Largest Spare Tire size
Discussion in 'Wheels & Tires' started by C2Tundra, Feb 10, 2023.
  1. Aug 31, 2024 at 2:00 PM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    What mounts are you talking about, just got rim, now going to get the tire so I can mount full size spare 295/65/20
  2. Sep 11, 2024 at 7:18 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    The little arms that stick out to center the tire
    machd08[QUOTED] likes this.
  3. Sep 18, 2024 at 9:18 AM
    machd08
    machd08 New Member
    CLARENCE
    I can verify that a 295/65/20 Michelin Defender LTX Platinum aired down to 20 PSI WILL NOT FIT in Spare Tire Location for 24 1794. Just tried to get it to fit for the last hour, hits the pan bar and hitch will not go past it. So now gotta figure out what I am going to do for a full size spare.
  4. Oct 12, 2024 at 10:22 AM
    4x4Remedy
    4x4Remedy New Member
    24 Tundra
    3” Toyota factory lift. Icon 17” wheels
    Thank you! Unfortunately my Falken wild peak AT4w doesn’t fit without rubbing on the pan hard bar. I looked into it and that Toyo is dimensionally 34.5” and my Falkens are actually 35”. I lose that 1/2” that you have to spare. Now I need to figure out what to do with my 5th wheel set up… IMG_1805.jpg
  5. Oct 25, 2024 at 7:52 AM
    Cassidy1866
    Cassidy1866 New Member
    2023 Tundra Limited TRD Off-Road
    I was considering trying the Falkens next time around so this is good too know. Thanks for sharing and let us know what you come up with as a solution for the spare.
  6. Oct 25, 2024 at 8:01 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    If you can find a cheap 17" wheel, a 285/75-17 tire is close to being a skinny 35. But 285 vs 295 isn't much width change so as far as how much it hangs down, not sure if you could even see the difference. For clearing other parts though, 10mm difference might be enough?
  7. Oct 26, 2024 at 4:10 AM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Will a 18 nitto fit on spare to replace 18 stock tire. Just wondering because the nitto has a more aggressive tread pattern
  8. Nov 9, 2024 at 6:34 PM
    4x4Remedy
    24 Tundra
    I just dropped the pressure down to 10PSI and it fits. It’s a pain to get it to raise at the perfect angle, but once you get it there is about a 1/4” clearance. I can take some pics if you are still considering.
    Cassidy1866[QUOTED] likes this.
  9. Feb 3, 2025 at 7:42 AM
    HS25Tundra
    HS25Tundra New Member
    2025 Lunar Rock Tundra Limited Hybrid 4x4
    I’m actually considering the Falkens since I’ve had them in the past. What size wheel/tire are you running? I’m planning on doing the 285/65R20 falkens and the width is technically 34.6 so wondering if that’ll clear it without lowering the PSI.
    did you ever get this setup up and running? Were you able to clear the spare without issues?
  10. Feb 3, 2025 at 1:46 PM
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    What did you end up doing for a spare? I have 35x11.5R18 Falkens but I'm not sure the full size spare will fit. I have seen someone fit a 285/75R18 though.
  11. Feb 5, 2025 at 3:18 AM
    4x4Remedy
    24 Tundra
    I just dropped the PSI to 10 and it fits. I carry a Milwaukee inflator.
    Hoody likes this.
  12. Feb 5, 2025 at 9:13 AM
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    315/70/17 BFG KO2 fits. Tech at Discount said it wasn’t easy but it fit.
  13. Mar 17, 2025 at 3:01 PM
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    Did you end up doing a 285/65/20? If so, did it fit?
  14. Jul 2, 2025 at 5:59 PM
    UPSS2K
    UPSS2K New Member
    Erik
    2019 Super White TRD PRO
    none yet
    Ok, My new to me 19 TRD Pro is getting delivered tomorrow, hopefully. Im planning on going with a 285/75/18 all the way around and plan on doing the spare this size also. Looks like from what I'm reading it should fit but will be tight, correct?
