U-Bolt flip kit, bump stops, 37s, a BMC, and glass fenders.
  3. Apr 26, 2024 at 7:58 AM
    #483
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    What is the U bolt flip kit for?
  4. Apr 26, 2024 at 8:10 AM
    #484
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    Just a little extra clearance, and they usually come with upgraded bump stops.
    1BadTundra[QUOTED] likes this.
  5. Apr 26, 2024 at 8:46 AM
    #485
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Deaner[QUOTED] likes this.
  6. Apr 26, 2024 at 10:53 AM
    #486
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
  7. Sep 4, 2024 at 1:23 PM
    #487
    Snowviraptor
    Snowviraptor New Member
    2016 MGM Tundra SR5 CrewMax
    I decided to go with the rough country 6" kit with the N3 shocks and rear struts, Fuel Vapors with a +1 offset, and Toyo Tires Open Country R/T trail 35x12.5R20LT. Truck rides real quiet and smooth, better than it did when I first bought it.
    Before:
    After:
  8. Sep 7, 2024 at 4:26 AM
    #488
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    After I had one of my front shock reservoirs leak and rebuilt, I went ahead and bit the bullet and replaced the shocks and coilovers on Kompns8.
    Replaced with the same rare (because of the length I guess?) Fox 2.5 coilovers up front and Fox 2.0 in rear. I have orange and black labels coming in for the front reservoirs to match the rear.
    Not 100% on the location of the front reservoirs yet but they’re close to what they were before. Does anyone know a part that will mount above the shock mount and hold the reservoir there?
    Also replaced the front diff and added a double Cardin front drive shaft after hearing noises I didn’t like at higher speeds in 4WD.
    Truck still sitting high and level! Next step would be to sand blast and paint or powder coat the lift kit as it’s seen better days.
  9. Oct 1, 2024 at 8:02 PM
    #489
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Looks great!
  10. Oct 27, 2024 at 3:43 PM
    #490
    RFerre6
    RFerre6 New Member
    2.5 King suspension with Resi’s set to stock settings out of the box (5 threads showing)
    1.5” CB Shackles
    Icon Uniball UCA.
  11. Dec 28, 2024 at 12:53 PM
    #491
    tjacob95
    tjacob95 New Member
    2014 toyota tundra limited
    what size tires are in the first pic
  12. Jan 17, 2025 at 1:13 PM
    #492
    ryanallaire
    ryanallaire New Member
    2010 CM 5.7
    3" RC leveling kit, S&B intake, custom DIY exhaust, tuned for 91 octane, morimoto headlights, all LED interior lighting.
    Sweet truck! I have a 3" RC leveling kit in the front and nothing in the back, I'm looking at method 703's with a 35mm offset as well, and looking to put some 305/70r17 tires. Do you have any issue with rubbing? Have you cut or modified anything?
  13. Mar 2, 2025 at 5:08 PM
    #493
    RoadmenButch
    RoadmenButch New Member
    Curtis
    2013 Platinum
    BDS Lift, Custom wrap, ARE canopy, DAP tuner, K&N Air Intake, Custom Stereo, Fuel Wheels, Rear Air Bags, LED Custom grille, LED lighting throughout
    Here is my 2013 Platinum. Has a 6” Fox BDS lift. Currently running 35x13.5 R20’s Toyo MTR’s and will soon be running the same size tires, but will be the Mickey Thompson Baja Boss A/T’s.
  14. Jul 18, 2025 at 5:40 AM
    #494
    iamunique127
    iamunique127 New Member
    Manitoba, Canada
    2013 CrewMax
    3" level
    That is one of the nicest looking Tundra's I've ever seen.
    Great job.
    PolishedTRD[QUOTED] likes this.
