  1. Oct 5, 2024 at 3:46 PM
    #7411
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Added rock lights via diode dynamics bed light kit to have approach lights. In this picture they’re on low mode. Now they’re on high.
    added some big bangers hxb’s. Just need to wire them up.
  2. Oct 6, 2024 at 5:09 AM
    #7412
    ansel123
    ansel123 New Member
    Sr5 2024
    Several
    10 inch behind seat night and day difference highly recommended
  3. Oct 6, 2024 at 8:08 AM
    #7413
    TRD_TUNDRA
    TRD_TUNDRA New Member
    2024 Tundra TRD Off Road and 2024 Sequoia TRD Pro
    Full-size 37” bed mounted spare set-up. I like chase racks but wanted something that would lay flat so I could keep it covered under a tonneau cover. This set-up seems popular with Raptors and I found a shop that would make one to the Tundra dimensions.
    The main piece is a horizontal Badland jack mount from JDS Customs. This piece is the exact width of the forward bed mounting bolts and utilizes those to bolt the mount to the bed floor. This mount has a D ring mounted in the center for the tire tie down strap. The mount is designed for a Grove Fabworks Badland jack cradle. Additionally from JDS Customs are two separate bed bolt mounted D rings, placed under the middle two factory bed bolts.
    The second piece of the set-up is a Badland jack carriage from Grove Fabworks. Like I previously said, this bolt directly to the JDS Customs mount.
    The last piece of the set-up is the Y style tie down strap from Alpine Offroad.
    The whole set—up is completely bolt on, no additional holes needed to be drilled.
    Txrx, AND, ManUtdFC28 and 11 others like this.
  4. Oct 6, 2024 at 5:35 PM
    #7414
    mfa1981
    mfa1981 New Member
    Marcel
    2024 Nightshade Limited
    Full camo kit on my Limited, Heritage grille, front and rear marker as well as flare marker. Still waiting for my Baja Designs so the bumper is gonna come out again. Also the most difficult mod of all the Meso Lights, I couldn't take that main harness out no matter what, ended up tapping into the wires and had to do everything with it hanging by the harness
    462261742_10162952512014523_531642597504_3a0cfff3fc6b7efa559fe0d207ea0e4345421ba2.jpg
    462297558_10162952512384523_210326415349_48445d5011aa19f1c240b2d92ecb5bd834d69420.jpg
    462448235_10162952512784523_260074384566_afe8bb0564b5fb2c4d19b1f3bd9ea7ae67c1cbdc.jpg
    462287083_10162952512324523_297760895196_9b3134cb62063f2a43bd2fc4b9e478c9898c73f7.jpg
    462203015_10162952511994523_611988922651_6caa4f4887461e380de01fe49ee06e43570ddf19.jpg
    462228106_10162952511984523_896185023068_e54bcfd3ba68128da87c806efde1ea3c6120ee8b.jpg
    462227452_10162952511914523_121578804331_904e57b8321b332ddd9439e6503b3186971ee133.jpg
  5. Oct 7, 2024 at 9:33 AM
    #7415
    Ipaddick
    Ipaddick New Member
    Canada
    Looks good! I still need to do the spoiler.
    wires my big bangers today.
    Blufin and PBNB like this.
  6. Oct 7, 2024 at 9:44 AM
    #7416
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    You have some serious lights going on there!
    Are those Fogs DD's in white?
  7. Oct 7, 2024 at 11:20 AM
    #7417
    Ipaddick
    Ipaddick New Member
    Canada
    Yessir.
    ss18 white grill bar and ss18 bumper bar as well.
  8. Oct 7, 2024 at 11:32 AM
    #7418
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have a S18 in the grille white driving configuration, I still have to aim it and damn thing is bright.
    Looking forward to getting my S6 amber fogs in, but I need to pull the front and deal with the painting of the silver stache black.
    What lights did you pick for the rock lights? Are they switchable from inside?
  9. Oct 7, 2024 at 1:40 PM
    #7419
    Ipaddick
    Ipaddick New Member
    Canada
    You can do the fogs without pulling the front end off.
    They are DD rock lights. I used the bed kit, so controlled by the bed light switch. They way they turn on when unlocked or a door is open. I didn’t want them to be on when driving around, more as ahh approach light. But again I could turn them on with the bed lights if I changed my mind.
    kirkb likes this.
  10. Oct 7, 2024 at 1:47 PM
    #7420
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I didn't know that about the fog lights? I thought there were some screws buried in there. Is it just a matter of releasing the clips for that section? It would be much easier to aim them as well if the grille stays installed.
  11. Oct 7, 2024 at 1:51 PM
    #7421
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Pointer to rock light install - https://www.tundras.com/threads/puddle-light-install.139348/#post-3564455
    gesekee19 likes this.
  12. Oct 7, 2024 at 2:05 PM
    #7422
    Ipaddick
    Ipaddick New Member
    Canada
    Just remove the fog surround and you can access the screws and wiring. Easy peasy.
    kirkb likes this.
  13. Oct 7, 2024 at 2:06 PM
    #7423
    Ipaddick
    Ipaddick New Member
    Canada
  14. Oct 7, 2024 at 2:25 PM
    #7424
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Well that's good to know. Their install video shows them removing the entire grill
  15. Oct 7, 2024 at 2:33 PM
    #7425
    jctmundra
    Northern VT
    OK, I tapped the wires in the cab. Plug-in-play is the way to go.
    Ipaddick[QUOTED] likes this.
  16. Oct 7, 2024 at 3:45 PM
    #7426
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Thanks for the tip @Ipaddick I popped the surround off the fog lights and put the DD S6 ambers in. Took very little time and now they are in and adjusted. Should be great when we get some crappy weather.
    kirkb[QUOTED] and Ipaddick like this.
