1st Gen parts Corner of Shame - OEM minus or plus?
Discussion in '1st Gen Tundras (2000-2006)' started by KNABORES, Mar 31, 2023.
  1. May 2, 2024 at 9:41 AM
    #91
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I was going to get moog, but if you buy OEM through the online program its was only $15 more so I went with OEM.
    Weagle and KNABORES[OP] like this.
  2. Jul 26, 2024 at 9:59 PM
    #92
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Major fail!
    I bought Powerstop drums and rotors when I did my brakes recently. I've had great luck with Powerstop products in the past, they've always worked well for me. Until now. After installing the new brakes I had a terrible pulsing when braking, like really really bad. I brought the drums to a buddy of mine who has a brake lathe, and it turns out that they had more than .050" of runout!!! I couldn't believe it. Really really disappointing. The original drums with 215k on them weren't out of round at all. They were far out of spec, but still. No good.
    That said, the hardware that came with the Powerstop kit was very good, stuff was just as beefy as the originals and I didn't have any issues getting stuff to fit.
  3. Jul 27, 2024 at 4:47 AM
    #93
    KNABORES [OP] Sarcasm incoming
    Great info, I’ll mark powerstop drums off the list. Still OEM or bust for those.
    rouxster70 and Weagle like this.
  4. Jul 27, 2024 at 4:49 AM
    #94
    I'm still using my original drums at 194k miles. No issues and no clue how long they will last.
    I've mentioned before that I'm running some of the cheapest (Raybestos) calipers and rotors too. Again, no issues.
    G_unit3000 and Weagle like this.
  5. Jul 27, 2024 at 5:28 AM
    #95
    Original OEM rotors here with 271k miles. I’ve only changed pads once. Original wheel cylinders too. I’ll inspect during the upcoming tear down.
    G_unit3000, Weagle and jerryallday like this.
  6. Jul 27, 2024 at 5:44 AM
    #96
    Original rotors? Or drums? Didn't you buy the truck used?
  7. Jul 27, 2024 at 6:52 AM
    #97
    Original drums, I’ve replaced rotors twice
  8. Aug 23, 2024 at 7:24 AM
    #98
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I’m adding the Moog Sway Bar Links. I only swapped them because I assumed they were going to be trashed, and I had to pull them anyway to add a 1/4” top plate spacer.
    They have 115k on them and are 4 years old. I live on a rough poorly maintained bumpy road, they have bombed down washboard roads at 70mph, they have held up like new.
    The balljoint is still very tight and the bushing are in great shape. They have surface rust, but that’s about it.
    Not bad for $42 shipped. I replaced them with the new Moog links with the white bushings. We’ll see how those hold up.
  9. Aug 23, 2024 at 7:25 AM
    #99
    I want to say it's the Moog sway links with zerks I hear people complain about the most? Or maybe I'm remembering wrong.
    Weagle and Diablo169[QUOTED] like this.
  10. Aug 23, 2024 at 7:28 AM
    #100
    I just took my Moog tie rod ends off. They were serviceable. Not bad enough to not recommend. Not good enough compared to how smooth these OEMs are, or the 212k I got on my original OEMs compared to the 50k I got on the Moogs before they got sloppy. Decent temporary solution perhaps.
    Weagle, Diablo169 and shifty` like this.
  11. Sep 12, 2024 at 11:32 AM
    #101
    Well, here's an OEM plus, aftermarket minus/fail to share from the lowercase FB group.
    Weagle, KNABORES[OP] and Diablo169 like this.
  12. Oct 3, 2024 at 12:23 PM
    #102
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've had 2 sets of passenger side Depo CAPA certified corner lights get moisture in them now. First one purchased 5/18/23 and then replaced on 11/2/23 under warranty and now a year later here is the passenger side again with moisture in it.
    Not sure if any of the other options out there (other than OEM) are any better and I suppose I could pull the one apart and reseal if I have to.
    Gonna have to be OEM minus here. Maybe just a bad batch or something, headlights and driver side corner light has been fine so far.
  13. Oct 21, 2024 at 6:58 PM
    #103
    808basswolf
    808basswolf New Member
    Los Angeles, CA
    2002 tundra SR5 v8 AC
    Been a while, but how did the mood sway bar links hold up?
  14. Oct 21, 2024 at 7:08 PM
    #104
    Where can I get these? :monocle:
    Joking aside, they lasted me about 4-5 years before needing replacement. I’m on my 2nd set replaced under the lifetime warranty. Will be looking to get at least one replaced under warranty again and just buy the other. Spent this past weekend cutting the ball of the bad one out of my LCA….
