2006 Tundra Rust
Discussion in '1st Gen Tundras (2000-2006)' started by LukesTundra, Oct 8, 2024.
  1. Oct 8, 2024 at 1:37 PM
    LukesTundra
    LukesTundra [OP] New Member
    Luke
    2006 SR5 Tundra
    Hello! I have this 2006 Tundra and Im worried about the rust on the frame. There are some areas I am concerned about but no obvious holes or frame rot. Let me know what you think!
  2. Oct 8, 2024 at 1:54 PM
    Yeah, that's pretty fucked. And it's '06 so doesn't qualify for recall. You pictured one important spot, 2nd pic, that frame stiffener, you can clearly see the steel has already delaminated. You know the other places to check, right? If not, READ HERE.
    Meanwhile, is this a hole thru the frame? This is one of the spots we see frames snap, on driver's side. There's a link to pics of a frame in pristine shape that snapped in that spot.
    If you haven't bought this truck, walk away. If you have bought this truck, I recommend doing everything in your power to return it! That's some bullshit right there.
  3. Oct 8, 2024 at 2:27 PM
    Mr Badwrench
    Mr Badwrench New Member
    You can get a few more years on that, I'd bet. It won't be much fun to work on as far as shocks, steering ends and ball joints though. Mine is worse than that.
    Gray06 and Theseus'_Tundra like this.
  4. Oct 8, 2024 at 2:29 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
  5. Oct 8, 2024 at 2:29 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Parts truck. Also broken sway bar mount.
    BroHon and FrenchToasty like this.
  6. Oct 8, 2024 at 2:43 PM
    You’re just now noticing this rust? How long have you owned it? Not good from the looks of it.
    Start looking over your power steering, brake and fuel lines for similar rust because now is the time to protect them from further corrosion or face potential leaks like me.
  7. Oct 8, 2024 at 3:27 PM
    bfunke
    bfunke Tundra Curmudgeon
    Stage 3 cancer
    G_unit3000 likes this.
  8. Oct 8, 2024 at 4:17 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Hideous.
  9. Oct 8, 2024 at 6:23 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    We think its bad, the frame stiffener in the back, is totally delaminated and the frame is pooched out, this is a strengthening brace, and its weakened, so the frame is weakened. This is bad um'kay
    The sway bar link is rusted thru, the thin end where the threads are often times rusts smooth thru and the sway bar end link pops the top off after rust starts eating thru the necked down part of the bar link end. You will need new sway bar end links.
    You will also need a LOT of rust converter and a lot of hopes and prayer to hope this frame makes it out of its aggressive cancer stage. Its going to take lots of radiation (rust converter) and likely multiple chemo treatments (more rust converter) and then some bed rest (coating with an epoxy paint to create a hard shell over the frame) or keep a crap ton of rust inhibitor on the frame like many people up north use.
    I have seen worse on the road
    I have been under worse that were on the road
    I have seen them fall apart with less rust than that too.
    Cross your fingers, hit it hard with chemo and radiation, and hope you can get that cancer under control before it kills its host.
    G_unit3000 and BroHon like this.
  10. Oct 8, 2024 at 6:33 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    That's just to take care of the stuff you can see. What about the fully boxed sections?
    G_unit3000 and Jack McCarthy like this.
  11. Oct 8, 2024 at 6:54 PM
    I’d hate to see what’s inside the frame rails!
    G_unit3000 and ATBAV8[QUOTED] like this.
  12. Oct 8, 2024 at 7:02 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  13. Oct 8, 2024 at 7:04 PM
    LukesTundra
    Luke
    2006 SR5 Tundra
    Ouch.
    Jack McCarthy likes this.
  14. Oct 8, 2024 at 7:18 PM
    Mr Badwrench
    New vehicles are pretty steep these days 4$,$$$+ along with the insurance to cover them.
    Just saying.
    If a vehicle is capable of getting you to work, especially if its paid off, then it's a winner.
    Gray06 and FrenchToasty like this.
  15. Oct 8, 2024 at 7:29 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Good eye, I missed that totally!
  16. Oct 8, 2024 at 7:30 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    rest of the swaybar is held on by hopes & dreams, so maybe its for the best.
  17. Oct 8, 2024 at 8:25 PM
    badass03taco
    Yeah I mean… it’s in bad shape 4sho. Inside the frame is gonna be worse than what you see on the outside. Inside rails are always worse. Seen plenty of frames rust out from the inside out boxed tuning that held water/salt/chemicals and one day it’s a flexi-flyer bending like a pretzel. Then you start seeing holes pop thru, as the rust eats the frame from the inside out.
    ATBAV8[QUOTED] likes this.
  18. Oct 8, 2024 at 8:32 PM
    I’d get an air hose and blow the rust out from the inside of the rails up front after getting a wire brush in there to take off the flakes. You’ll have enough rust that you can add aluminum powder and make thermite.
    ATBAV8 and BroHon like this.
  19. Oct 9, 2024 at 2:14 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    DAMMIT, and I just threw the 2 or 3lbs of mine in the trash!:rofl:
  20. Oct 22, 2024 at 11:15 AM
    MI Tundra
    MI Tundra New Member
    2005 DC
    I use RP-320 on my undercarriage/frame. Maybe look into it for your truck. I’ve been doing mine every fall (the past 4-5 years), to try and keep the undercarriage strong. This year I did the spring and fall.
    Cost wise, it’s about 4-5 cans to do the truck, roughly $50.
  21. Oct 22, 2024 at 2:17 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    You mean this? Or do you have a link?
    https://www.amazon.ca/Cosmoline-RP-342-Rust-Preventative-Military-Grade/dp/B01MTV41O0?th=1
  22. Oct 23, 2024 at 12:26 PM
    MI Tundra
    2005 DC
    Sorry about that. Yes that is the stuff I use.
  23. Oct 23, 2024 at 12:55 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    I would say put it out to pasture but it looks like its been out in one for a while.
    shifty` likes this.
  24. Oct 23, 2024 at 1:29 PM
    Damn. I resemble that remark.
    :sadviolin:
