  1. Oct 11, 2024 at 8:22 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I think I had that issue too. I don't recall if we already talked about it. Between the two trucks I've had quite a few O2 sensor codes in the last three years. But do you have one spacer per sensor? I tried doing two per sensor on my 03 at first, and the codes just changed. I think it was p0136 and p0156. So I only did one on each and the 420/430 came back. I solved it by using URD o2 sim I scored used.
    Have you installed all four new Denso sensors?
    On my 06, I think I was getting p0138 and p0158 until I swapped the front two sensors. I remember being mad that none of the recommendations for the fix included changing the fronts. But someone here told me to try it and it worked.
  2. Oct 11, 2024 at 8:26 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I only installed 1 new sensor. I get annoyed messing with them haha. I have 2 spacers in each side.
  3. Oct 11, 2024 at 8:27 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'd try dropping it down to one per side on the rears.
    Are you on aftermarket cats or what?
  4. Oct 11, 2024 at 8:32 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Some bullshit little cats the previous owner put on. Thinking about welding some aftermarket in.
  5. Oct 11, 2024 at 9:10 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Got a slight pull to the left. I'm guessing it's the toe or the caster. But I don't know.
  6. Oct 11, 2024 at 9:37 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Those numbers are wack.
    Needs slight toe in and more caster.
    Is this the 4x4? What year?
  7. Oct 11, 2024 at 10:10 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    2006 4wd with 3" lift, SPC UCAs (adjusted one click from as far forward caster as possible), and 33's.
    Dude said my LCA bolts are seized, but he'll try again.
    I'm going to be buying some Solo LCAs, uniball lbjs and some off road alignment cams for Black Friday once the sales hit. But in the meantime, I'd like it to track straighter. I feel like it was tracking straighter before the alignment honestly. Only reason I got it aligned was because it had been at least 2 years, maybe 3 and I off-roaded it at least 5+ times since then.
  8. Oct 11, 2024 at 10:15 PM
    Sirfive
    Sirfive Working on pavement
    ‘02 Limited AC TRD
    Bassani cat-back
    How much room do i need in the fan side of this inverter?
    Battery mounted to the frame behind the shackle in the bedside?
  9. Oct 11, 2024 at 10:19 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I appreciate how many best gens dont bother with the home screen. Nothing exists outside the fat taco section.
  10. Oct 11, 2024 at 10:34 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Since you're clicked forward on the SPC uppers, that leads to low caster and wandering.
    Given your current numbers, with the lower cams seized I'd try:
    2 or 3 positions back on drivers side
    1 or 2 on passenger side
    (From being pointed straight inwards at the truck.)
    Then slide the SPC's in or out for camber, shooting for -0.3 to -0.5
    .10 - .15 total toe
  11. Oct 11, 2024 at 10:40 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    My concern with going back on the caster is I'll rub.
    I'll let Juan take another crack at it Tuesday or Wednesday when he does my drain n fills and go from there. Worse case scenario, I'll just live with it til I can buy and install the aforementioned new parts.
  12. Oct 11, 2024 at 10:43 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Not likely at the upper. A few mm of movent usually.
    The hub/wheel is at the bottom of the knuckle. Thats why you pull the lowers forward, to clear the footwell. Gets you an inch or two of clearance.
    Since you're going back, undo one of the uppers and measure it (for science!).
    des2mtn likes this.
  13. Oct 11, 2024 at 10:44 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I meant rub the firewall when stuffing my 295/75r16's. That's the whole reason I moved em so far forward a few years ago.
  14. Oct 11, 2024 at 10:49 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Yep, we meant the same thing. Footwell is the rear side of the fender well. The firewall.
  15. Oct 11, 2024 at 10:49 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Sounds like a job for sawzall.
  16. Oct 11, 2024 at 10:50 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    And his sidekick BFH.
  17. Oct 11, 2024 at 11:11 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I thought you were saying something about rubbing the UCAs. NVM.
  18. Oct 11, 2024 at 11:12 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Not much more I can cut without welding/tubbing
    JakeJake likes this.
  19. Oct 11, 2024 at 11:16 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    My guess would be at least two or three inches. But I'm only basing that off my experiences with box fans. Too close to a wall and they don't blow as well.
  20. Oct 12, 2024 at 5:43 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  21. Oct 12, 2024 at 5:47 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Road debris?
    Tundra2[QUOTED] likes this.
  22. Oct 12, 2024 at 5:48 AM
    Damn. Got both wheels. What did ya hit?
    Tundra2 likes this.
  23. Oct 12, 2024 at 5:48 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    You're supposed to go around the stop sticks.
  24. Oct 12, 2024 at 5:54 AM
    Dangit man. This has a story attached to it. front rim looks like multiple curb strikes. You fall asleep? Gotta be careful burning the candle at both ends, take care of yourself brother.
    bmf4069 and Tundra2[QUOTED] like this.
  25. Oct 12, 2024 at 5:58 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Rip rap.
    The same old song and dance, deer swerve, into the median, out of the median.
    The usual
  26. Oct 12, 2024 at 6:00 AM
    Sucks man. That's probably a hell of a ride over rip rap in a small sedan! Just the rim and tire damage? JY will have lots of corrolavirus rims, many with usable tires for cheap. Been there....
  27. Oct 12, 2024 at 6:12 AM
    Not just flat, mangled!
    I guess it’s good you didn’t have nice wheels.
  28. Oct 12, 2024 at 6:21 AM
    JakeJake
    2000 Tundra AC 4X4
    Deer hate this :rofl:
  29. Oct 12, 2024 at 6:34 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :redxfall:
  30. Oct 12, 2024 at 6:40 AM
    Oddly, I can see the preview thumbnail, but when opening the thread, the madmax cow dissolver bumper is not visible.
