5.7 Engine knock at idle
Discussion in '2.5 Gen Tundras (2014-2021)' started by SendtheFire, Jan 26, 2021.
  1. Feb 14, 2023 at 3:59 PM
    Rw429
    Rw429 New Member
    Rob
    2017 Black Toyota Tundra SR5 Crewmax TRD Off Road
    Yeah my 17 seems to have the valve / tick rattle when cold and then subsides when it reaches full operating temperature. If I accelerate prior to warming up. It is a bit concerning how it sounds. However, no oil loss, plenty of power and everything appears ok under the hood. Got me.
    stanky likes this.
  2. Feb 14, 2023 at 8:40 PM
    citrusmaster
    citrusmaster New Member
    Tielar
    2015 Tundra RCLB
    My 15' with 175k makes the same noise in the video. I switched to 5w-30 and it didn't really change.
    Pretty sure it is the timing chain/chain tensioner. It is most prevalent at idle when cold and goes away when your foot is on it or when warm. It has done it since I got it and I have put a good bit of miles on it by now. I am not going to worry about it.
    stanky likes this.
  3. Feb 15, 2023 at 3:18 AM
    blanchard7684
    blanchard7684 New Member
    Totally normal.
    I'm trying out 5w30 right now and it does seem to make the engine quieter than 0w-20...but I like the additive package in Toyota 0w-20...decisions.
  4. Feb 15, 2023 at 6:34 AM
    stanky
    stanky New Member
    2021 4x4 crewmax
    Platinum
    10-4 I wish I could be so calm about it. And maybe its just my engine coming into its prime cause my gas mileage has gone up a bit in the last few months, but this thing gets fuggingg LOUD sometimes just like that video. Sounds like its gonna slowly rip its self apart...
  5. Feb 15, 2023 at 12:49 PM
    Rw429
    Rw429 New Member
    Rob
    How did you get your mpg up to 17.0? Just curious, since the best I see is 14.5 mixed city, with some highway. Maybe that’s my issue.
    stanky likes this.
  6. Feb 15, 2023 at 5:55 PM
    raketemensch
    raketemensch New Member
    NEVADA
    I'm getting 11.4 mpg right now and I thought that was great
    stanky likes this.
  7. Feb 16, 2023 at 3:01 PM
    Giskk
    Giskk New Member
    Mississippi
    2021 Cement Tundra TSS Off-road
    My 2021 sounded like that using 0-20. I put in Valvoline EP 5W-30 and it is much quieter. Gas mileage is not much worse. I can get 19 MPG running 55 MPH on a state highway using the 5W-30
    stanky likes this.
  8. Feb 16, 2023 at 4:00 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    You drive 55mph on a highway? Seems like a dangerous thing to do.:burnrubber:
    koditten, stanky and Giskk[QUOTED] like this.
  9. Feb 16, 2023 at 7:16 PM
    raketemensch
    NEVADA
    tomorrow I'm going to try the ATS chemical treatment and then 5w30 with the HPL 30w cleaner. wish me luck
    stanky likes this.
  10. Feb 16, 2023 at 7:40 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    An all aluminum engine, with two massive timing chains will always sound a little louder then some of the cast iron engines some might be used to IMO. Changing over to 5/30 definitely helped quiet mine down, but I wouldn't worry about it, even when running 0/20.
    Terndrerrr and stanky like this.
  11. Feb 17, 2023 at 11:52 AM
    pursuit2550
    pursuit2550 New Member
    Geez, talk about resurrecting an old thread. Anyways, Its normal. I am on my 4th Tundra and all have sounded like this. I will say that 5w-30 will quite it down some and give you more oil pressure.
    stanky likes this.
  12. Feb 17, 2023 at 6:23 PM
    raketemensch
    NEVADA
    May be to early to tell, but the ATS 505CRO followed up with the HPL 30w cleaner seemed to work
    stanky likes this.
  13. Feb 19, 2023 at 8:42 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Since this thread has been resurrected I will follow up on my earlier comment. There is a normal Toyota valvetrain noise and the noise in the first video of this thread is that normal noise plus the extra noise of other components from being an aluminum block, like many others have said. It is just very hard to get used to.
    In my case, due to leaking cam risers I tore mine open. I ended up replacing the tensioners, drivers side main was stuck bad. That didn’t change the sound of my engine. Mine did have a diesely noise which was definitely from the secondary air injection connection port on the drivers side manifold. If you hear additional noise from what is in the video I highly recommend checking the manifold prior to blaming tensioners. There are also an inspection ports for the main tensioners on the timing cover but still require removal of other items to access.
    stanky likes this.
  14. Feb 20, 2023 at 12:02 PM
    stanky
    stanky New Member
    2021 4x4 crewmax
    Platinum
    Gassed up right off the freeway and took it ez getting back on, set the cruise so the tack was little over 2k and rode it.
    Pig Rig likes this.
  15. Feb 20, 2023 at 12:12 PM
    Retired...finally
    Maybe it's been covered and I missed it but how many miles are some of these "knockers" going between oil changes?
    My 21 is as quiet as can be. With the exception of start up when it sounds like a huge turbofan jet engine. Throw in the smell of half burnt kerosene and I'd swear I was as the airport
    stanky likes this.
