No Nickname '24 Tundra
Discussion in '3rd Gen Builds (2022+)' started by 6rian, Feb 28, 2024.
  1. Aug 29, 2024 at 2:45 PM
    #91
    6rian
    6rian [OP] New Member
    lol it was a piece of packing foam. Gets me every time I see that clip.
  2. Sep 8, 2024 at 8:02 PM
    #92
    6rian
    Had my brother 3D print me a cover plate for my K&N intake filter housing. His printer isn't big enough for the overall dimensions needed, which is why the edges don't mate up at the top corners. Doesn't bother me though since there's still enough overlap of the two pieces to create a seal. The gaps also act as a recess to aid in lifting the cover when needed, so I'll call it a feature. I may add some sort of gasket later to ensure it's sealed 100%. Now, the housing has only one inlet utilizing the factory intake fender cutout.
    BreyTundy likes this.
  3. Sep 15, 2024 at 8:55 AM
    #93
    6rian
    Front glass on. Had the underside sprayed with bed liner for added strength and durability. Need to come up with a new fender liner and something to guard the inlet for the intake from our PNW climate.
    Bedsides next.
    ReCKzX and chunkytundra like this.
  4. Sep 15, 2024 at 9:29 AM
    #94
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    Are you in Beaverton??
    6rian[OP] and reywcms like this.
  5. Sep 15, 2024 at 11:55 AM
    #95
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    We both are yes lol
  6. Sep 15, 2024 at 11:55 AM
    #96
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I have an idea for this. Easier on yours since you have double layers of areas. Hotrod louvers like I did work well
    6rian[QUOTED][OP] likes this.
  7. Sep 16, 2024 at 9:21 AM
    #97
    6rian
    Good idea. Tricky part is finding one that’ll cover the entire inlet in that triangular area. I have some foam that’ll I’ll use temporarily while I see if I can find or 3D print something that fits.
  8. Sep 16, 2024 at 9:39 AM
    #98
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Bought a large one cut it down to fit and then blacked it out. Old pic for reference
  9. Sep 16, 2024 at 8:05 PM
    #99
    6rian
    Clean! I have an idea if I can’t find the right louver or mesh to work with. Looks like there’s plenty of circular vents I could use that’ll fit with some creative mounting.
    reywcms[QUOTED] likes this.
  10. Sep 28, 2024 at 4:55 PM
    #100
    6rian
    My not-so-elegant-but-works-for-now solution for the exposed intake inlet. I used the factory intake box snorkel and cut it down to lay flat against the sheet metal. This allows me to wrap the snorkel with a pre-filter to block the elements when needed. It's a direct shot into the intake box. Won't do much for blocking rocks and other stuff from collecting within the two walls, but I'll probably add something there to shield it temporarily.
  11. Oct 13, 2024 at 7:50 PM
    #101
    6rian
    Finally took the truck out to the dunes for a quick run to see how it does as it's been. All I'll say is LSK needs to hurry up and release a race kit.
    A couple photos from the day but no videos. I guess I need a GoPro too. lol
    ATV25, RealTruck, ramnj and 3 others like this.
  12. Oct 13, 2024 at 7:55 PM
    #102
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Such a sweet truck!
  13. Oct 18, 2024 at 10:50 AM
    #103
    6rian
    Bumper is close to being done. Just needs the bash plate and some black steel-it and then it's on its way to me.
    JrJrOffroad, AND and BabyMoose like this.
  14. Oct 22, 2024 at 5:40 AM
    #104
    BabyMoose
    BabyMoose New Member
    2023 Tundra Limited TRD Off-Road
    CBI bed rack, Decked storage, OVS Nomadic 2 RTT, Ironman DeltaWing 270
    Looks killer! Does it affect any sensors? Looks like the cut is low enough that at least some don't need to relocate?
    Also, what catch can setup did you settle on? Looks like there is an additional can with AN fittings that wasn't in your last post about a diy setup?
  15. Oct 22, 2024 at 8:00 AM
    #105
    6rian
    I already took out my sensors but they'd have to be relocated if I wanted to use them. The other can is from HPS.
  16. Oct 22, 2024 at 8:02 AM
    #106
    BabyMoose
    Gotcha. Do you get a bunch of errors when driving? Running 3 cans?
