Another Transfer Case fluid post. (Liqui moly MTF 5100 75W)
Discussion in '2.5 Gen Tundras (2014-2021)' started by Chip_Tundra, Oct 26, 2024.
  1. Oct 26, 2024 at 7:33 AM
    Chip_Tundra
    Chip_Tundra [OP] New Member
    Liqui Moly MTF 5100 SAE 75W works. I got 2 quarts at Napa for $16 per bottle.
    FireShot Capture 065 - Top Tec MTF 5100 SAE 75W - LIQUI MOLY - www.liqui-moly.com.png
  2. Oct 26, 2024 at 11:56 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Not sure how this holds up to Ravenol, but I’d personally only use Ravenol.
    smokint likes this.
  3. Oct 26, 2024 at 12:14 PM
    Chip_Tundra
    Both are german brands and make very good lubricants. Just putting this out there because it seems to be more readily available.
    But hey, it's your truck, so put in what you're comfortable with. I personally changed the diffs to supertech 75w90 syn and liquimoly 75w for the T Case at 30K miles.
  4. Oct 26, 2024 at 12:53 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    +1 Ravenol. 75w. Get it on Amazon.
  5. Oct 26, 2024 at 2:06 PM
    Chip_Tundra
    Lol eff it, be part of the herd and just use Ravenol.
    Anything else will not work. :rolleyes:
  6. Oct 26, 2024 at 5:11 PM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
  7. Oct 27, 2024 at 11:12 AM
    Chip_Tundra
    Another good choice.
  8. Oct 27, 2024 at 12:24 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    There's nothing really special about Ravenol, the VOA on it shows it's not close to the Toyota fluid. People just use the Ravenol because it's the only fluid that says it can replace the exact part number of the Toyota fluid along with a ton of other OEM fluids which has always made me suspicious of it since you wouldn't want to use those other OEM fluids in your transfer case but if Ravenol can replace all those other OEM part numbers then that would suggest that those OEM fluids would also work. I personally have just stuck with the OE fluid since I dont change it often enough for the added cost to really make much of a difference.
    Chip_Tundra[OP] and dt325ic like this.
  9. Oct 27, 2024 at 2:05 PM
    Chip_Tundra
    If it's GL4 certified and 75w per the manual, I have no problem with it. There have also been people on record saying that dealers have been putting in 75w90 in the T cases with no issue. So theses straight 75w fluids like ravenol, redline and liquimoly can't be far off from the toyota branded one.
    People on this forum would flip if they saw what I was putting into my truck lol. API certs and shorter drain intervals just don't cut it for the majority of people here I guess.
  10. Oct 29, 2024 at 5:04 AM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
  11. Oct 29, 2024 at 11:52 AM
    Joe333x
    Joe333x Member
    Boston