  17. Oct 7, 2024 at 3:50 PM
    #7427
    mfa1981
    mfa1981 New Member
    Marcel
    New shoes, decided to go with Defender LTX Platinum since I drive 99% of the time city/highway not offroading 275/65/R20462235324_10162954073169523_382577544253_3fc913d112bcc75ea513eb51da63801d7a2c72ca.jpg
  18. Oct 8, 2024 at 4:15 PM
    #7428
    Kerktam
    Kerktam Lexus truck wanted
    middle of nowhere, up north
    2023 limited TRD OR, 2024 silverado 5.3
    35 tires, 2 inch level kit
    Got trd pro hood scoops. Still debating if I like them
    mikev25, Raven67 and Tundrastruck91 like this.
  19. Oct 8, 2024 at 4:21 PM
    #7429
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    Seems all these trucks need something on the hood to break up the lines. I dig it, but I know folks will call you a PROser. Rave sells inserts to replace "pro" with your trim or whatever else you'd like. If you decide you don't like them, hit me up. I'll give them a shot without shame.
  20. Oct 8, 2024 at 10:37 PM
    #7430
    Kerktam
    Honestly I'm ok with trd pro badge, it's looks better than rave stuff. I know that my truck is not trd pro model but I did not want hybrid anyway and just trying to make truck to look good to me ( not to mimic trd pro ). I don't like black mirrors on trd pro and black accents/spoiler on tailgate either.
    But I do like trd pro scoops, my wife says it looks bad "a" and that's all I care about lol
    mikev25, Raven67 and ramnj like this.
  21. Oct 9, 2024 at 12:20 AM
    #7431
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Boxed up this piece of crap and got it ready to ship back out
    mayan, maldo012, kirkb and 1 other person like this.
  22. Oct 9, 2024 at 7:30 AM
    #7432
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Looks good! Thinking about this myself on my limited after I do the level kit & tires, gotta wait & see how it all looks.
    Kerktam[QUOTED] likes this.
  23. Oct 9, 2024 at 9:48 AM
    #7433
    mikev25
    mikev25 New Member
    Kansas
    2022 MGM SR5
    TRD lift, wheels, tires, AlphaRex headlights
    Installed EGR flares over the weekend. Spidertrax 1" hubcentric spacers will go on today and have 295/60 BFG KO3's going on next week! Worried about the added weight with 10 ply, but oh well. Now I'm cool.
    maldo012, ramnj, Kerktam and 4 others like this.
  24. Oct 9, 2024 at 3:10 PM
    #7434
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    Had the dealer change the oil at 1000 miles.
    CrayCray, Ausfahrt, Zudrick and 2 others like this.
  25. Oct 9, 2024 at 3:12 PM
    #7435
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Please let us know what you think of those headlights. They look sharp!
    ramnj and Kerktam like this.
  26. Oct 9, 2024 at 4:47 PM
    #7436
    chunkytundra
    chunkytundra New Member
    SOCAL
    KING 2.5 Coil Over Resi W/ Adjuster KING 2.5 Rear Shock Resi W/ Adjuster KING Rear Sway Bar Billet Link Kit KING 2.0 Rear Bump Stop Kit MAZZULLA Billet UCA MAZZULLA Billet Trailing Arms DR.KDSS Track Bar Correction Kit PERRY PARTS Front Bump Stops BAJA DESIGN 9 XL Linkable Roof Bar Kit BAJA DESIGNS XL Sport A-Pillar BAJA DESIGNS S8 20" Behind Bumper Light Bar BAJA DESIGNS S2 Dual Fog Light Kit BAJA DESIGNS S8 20" For TRD Heritage Grill BAJA DESIGNS S2 x2 Chase Lights BAJA DESIGNS S2 x2 Flush Mount Revers Lights BAJA DESIGNS Rock Light Kit SPOD HD BantamX SDHQ Built A-Pillar Light Mounts ALPHAREX Nova Headlights RRW 17x8.5 ET 0 TOYO TIRES RT Trails 37x12.5R17 Extended Brake Lines INNOV8 Racing Billet Bed Support Kit PERAGON Tonneau Cover Limited HDx CHARVONIA DESIGN Billet D-Rings ALPINE Off-Road Y Strap TRD Heritage Grill TRD Pro Marker Lights TRD Camo Fenders TRD Skid Plate W/ Black Lettering Gold Hook "TRD 4x4 Sport" Replacement Bedside Decals in Black/Gray/Silver Colorway SEIBON CARBON RR-Style Carbon Fiber Hood Painted/Matte Clear Carbon Fiber
    They are a must have, if you do not have the premium headlights.
    The output is so much better than before. I got them with the amber I think it looks perfect on white.
    jaxadam, mikev25, maldo012 and 6 others like this.
  27. Oct 9, 2024 at 6:08 PM
    #7437
    Hye_Tundra
    Hye_Tundra Fortune Favors The Bold
    LEV
    Los Angeles, CA
    25’ CSM Limited TRD OR
    jachal, ReCKzX, Ipaddick and 6 others like this.
  28. Oct 9, 2024 at 11:07 PM
    #7438
    Kerktam
    installed ( finally) trd pro hood scoops/plastics on the hood. Placed order on trd pro fender flares
    PBNB and Raven67 like this.
  29. Oct 10, 2024 at 7:57 AM
    #7439
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    Smart move.
    ramnj[QUOTED] likes this.
  30. Oct 10, 2024 at 8:16 AM
    #7440
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I saw a 22 for sale with these hood pieces on it in Craigslist. I thought they put them on to make it look like it wasn't part of the recall by giving the hybrid look.