  17. Oct 22, 2024 at 7:27 PM
    #107
    6rian
    No errors. 3 cans but the single PCV can is really the only one that catches anything.
    BabyMoose[QUOTED] likes this.
  18. Oct 25, 2024 at 11:13 AM
    #108
    6rian
    Bumper was sprayed and the aluminum plate was cut out. Just needs a little more dry time.
    BabyMoose likes this.
  19. Oct 31, 2024 at 8:35 PM
    #109
    6rian
    My prerunner bumper is finally here and on my truck. Worth the wait.
    ATV25, RealTruck, AND and 2 others like this.
  20. Nov 1, 2024 at 11:15 AM
    #110
    AND
    AND New Member
    Washington, PNW
    Holy shit that looks good!!!
    Mind me asking how much it was delivered, I am also in PDX area up north in Ridgefield,WA
    6rian[QUOTED][OP] and reywcms like this.
  21. Nov 1, 2024 at 12:40 PM
    #111
    6rian
    Thanks! It was close to $2K raw and after shipping. Add a couple hundred if you want it powder coated. You likely won’t be able to get one made from him unless he’s got your truck or has another one whose owner doesn’t mind them using it to build off of since he builds them as one-offs. I got lucky with the latter.
  22. Nov 1, 2024 at 3:14 PM
    #112
    RealTruck
    RealTruck New Member Vendor
    Well worth the wait! This is an incredible build!
  23. Dec 3, 2024 at 5:13 PM
    #113
    6rian
    Parts pile is piling again. Winter boredom in full effect.
    Remote trans cooler project is underway. Trying not to obstruct the radiator any more than I already have. I could fit it behind the grill with some creativity, but I decided to mount it to the backside of the bash plate and have the fan pull air. Bar and fins will be protected with a stainless mesh screen. This is a semi-permanent location until this truck gets a bed cage.
    BabyMoose, RealTruck and reywcms like this.
  24. Dec 3, 2024 at 9:15 PM
    #114
    6rian
    Cutout done and trans cooler bolted up to the plate. May add some additional bracing later but it feels sturdy enough to hold up to my driving style. Just waiting on some mesh and deciding if I should leave it as is or paint it all black.
    AND, BabyMoose and RealTruck like this.
  25. Dec 10, 2024 at 7:38 PM
    #115
    6rian
    Mesh screen riveted on. Just waiting on a couple AN fittings and then just a little plumbing to complete this project.
    12/25/24.
    Painted with black Steel-It for a more subdued appearance. Also, got all the parts I need to install and plumb the trans cooler behind the mesh screen but been busy with work and Holidays. Might wait until the snow/ice storm hits and need a project to stay busy at home.
  26. Jan 31, 2025 at 4:14 PM
    #116
    6rian
    Finally making some progress on the trans cooler. Decided to ditch the bash plate idea and mount in the bed on the chase rack. This allows me to use the larger 25 row unit from Derale.
    Rather than cutting a large square out from the upright, I used 3/4" spacers to net a gap of 1.5" between the cooler and upright. Seems to allow plenty of air flow with the fan pulling air. If I need more, I can swap out for larger spacers.
    All that's left to do is the plumbing and wiring up the fan switch. Plan is to use the Improved Racing thermostat and bypass the radiator to make this a stand-alone system.
  27. Jan 31, 2025 at 8:02 PM
    #117
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Awesome build man. I would love to build something like this. Do you leave the chase rack in full time? Seems like a big unit to be moving around.
  28. Jan 31, 2025 at 8:46 PM
    #118
    6rian
    Appreciate that!
    The rack stays in full time. It's a bit over-built in my opinion (weighs 100lbs bare), but it was designed to be modular so the user could configure it however they wanted to with whatever gear they carry. The alternative would be a more simple tube design. I've moved the chase rack in and out several times now and have a good process to do it alone.
    reywcms and az 3rdGen[QUOTED] like this.
  29. Feb 1, 2025 at 11:42 AM
    #119
    6rian
    When I can't sleep, I hang out in the garage looking for small projects. This time it was mounting the Scangauge onto the 3D printed sPOD cradle. Used some brackets and hardware I had laying around and this was the result. Beats using an ugly suction cup mount.
    60centenergy, BabyMoose and reywcms like this.
  30. Feb 28, 2025 at 4:45 PM
    #120
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    Are you selling the ADD bumper by chance ?
