Radiator question
Discussion in '1st Gen Tundras (2000-2006)' started by gizardlizard, Oct 2, 2024.
  1. Oct 2, 2024 at 10:30 AM
    A what now? Guess I don’t have one of those or nobody has mentioned it for an 02.
  2. Oct 2, 2024 at 12:17 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I want to say the ATF cooler was standard thru 2002, at least on V8 trucks. There was no separate towing package. Then in 2003, the separate towing package became available.
  3. Oct 2, 2024 at 12:19 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    its just a loop of tubing, not hard to miss or overlook - but i can’t say with certainty that 2000-02 had them.
  4. Oct 2, 2024 at 12:50 PM
    There was a towing package but it was just the hitch as I recall.
  5. Oct 2, 2024 at 1:32 PM
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD 4.7L AX
    At least for 2005, this was the "towing package". It was optional on RC and AC, but standard on DC, and it appears that it was not available at all on the v6 models:
    "V8 Towing Package — includes Class IV towing hitch receiver, 7-pin connector with converter, heavy-duty 130-amp alternator and supplemental transmission oil cooler"
    G_unit3000 and Jack McCarthy like this.
  6. Oct 2, 2024 at 2:56 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I replaced my radiator for the first time at 225,000 miles. Yeah pink milkshake is an issue, but not till very high mileage and age. So it's not like it's much of a "weak spot". 100,000 mile replace intervals and it's no problem at all.
  7. Oct 3, 2024 at 6:26 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Yep, just a loop. And I couldn't get the new lines hooked up to it without pulling the bumper off...
  8. Oct 3, 2024 at 2:59 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    This is true on my 2005 DC with towing package. Trans oil cooler is in the spec sheet
  9. Oct 3, 2024 at 3:07 PM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    Also, LSD is not specifically named on that list of tow package installed equipment for my vehicle but I checked underneath and definitely have it
