Plugging Roof Holes
Discussion in 'General Tundra Discussion' started by Tan-dra, Sep 30, 2024.
  1. Sep 30, 2024 at 6:25 PM
    Tan-dra
    Tan-dra [OP] MUD GANG 2006
    2020 Quicksand SR5
    Bilstein 5100, 35’s on 17” wheels
    Not really sure where to post this. I am looking at buying a 2nd Gen, but the previous owner installed clearance lights on the roof of the cab. They are drilled into the roof itself. Does anyone know if there is an easy way to plug roof holes? I don’t love the look of these lights but if it’s gonna make the roof leak if I remove them then not a deal breaker. Thanks for any info upload_2024-9-30_20-25-18.jpg
  2. Sep 30, 2024 at 6:36 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    That's a body shop situation right there. If you're not totally against cab lights, but just against those, then why not try a different cab light setup?
    Tan-dra[OP] likes this.
  3. Sep 30, 2024 at 6:43 PM
    Tan-dra
    2020 Quicksand SR5
    I don’t hate them but I’d prefer if they weren’t there, if you know what I mean. Not really worth spending a bunch of money to remove them and fix the holes though. Maybe I can repurpose the holes to wire up some Baja design lights or something in the future
    texasrho83 likes this.
  4. Oct 1, 2024 at 9:28 AM
    Bammer
    Monroe, CT
    I'd leave them, look pretty KEWL IMHO !
  5. Oct 1, 2024 at 9:48 AM
    2mchfun
    One could easily fill the holes with epoxy putty, but the paint would be a little tougher to correct due to prior fading.
  6. Oct 1, 2024 at 12:18 PM
    kentuckyMarksman
    kentuckyMarksman New Member
    If it were me and I opted to not have lights there, I'd bondo over the holes, sand it flush, and spray paint it with the closest color I found. I wouldn't worry about getting an exact match on the paint, just close enough. I mean, do people look at your roof often? My last truck, the roof color wasn't even close to the rest of the truck, and I rarely looked up there to even care.
    Now if the headliner were out for some reason, then I might be tempted to plug weld the holes...
  7. Oct 1, 2024 at 12:44 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  8. Oct 2, 2024 at 4:29 PM
    seydou
    seydou Distinguished Member
    I personally think marker lights look stupid. But if I were to buy that truck, I'd leave them be. Not worth the time, money or hassle to remove or replace.
    Trooper2, Fobroader and Tan-dra[OP] like this.
  9. Oct 3, 2024 at 2:45 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    I think you should let them be and instead use GE or whatever else makes weather resistant (UV resistant) silicone so you ensure water is not getting in..and check up on that every 2-3 years.
    Fobroader likes this.
  10. Oct 3, 2024 at 9:23 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    To be honest the headliner comes out really, really easily. Look up YouTube videos. Then have a guy spot weld the holes and sand it. A respray of just the roof would be cheap and no one would notice. Nice thing, the blue doesn’t fade too bad it would hardly or quite literally be unnoticeable.
    BTW, you got yourself a nice truck there. Heck of a deal. I’m not into the Bro roof lights either. They’d be gone!
  11. Oct 4, 2024 at 1:46 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I’d get matching thickness sheet metal, spot weld, and sand it flat. If needed use body filler to smoothen it out before primer and paint.
  12. Oct 4, 2024 at 4:33 AM
    siznarf
    siznarf Not New Member
    Kommiefornia
    04 DCLB 4.7 4WD - 07 RCSB 5.7 4WD -
    Saw this truck for sale on Marketplace (now sold) - were you the one that bought it?
  13. Oct 6, 2024 at 7:46 AM
    Tan-dra
    2020 Quicksand SR5
    Nah someone else bought it before I was able to. Oh well ‍♂️
