Tire and leveling question
Discussion in '1st Gen Tundras (2000-2006)' started by Otakutoaster, Oct 18, 2024.
  1. Oct 18, 2024 at 6:41 PM
    Otakutoaster
    Otakutoaster [OP] New Member
    WI
    2002 Tundra AC limited Black V8 4wd
    Radio, subwoofer & amplifier, Roll-N-Lock, Cabin air filter,
    I have a 2002 tundra AC limited. Will 265/70r17 tires fit without changing anything stock. Also can I use 2 inch leveling spacers without changing anything. I just want to level the front for looks nothing other than that.
  2. Oct 18, 2024 at 7:25 PM
    ZHUNTER
    ZHUNTER New Member
    North Georgia
    2020 Quicksand Tundra DC TRD
    Westin Winch mount tray w/ custom light bar, avs hood deflector, 3” lift, badlands winch w/ wireless remote, bed stiffeners, Toyota Predator steps, Husky Floor liners
  3. Oct 18, 2024 at 7:41 PM
    Otakutoaster
    WI
  4. Oct 19, 2024 at 4:51 AM
    For suspension/tire stuff, the things you need to know specifically, see the suspension section in this thread: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Spacers will still change your suspension geometry. Can you do it? Of course. Is it great? Not really. Is it better to spend the money on a decent brand lifted coil on a Bilstein strut? Yep.
    Just avoid Rough Country, Rancho, and Monroe and you should be alright.
  5. Oct 19, 2024 at 8:15 AM
    Otakutoaster
    WI
    Thanks I mostly just wanted to know if it'd be fine to run for a few weeks until I have more money to upgrade. I'm dead broke after buying this truck.
  6. Oct 19, 2024 at 9:32 AM
    Totally get it. I’m a fan of buy once cry once (or install once cry once) but I also doubt you’ll need the added front lift for 1” added diameter. You may run but if you do it won’t be nearly as substantial as what I’m dealing with on my 2006 AC running + 2.25” diameter tire and an extra 3/4” if I’m remembering right. 265/70r17 you’re not adding any worth, just sidewall height (again, from memory, all the tire research we’ve all done is in that thread I linked)
    That said, are you thinking too hard about this? Get the tires. If the rubbing is obvious, install spacer ‘til you get a few hundo to buy lifted springs and struts.
  7. Oct 19, 2024 at 10:34 AM
    Otakutoaster
    WI
    I'm probably just gonna wait until I have the money cause I will have enough next month.
    shifty`[QUOTED] likes this.
  8. Oct 19, 2024 at 3:41 PM
    ZHUNTER
    ZHUNTER New Member
    North Georgia
    Sometimes you have scroll up with in the sticky threads at the very top of the threads.
  9. Oct 21, 2024 at 4:33 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Be sure all the other maintenance items are up to date before spending the coin on bigger tires and such. Lower ball joints and the timing belt especially.
  10. Oct 21, 2024 at 11:19 AM
    Otakutoaster
    WI
    Well I know that tires is one of them I just found out yesterday that my tires are 7-8 years old. Right now it's just the battery, tires, brakes, and fluids. By fluids I mean the brake fluid, power steering fluid, and coolant. But I already bought the stuff for that just waiting for my off day.
  11. Oct 21, 2024 at 12:05 PM
    NickB_01TRD
    KY
    I got ya. Do you know how old the timing belt or ball joints are either?
  12. Oct 21, 2024 at 12:08 PM
    Otakutoaster
    WI
    Ball joints no I haven't had the time to look at them the timing belt looks relatively new. I'll be replacing the ball joints next year or else December depending how bad they are.
  13. Oct 21, 2024 at 12:09 PM
    They typically don’t show signs of being bad, they just fail. Catastrophically, we’ve seen.
  14. Oct 21, 2024 at 12:11 PM
    NickB_01TRD
    KY
    Yeah as stated here. They won't usually let you know, they just come apart. $250 is usually the most you'll spend for OEM. We can link you to part numbers and such if need-be
    Timing belt looks won't always tell you the whole story. If you don't know the age I'd at least plan to replace it at some point in the nearish future as long as it isn't showing visual cracking.
  15. Oct 21, 2024 at 12:34 PM
    Otakutoaster
    WI
    I know that it looking fine isn't a good indicator but it means I don't need to fix it yet will probably do it in a month or two. The ball joints I was planning to do when I do my suspension since I'd already be taking it apart might as well rebuild the suspension.
    NickB_01TRD likes this.
