Has anyone put Sumo Springs on 3rd Gen?
Discussion in 'Suspension' started by Sacul, Jul 6, 2024.
  1. Oct 17, 2024 at 5:35 AM
    #61
    BabyMoose
    BabyMoose New Member
    2023 Tundra Limited TRD Off-Road
    CBI bed rack, Decked storage, OVS Nomadic 2 RTT, Ironman DeltaWing 270
    I put a set of black on my 23 limited TRDOR. I have a Decked box with some tools and camping gear, a steel CBI bed rack, a folding soft cover roof top tent, and a 270 awning. At rest the SumoSprings are barely touching the axle. I haven't been off road with it yet, but can tell an improvement when hitting speedbumps, dips in road, etc. at speed. Less bounce and better support for the weight. I don't have a great before pic from the same angle but these are close. I did trade my 20s for the 18s as soon as I got back from Big Bend and got the SS about a week later.
    Before:
    After:
    Side by side, left is before right is after:
    Sacul[OP], GAMark and PBNB like this.
  2. Oct 19, 2024 at 2:13 PM
    #62
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    @Raven67 you were right. Easy as pie. Printed instructions were wrong though, they say 14mm, it's actually 12mm ratchet/wrench needed. I didn't jack the truck up and didn't pull the wheels. No need!
  3. Nov 23, 2024 at 7:27 PM
    #63
    MrKABC
    Art
    Corona, CA
    UPDATE: Blue Sumos did make a difference! No squat anymore. Ride loaded/unloaded essentially the same. I think the Sumos were a good call and I'm happy!
    Spartanfam, Lord Helmet, Kap1 and 4 others like this.
  4. Nov 25, 2024 at 12:30 PM
    #64
    PGomersall
    PGomersall New Member
    All I just bought the Black versions for my 2022 Limited. There is also a 25% discount for BlackFriday for the next few days.
    Hope my engine holds while I test them!
  5. Nov 30, 2024 at 6:40 PM
    #65
    lavern23
    lavern23 New Member
    Chad
    I am leaning towards getting a set of these. Any of you have the factory lift kit and have the Sumo springs installed? I am curious if I will need a spacer.
  6. Dec 2, 2024 at 6:43 AM
    #66
    PGomersall
    Just fitted my black versions. On my 2022 Limited Standard, I have a Leer shell on. With the Sumo's fitted I have about 1/2 inch gap between them and the axel. Without them or the shell I suspect the gap between the frame and the axel would be about 7 inches, discounting the OEM bump stop. Not sure what the gap would be on a lifted truck and how that would affect using Sumo's.
  7. Dec 4, 2024 at 7:24 PM
    #67
    lavern23
    lavern23 New Member
    Chad
    I think I will be going with Dobinsons
    Pro rated springs in the rear.
    This is the reply I got from Sumo about using these with the factory lift…
    Hello Justin here,
    Since your vehicle is a work truck, I would recommend the SSR-631-47. However, since you have a 3" lift there will be more of a gap than we recommend. This kit does not allow for spacers as it is designed for stock height vehicles
  8. Mar 1, 2025 at 9:45 AM
    #68
    Hammertimerrrr
    Hammertimerrrr New Member
    2024 MGM Limited OR
    Well, I installed the fronts a few weeks back and love the sportier handling and absorption of vibrations on gravel. Ordered the rears to minimize sag when loaded down / towing.
    it’s definitely an easy install for both. However, I overtorqued the side rear driver side bolt and snapped it…
    Will do my research but open to any suggestions as I need to
    1. Confirm the factory bolt and get it ordered - it’s a weird 12mm with the taper at the end that goes into the frame.
    2. Figure out how the hell to get the broken bolt threads out of the current hole easily. So tight in there I’m hesitant to do any dremmeling to get a small flat head in there and risk frame damage.
    ideas from the Tundras brain trust are welcome…
    as of now I only have the bottom 2 bolts secure on the drivers side which will have me taking it easier in my truck than I want to until I get it resolved. I also worry about how close they come to the brake lines and if, off center could make contact there and cause issues
  9. Mar 1, 2025 at 10:49 AM
    #69
    Retroboy1989
    Northern Utah
    I put some black ones on my 25 in anticipation of camping this summer.
    Are there torque specs on these bolts?
  10. Mar 4, 2025 at 4:51 AM
    #70
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I installed the blue ones last fall & recently had to haul some landscaping blocks. Not sure of the weight but it sat on the sumos pretty good & had a very very small amount of squat. The truck rode very nicely on those springs, better than I had thought it would. Quite pleased with the results so far.
    RickyBobbysTundra and Sacul[OP] like this.
  11. Mar 10, 2025 at 11:12 AM
    #71
    GAMark
    GAMark New Member
    I love mine. Questions, when would you need the front Sumos?
  12. Mar 26, 2025 at 9:37 PM
    #72
    Sacul
    Sacul [OP] New Member
    2024 Tundra Limited TRD
    Nothing yet
    Awesome! Glad to see this post helped so many.
    I love my rear sumo springs, hassle/maintenance free, great ride quality, a much safer ride when loaded, and no need for WD hitch.
    Unfortunately I haven’t been able to install the front springs as they wouldn’t fit between the A frame and I’m not spending that much time on it until UBJs are needed.
  13. Mar 26, 2025 at 9:45 PM
    #73
    Sacul
    Nothing yet
    The front coil springs or the front bumpstop replacements?
    The coil springs are supposed to limit vibration on rock, gravel, washboard…
    (FYI: vibrations kill these front bumpers on these trucks :mad:)
    The bump stop replacements are supposed to be for softer landings.
    If you have a negative offset like me you might blow out a fender flare every now and then (weekly) when off-roading :rofl:
  14. Mar 27, 2025 at 1:49 AM
    #74
    TheDo114
    TheDo114 New Member
    2022 Black Tundra SR5 TRD Offroad
    What do you mean vibration kills the front bumper?
  15. Mar 27, 2025 at 7:59 AM
    #75
    Third-Reef
    Third-Reef New Member
    Gary
    2025 1794 TRD offroad
    I added the air bags and they work great. I tow a 7.5K lb trailer with about 800-900 tung weight. 25 lb in the bags leveler it right out. I got the ultimates (built in bump stop) so i can run them with zero PSI when not trailering.
  16. Mar 27, 2025 at 9:37 AM
    #76
    Hammertimerrrr
    2024 MGM Limited OR
    I loved these on my Tacoma, but have now returned them for my Tundra. I'm not yet towing very frequently and will revisit when we buy a camper later this year. Rebound on these is far harsher than they were for the Tacoma. Like, started to hurt my back. I tried to get used to it over a couple of weeks but ride quality went down significantly so I've now removed the rears and will likely remove the fronts.
    Considering the Icon versions that would still soften bottom-outs without making contact as frequently as the sumos - which have very little gap and make contact on small bumps in the road that would otherwise be barely felt.
  17. Mar 27, 2025 at 9:42 AM
    #77
    Hammertimerrrr
    2024 MGM Limited OR
    These? https://www.airliftcompany.com/shop...aOZMgkK7R67Mq27TknX95UZAwTUunyTItuMaUJvMG-s0P
    Also, can you tell if the integrated bump stop is any longer than the stock one? I.e. will it hit hard, earlier or is the basically the same contact point as stock?
  18. Mar 27, 2025 at 11:08 AM
    #78
    Third-Reef
    Gary
    That is basically what I installed. My brackets look a little different. The bump stops seem about the same but you cannot see them. i did squish the bags down with no air and could feel the stops hitting at about the same height as the bump stops look to be.
    Hammertimerrrr likes this.
  19. Mar 27, 2025 at 1:53 PM
    #79
    Sacul
    Nothing yet
    I’ve seen better quality from a 3D printer than the plastic used to hold our bumper covers to the crash bar. On my truck one of them broke due to vibration and all the rest followed soon after. And because the bumper cover is connected to the grill it started sagging from the top.
    I got lucky, when I pulled the grill to put on the new bumper the only plastic connections that weren’t broke were the ones that stay on the grill after trimming for aftermarket bumper.
    I also know a guy who bought several of these trucks for his oilfield employees and he’s having the same issue.
    TheDo114[QUOTED] likes this.
  20. Mar 27, 2025 at 2:50 PM
    #80
    TheDo114
    TheDo114 New Member
    Thank you for the answer. Does that mean it’s the black part under the grill that is the problem? The part that people usually cut out when installing an aftermarket bumper? Or it’s even more than that?
  21. Mar 27, 2025 at 2:58 PM
    #81
    Sacul
    Nothing yet
    The black plastic that bolts directly to the crash bar. And yes they are scrap after installing a bumper
  22. Mar 27, 2025 at 3:00 PM
    #82
    TheDo114
    TheDo114 New Member
    Great! I was planing on putting a CBI covert bumper so it will eliminate that problem. Thanks!
    Sacul[QUOTED][OP] likes this.
  23. Mar 27, 2025 at 3:11 PM
    #83
    Sacul
    Nothing yet
    There are still two, one on each side, with the covert bumper. But yeah it seems like it should have more rigidity after installing the CBI bumper
    Good luck
  24. Mar 27, 2025 at 4:07 PM
    #84
    TheDo114
    TheDo114 New Member
    Ok so not just the black plastic under the grill but the whole bumper where it’s connected to the crash bar. I guess a I’ll keep on eye on the sides.
  25. Apr 27, 2025 at 9:05 AM
    #85
    TheDo114
    TheDo114 New Member
    Well the side pieces are already broken and the middle ones are keeping it together for now. I will try to see if I can order some replacement. No idea if it’s possible since they appear to be molded in the bumper.
  26. Apr 27, 2025 at 9:53 AM
    #86
    Kap1
    Kap1 New Member
    San Francisco, CA
    Have you guys compared Timbrens to Sump? Any pros cons?
  27. Apr 27, 2025 at 6:25 PM
    #87
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    Installing these this Friday… Dayton CargoMaxx HD Coil springs.
    Update:
    Installed and I don’t notice any unladen ride quality difference… picking up my camper this week so I’ll get to evaluate towing with the HD springs then.
    It did raise the RR end by 1” exactly. The extra rake isn’t crazy looking.
    TheDo114 likes this.
  28. Apr 27, 2025 at 7:59 PM
    #88
    Retroboy1989
    Northern Utah
    I've been running the black sumo springs for a couple thousand miles now. Normal ride quality is unaffected. The only time I notice them is on a hard bump at low speeds like a pothole or dropping off a speed bump. I think I'm feeling them hit the frame on those cases.
    Tundrastruck91 likes this.
  29. May 8, 2025 at 5:16 PM
    #89
    Spartanfam
    West Michigan
    My trailer tongue weight (dry) is 800 lbs on the dot. It used to severely sag the back and would level out with weight distribution. I added the CargoMaxx springs… and it now sets level by all accounts… before the WD is set. I will need lighter weight bars for the BlueOx WD to provide proper sway control… but what a difference in stance!
    Retroboy1989 and Raven67 like this.
  30. May 8, 2025 at 7:48 PM
    #90
    Retroboy1989
    Northern Utah
    I've noticed the black sumo springs have made the rear end ride really firm.
    Do they break in?