    G_unit3000, BroHon, Weagle and 3 others like this.
  15. Oct 28, 2024 at 2:07 PM
    #105
    seanm1973
    seanm1973 New Member
    2006 maroon-ish DC Tundra, stock, 204k miles and going
    just curious about any recommendations for the sway bar links? From what i've read on here, stay away from mevotech and Moog was decent for short term (I don't plan on keeping my '06 another 14yrs)
    I did the topic search and this was the best match. thank you all for the great information, y'all have prevented me from making a few costly, repeated mistakes.
  16. Nov 1, 2024 at 1:55 PM
    #106
    rock climber
    Suspension maxx is good
  17. Nov 1, 2024 at 2:00 PM
    #107
    Stock height: https://suspensionmaxx.com/product/smx-122260t
    Lifted trucks: https://suspensionmaxx.com/product/smx-122270t
    Use a poly-safe lube on the bushings during install.
    Do your best to keep the bottom cam parallel to the ground at install.
    You may need a (14mm? 17mm? I forget) thin wrench to install.
    Read the directions they provide for install so you know how to properly install.
    G_unit3000 and seanm1973[QUOTED] like this.
  18. Nov 1, 2024 at 2:01 PM
    #108
    And goooooold!
    G_unit3000, seanm1973 and Weagle like this.
  19. Nov 4, 2024 at 4:40 PM
    #109
    seanm1973
    Well f&$k, moog 2 piece for the loss. 14ft/lbs torque my ass.
    Didn’t want to spend extra monies for someone else to enjoy a few extra years out of ‘ol dirty red. Guess I’ll chalk this up again and listen y’all before buying….again. (I couldn’t wait for response before I bought, had a couple days off work ((shift worker)), figured easy 1 hour job)
    KNABORES[OP] likes this.
  20. Nov 22, 2024 at 6:53 PM
    #110
    G_unit3000 and KNABORES[OP] like this.
  21. Jan 14, 2025 at 1:45 AM
    #111
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    At my local Toyota those 6 items come out to $66 before tax. How necessary are new clamps? NVM it's just an extra $7... Weird that the two sides aren't identical for the clamps and bellows part numbers and the clamps differ by 47¢ in price.
    Local
    Birmingham
    Decatur
  22. Jan 18, 2025 at 2:40 AM
    #112
    Kilgore Trout
    Kilgore Trout New Member
    Oregon
    2002 AC Toyota Tundra SR5 4.7L V8
    Airaid Cold Air Intake, Magnaflow Dual Catback Exhaust, 2017 18” 4Runner Wheels
    Oh man that’s a bummer. I bought a no name fully aluminum radiator off of eBay for cheap and it’s been absolutely perfect the last 8 years or so.
  23. Feb 4, 2025 at 8:21 PM
    #113
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I was wondering the same thing.
  24. Feb 5, 2025 at 5:33 AM
    #114
    Aren't the OEM UBJ like $35-40/ea? I swore they were so inexpensive it warranted just going OEM.
  25. Feb 5, 2025 at 5:42 AM
    #115
    and the Job isn’t that much fun to want to do it regularly
  26. Feb 5, 2025 at 7:08 AM
    #116
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    it isn't THAT bad. If you get the VERY specific Toyota ball joint tool. But even then.....I hated doing my OEM UBJ.
    it's 2 months shy of a year installing my KSP UCA. It comes with an entirely different UBJ assembly. It didn't break the bank and is still holding upIMG_4471.jpg
    so take that for what it's worth
  27. Feb 5, 2025 at 9:56 AM
    #117
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I don't know. I haven't checked yet
  28. Feb 5, 2025 at 10:04 AM
    #118
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I often wonder how an aftermarket UCA would handle the 2" drop. I imagine the only one that would do it well is SPC due to its camber and caster adjustability.
  29. Feb 5, 2025 at 5:20 PM
    #119
    I just checked, for my '06 both sides are same part, 43310-39016 (formerly that ended in -39085). Current non-sale price (depending on your dealer's discount) is around $48.
    During a 20% off sale, you're looking at ~$39.
    Toyota says this p/n fits 1995-2006 vehicles so I assume it's same part for earlier years. Always verify before ordering.
  30. Feb 5, 2025 at 10:35 PM
    #120
    TnPlowboy
    TnPlowboy New Member
    2004 Tundra SR5 AC 4.7L 4WD, Tow Package: Blue Marlin Pearl
    What tool are you talking about? Must have missed that one.
