  1. Oct 4, 2024 at 3:37 PM
    Openbaffle
    Openbaffle New Member
    Took a picture of my truck in my driveway. Had a tasty IPA.
  2. Oct 4, 2024 at 4:53 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Good looking truck
  3. Oct 4, 2024 at 5:55 PM
    shifty` Goons of Hazzard
    Good looking beer.
    (Burial is solid)
  4. Oct 4, 2024 at 8:33 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Wish had a road force balancer. Anyone balance tires at home? Dreaded going in to the shop after cross rotating at home and ending up with front balance vibration.
    Warning that maybe should have known already....
    Went in for tire balance with newer coated rotors and brought own torque wrench to spec them myself, but didn't expect the tech to whip out a wire wheel on a drill after dismounting the tire and try to remove nonexistent rust ... but successfully remove part of coating from the new rotor's coated hat.
    Stopped it before they got to the 2nd one when he said it was to remove the rust, so explained he would be causing it to form..look it's clean because its almost new.:facepalm:
    Asked em to make sure and not over torque and they promised to hand tighten then watched em ugg dugga them before whipping out the wrench. Some where tighter than others coming off in the parking lot and back on with care.
    They did get the wheels balanced.
    Oh well. Guess will be shopping for a wheel balancer next...
  5. Oct 4, 2024 at 8:35 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Homeboy woulda eat that wire brush.
    oscardog86 and FrenchToasty like this.
  6. Oct 5, 2024 at 3:53 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    nice truck. Whos the IPA made by?
  7. Oct 5, 2024 at 4:18 AM
    Openbaffle
    This is Burial out of Asheville, NC.
  8. Oct 5, 2024 at 4:27 AM
    Hooptytrix
    Dirty South
    Hate to say but that just might be the last of that IPA, Asheville is destroyed. Wifey has people in that area and the level of destruction is really bad
  9. Oct 5, 2024 at 6:04 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    can you crawl under your truck and check the numbers & letters on your calipers? It may help you from buying the wrong pads. Toyota dealers uprated the early trucks with the larger calipers for later trucks back in the day, so yours could have either larger or smaller.
  10. Oct 5, 2024 at 6:09 AM
    New door checks arriving today. The scarlet pimp don’t mess around.
    oscardog86, BroHon, Sirfive and 2 others like this.
  11. Oct 5, 2024 at 6:25 AM
    bfunke
    bfunke Tundra Curmudgeon
    Even worse north of there.
  12. Oct 5, 2024 at 7:56 AM
    That's a great brewery.
  13. Oct 5, 2024 at 10:00 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Threw together this quick spare tire setup in preparation for the MERUS meetup in a few weeks. Ultimately this area will be covered/boxed in so this will likely see some revisions as that part of the build materializes.
  14. Oct 5, 2024 at 10:28 AM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    I was gonna order all new lock cylinders for 290. My problem is that my ignition was replaced so now I have two separate keys, unfortunately my tailgate doesn’t match either key…anyways is it cheaper to do what you’re doing?
  15. Oct 5, 2024 at 10:32 AM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    Will that work for double cabs as well?
    Edit:
  16. Oct 5, 2024 at 10:40 AM
    Can't you just have a locksmith rekey (re-barrel) the mismatched cylinders to the OEM key?
    NUDRAT likes this.
  17. Oct 5, 2024 at 10:43 AM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    Everywhere I’ve looked it’s been more expensive to rekey than to just buy new.
    Plus buying new I would have two new keys
    whodatschrome likes this.
  18. Oct 5, 2024 at 11:56 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Put the new battery in, ran a hose over it and put about 40 miles on it today
    Yard work tomorrow
  19. Oct 5, 2024 at 12:27 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I used it on the rear doors of my double-cab.
    I would reach out to him and ask if you have concerns. He said that some newer models have a different type of door check that lasts longer but is made a bit differently and may not work with his product.
  20. Oct 5, 2024 at 12:34 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I did the TPMS disable via grounding the pink wire. Happy to have that light turned off.
    As soon as I get my new OBD Link MX+ I’ll hopefully diagnose and fix my ABS light and have normal cluster again.
    shifty` and abcinv like this.
  21. Oct 5, 2024 at 4:21 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Colder air intake cause snorkels are dumb in TX
  22. Oct 5, 2024 at 4:29 PM
    Needs a little scoop
  23. Oct 5, 2024 at 4:37 PM
    When I was living in Phx and going to tech school, the neighbor I worked for was working on a VW bug and had ducts in the rear windows to direct air at the heads I assume? But supposedly a recess into the tube works better than a scoop.
    During the same stint, my cousin was telling me it’s not great to drive without a hood, because the air dam it creates over the engine and not letting the radiator flow air properly
    oscardog86, FishNinja and Sirfive like this.
  24. Oct 5, 2024 at 4:41 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    thats a low pressure zone. Interesting to know how that changes the timing or fuel trims.
    KNABORES and FrenchToasty like this.
  25. Oct 5, 2024 at 4:51 PM
    FishNinja
    Lee
    06DC2wd
    I'll go romp on it after I take a shower and let you know if my truck starts acting weird. Lol
  26. Oct 5, 2024 at 5:13 PM
    I would think air rushing past that opening would create suction rather than feeding air in.
  27. Oct 5, 2024 at 5:14 PM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    Where can I learn more about this? I got a tpms light and abs lol
  28. Oct 5, 2024 at 5:21 PM
    FishNinja
    Lee
    06DC2wd
    Shitbox is now louder? Nothing off when stepping on it. Still boogies.
    I just gotta keep an eye on MPG and see if I am actually doing something for the truck or just making the filter dirty faster lolll
  29. Oct 5, 2024 at 5:26 PM
    It took me under 5 minutes with an OBDlink MX+ dongle, with their free smartphone app, to both FIND and CLEAR TPMS codes for my dead/failed sensor to stop the light from flashing and I didn't even need to replace the sensor. Full info here:
    https://www.tundras.com/threads/obd-thread-pids-apps-dashboards.60459/page-10#post-3132384
    Expand the comment there to read more. Easy peasy. I've since updated my TPMS sensors to new Denso, $35/wheel. Batteries were dead in one and dying in a 2nd.
    Stock63[QUOTED] likes this.
  30. Oct 5, 2024 at 5:28 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Saw an FGT at T2S with that setup once. I feel like I would go through air filters like crazy with that