  16. Feb 20, 2023 at 12:17 PM
    stanky
    stanky New Member
    2021 4x4 crewmax
    Platinum
    15k right now. Oil was changed at 1500 and around 5k ever since.
  17. Feb 20, 2023 at 1:20 PM
    raketemensch
    NEVADA
    I suspected some of the noise was the secondary air injection. Since using ATS and HPL 30w cleaner oil on Friday I have no more timing chain slap. there is still a really loud noise in the first 1-3 seconds at cold start that sounds like its coming from the manifold
    stanky likes this.
  18. Feb 25, 2023 at 1:11 PM
    citrusmaster
    Tielar
    2015 Tundra RCLB
    I used to get 17 in mine when I was doing mostly highway cruising at 70 delivering stuff far away. Now I do more city driving and its 14.5. I also put a heavy front bumper and bigger tires. It makes a big difference.
  19. Apr 6, 2023 at 6:08 PM
    Unwittyname
    Unwittyname New Member
    My 2021 5.7L crew max with 20k miles has a cold start nock that sounds just like this but louder. I think the clatter ticking / diesel sound is normal. But I took it to the dealer for the cold start nock that's more audible on the passenger side. They agreed it didn't sound right. They diagnosed it as a cam shaft gear problem. They replaced the camshaft gear but it didn't solve the problem. Now it's back to square one. I'll find out more info soon...
  20. Dec 14, 2023 at 3:49 PM
    #50
    Ed d
    Ed d New Member
    Hope someone still watches this thread....lol
    My 19 5.7 tundra makes a similar noise.
    Had it in several times to the dealer and all said they heard it but seemed normal. And to be honest that was 40K miles ago, but still makes a knocking sound at idle, more when the motor is stopped, in great with a load like the AC on. You can turn the ac off and the noise gets much quieter.
    No noise at start and when warming up, but the warmer it gets and especially in hot weather the louder it is. Get it above 10 or 15mph and it's gone.
    Shouldn't worry but it does drive ya crazy!!
  21. Feb 28, 2024 at 5:31 PM
    #51
    Yoda-Tundra
    Yoda-Tundra New Member
    Justin
    Virginia
    2018 Tundra Limited
    This noise has had me concerned since I bought it used with 38k. I’ve listened to some others at work and mine is definitely louder. My truck is lifted with cuts in the liners so maybe that contributes to it being louder. I also get knocking that increases with RPMs but it’s intermittent.
    Let’s keep this thread alive. I want to know if anyone has experienced engine failure after noticing this noise.
    k0diak8o8 likes this.
  22. Feb 29, 2024 at 11:23 AM
    #52
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Sounds completely normal to me. My 21 has sounded like that when new and i was test driving it. Maybe even worse. Got 60k on her and nothing has changed.
    Also noticed some coworkers truck sounded better than mine., less rattle/diesel/ valvetrain noise. Trucks were parked side by side and fully warmed up and both running in park. His was 2 years older than mine and was a 4x4 everything else was the same option wise. But his had less extra noise/valvetrain/ Diesel like clatter.
  23. Feb 29, 2024 at 11:26 AM
    #53
    FabioXc
    FabioXc New Member
    None
    Hmm mine sounds more worse tbh but since I have warranty I brought it in to have them look at it other than that the trucks drives fine
  24. Sep 26, 2024 at 4:36 PM
    #54
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Anymore update on this?
    I just purchased a 21 and it’s doing similar thing. More noticeable on the passenger side. Only had it 1 week. I noticed it after i did an oil change. Immediately after the oil change and start up i hear the knocking noise. The engine is quiet. But the knocking can be heard.
    2021 tundra platinum idle noise. Knocking?
    https://youtube.com/shorts/GJLH9JH5R4Y?feature=share
  25. Sep 26, 2024 at 4:57 PM
    #55
    Adamace1
    Adamace1 New Member
    None....
    I always change my oil before 3k to 4.5k miles.
  26. Sep 27, 2024 at 4:44 AM
    #56
    BrandonL812
    Brandon
    Ok. Thanks. I’ll keep an eye on it and try to not worry about it.
    batman900[QUOTED] likes this.
  27. Sep 27, 2024 at 5:08 AM
    #57
    godrew1972
    godrew1972 New Member
    2007 Tundra 5.7
    None
    had 2007 since new, has always made the noise before warmed up. Some very early discussions or complaints about the 2 gen was the truck had a slight diesel sound to the 5.7.
    i have 192000 miles and she still has the noise, no drama.
    batman900 likes this.
  28. Sep 27, 2024 at 5:10 AM
    #58
    BrandonL812
    Brandon
    Mine only after fully warmed up. It’s definitely louder than the normal injectors firing ticks.
  29. Sep 27, 2024 at 5:17 AM
    #59
    Mr Badwrench
    Mr Badwrench New Member
    Unless the camera is filtering something out that you were hearing, that sounds normal. The 5.7 sounds like a sewing machine.
    Terndrerrr likes this.
  30. Sep 27, 2024 at 5:19 AM
    #60
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    That’s not knocking. That’s normal ticking, and it can be quieted down with thicker or better oil. Mine is quieter with Kirkland 5w30. It was also quieter with Amsoil 0w20.
    The 3UR-FE is likely the most diesel-sounding gas engine in the world. Aluminum block and thin oil don’t help.
